Has anyone used one of these? It would be mostly for my 50 1.4 to use 1.4 in studio or bright sunlight. Any opinions?
bugler Member 153 posts Joined Aug 2013 More info | Sep 25, 2013 22:25 | #1 Has anyone used one of these? It would be mostly for my 50 1.4 to use 1.4 in studio or bright sunlight. Any opinions? Bodies: 6D, EOS-M, & 1Ds(for sale)
Sep 25, 2013 22:41 | #2 i use one pretty often, its great for long exposures or keeping great DOF | 5Dc | 7D | 1D3 | 1Ds3 | 17-40 4.0 | 28 1.8 | 40 2.8 | 50 1.8 | 85 1.8 | 135 2.0 | ∑ 24-70 | ∑ 70-200 OS |
Sep 25, 2013 22:49 | #3 I honestly didn't even know these existed till yesterday at a somewhat local camera shop. I hadn't been in a proper camera shop in years. The stuff at best buy just doesn't cut it. Bodies: 6D, EOS-M, & 1Ds(for sale)
1Tanker Goldmember 4,470 posts Likes: 8 Joined Jan 2011 Location: Swaying to the Symphony of Destruction More info | I would just grab a 2 stop ND. Cheaper with less chance of IQ problems (such as the dreaded "X" that VND's sometimes give) Kel
Sep 25, 2013 22:58 | #5 That's the answer I was looking for. To get one that would fit all my lenses with adapters out would cost me well over $200. If I'm gonna spend that much, it better not affect image quality... Bodies: 6D, EOS-M, & 1Ds(for sale)
JohnfromPA Cream of the Crop 11,257 posts Likes: 1526 Joined May 2003 Location: Southeast Pennsylvania More info | Sep 26, 2013 06:19 | #6 Between a decent polarizer, low ISO, and high shutter speed it seems to me you could readily get to f1.4.
Sep 26, 2013 07:01 | #7 John, in outdoor situations with no flash, yes. But in the studio where that lens spends a lot of its time, flash sync speed hinders getting a fast enough shutter speed. Bodies: 6D, EOS-M, & 1Ds(for sale)
RockyRhode Goldmember 1,416 posts Likes: 6 Joined Apr 2011 Location: Sacramento More info | Sep 26, 2013 08:30 | #8 bugler wrote in post #16326439 But in the studio where that lens spends a lot of its time, flash sync speed hinders getting a fast enough shutter speed. Don't quite understand why you need f/1.4 in a studio situation; that being said what ever you do don't scrimp on the Var-ND filter. The outcome of your image is limited to the glass in front of the sensor. Just as you would not want to spend $500.00 to get corrective lenses for your eyes and then slap layers of smoke grey cellophane over them, when you go outside, you don't want to buy a cheap Var-ND filter and slap it in front of your lens.
DBNissan Goldmember More info | Sep 26, 2013 08:35 | #9 bugler wrote in post #16326439 John, in outdoor situations with no flash, yes. But in the studio where that lens spends a lot of its time, flash sync speed hinders getting a fast enough shutter speed. You might be able to get away with using Yongnuo YN-622C flash triggers. The will HSS with studio lights via a PC sync cable. Then you wouldn't need any ND filters
newworld666 Goldmember 2,306 posts Likes: 20 Joined Jan 2009 Location: on earth More info | Sep 26, 2013 09:43 | #10 I use frequently outdoor for action and panning. My target is to be able to keep a creamy background (mostly between F1.2/F2.0) and no horizontal stripes F1.2 IMAGE LINK: http://photos.corbi.eu …/O/_R8T0204%20copie-O.jpg Marc
amfoto1 Cream of the Crop 10,331 posts Likes: 146 Joined Aug 2007 Location: San Jose, California More info | Sep 26, 2013 11:13 | #11 Yeah, the problem with the variable NDs is that most give a color cast, some also give badly splotchy effect.... especially the more affordable ones. The higher quality such as Singh-Ray give better effect with less blotchiness and truer color rendition... but are terribly expensive. Alan Myers
Sep 26, 2013 11:32 | #12 I first built one myself by getting a cheap linear polarizer and putting it on top of my circular, to see if I liked the idea. At less than $10, easy to do. I think it was a Tiffen linear polarizer, just cheap since most are circular now. Worked good enough to make me get an ebay version for around $70, some no name thing sold under many different names/brands. Worked ok, did give some color cast that's easy to remove. I did get the X (a X shaped lighter area going across the image) when fully closed. 40D, 5D3, a bunch of lenses and other things
Snafoo Goldmember More info | Sep 26, 2013 12:48 | #13 The dreaded X is usually only a problem at wide focal lengths.
Sep 26, 2013 13:21 | #14 |
Sep 26, 2013 15:49 | #15 The shop by me Service Camera only has Promaster brand available. Anyone have experience with that brand? The highish price ($200 for 77mm) makes me believe it may be ok. Promaster does seem to have a cheaper version in each size, the 77mm being like $75 but I don't trust that one. Bodies: 6D, EOS-M, & 1Ds(for sale)
| Latest registered member is MWCarlsson 1261 guests, 172 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
