I have a Dell U2410 and a Colormunki Display.
After calibration I notice the display is dimmer, which is what I'd expect. My question is; if I go into my monitor settings, the brightness is still set on 100. Does that sound correct?
Sep 27, 2013 09:38 | #1 I have a Dell U2410 and a Colormunki Display. Canon 5Dm3, Fuji X100T, Fuji X-T1, Fuji X70
Bob_A Cream of the Crop More info | Sep 27, 2013 21:41 | #2 Does the calibration software target luminance or do you need to manually adjust it? I'm also not familiar with the monitor, but if it's a software calibration then I'd expect you'd need to (possibly manually) drop brightness to around 15% to get somewhere between 80 to 110 cd/m^2. It should look disturbingly dim compared to 100% brightness. Bob
Lowner "I'm the original idiot" 12,924 posts Likes: 18 Joined Jul 2007 Location: Salisbury, UK. More info | Sep 28, 2013 09:52 | #3 My Eye-One Display 2 requires that I adjust the brightness (luminance) and contrast manually with assistance prior to starting the automated calibration run. Richard
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | Sep 28, 2013 10:04 | #4 There are two ways that a monitor can be made darker; The hardware method in which the backlight is dimmed or the software method in which the profile's tonal response curve is pushed way over to the right. If you don't do the first, the calibrator will do the second, but the hardware solution is the better one, better than a truncated TRC. That is why most software packages will request that you manually reduce brightness first, before the calibration measurements are made. You do most of the work and then the calibrator completes the job. Elie / אלי
tonylong ...winded More info | Sep 28, 2013 14:20 | #5 tzalman wrote in post #16331199 There are two ways that a monitor can be made darker; The hardware method in which the backlight is dimmed or the software method in which the profile's tonal response curve is pushed way over to the right. If you don't do the first, the calibrator will do the second, but the hardware solution is the better one, better than a truncated TRC. That is why most software packages will request that you manually reduce brightness first, before the calibration measurements are made. You do most of the work and then the calibrator completes the job. Ah, that's excellent info! Tony
| Latest registered member is Monkeytoes 1331 guests, 169 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
