Thread started 28 Sep 2013 (Saturday) 14:08
North America Nebula and surroundings
Madweasel
Sep 28, 2013 14:08 |  #1
Getting my Astrotrac driven mount has given me a renewed interest in astrophotography. Here's my latest stack, centred on the North America Nebula region of Cygnus, as it's currently overhead from my latitude in the first part of the night. This means it's the darkest part of my light-polluted sky, so less work to process it out.
This is a stack of 12 30-second exposures with the 70-200/4L at 70mm f/4 on my unmodified 7D at ISO1600. I also used 10 flats, 10 darks, a similar number of dark flats and about 28 bias exposures, all to try and get the best final result I could manage. I stacked using the Kappa-Sigma Clipping method, which seemed to give me a better result than the default averaging. I neutralised the sky colour and boosted saturation of the stars a little, all in Deep Sky Stacker, and then did a little contrast stretching using curves in Photoshop. Nothing more than that. On the full-size version the faintest stars are about magnitude 14.5.
You can clearly see NGC7000, the North America Nebula, though I can see why people get the 60Da, or modify their existing bodies, because the red colour is very muted here. I've also faintly captured the Pelican, IC5070, and some of the brightest bits of IC1317, near Gamma Cyg (on the far right of the image), plus a handful of open clusters. I've pointed these out in a labelled version below the original.
IMAGE: http://i72.photobucket.com/albums/i192/garlicpickle/Canon/lr1small-_zps2ef45d66.jpg
IMAGE: http://i72.photobucket.com/albums/i192/garlicpickle/Canon/lr1small--2_zpsa9d2080f.jpg
Mark.
the ­ jimmy
Sep 29, 2013 12:27 |  #2
Great shot and processing. I like the marked up version for us who aren't so familiar with these deep sky objects.
NovaTJ
Sep 29, 2013 15:11 as a reply to  @ the jimmy's post |  #3
I agree...great shot! Now I see where IC5070 really is...:)
Greg
Astro-Tech 8" f/4 imaging Newtonian,Baader MPCC,Orion ED 80 APO F7.5,Skywatcher EQ-6 Pro,ASGT, Modified Canon 50D, Meade DSI Guide Camera, 8" SCT dovetail mounted relic, Criterion Dynascope RV-6, modified 300D, custom astro shed,and still just getting started!
Madweasel
Sep 29, 2013 15:40 |  #4
Thanks both, I'm really pleased with how it came out.
Mark.
samsen
Oct 04, 2013 16:40 |  #5
Love it when photographer becomes a sincere researcher and does his homework as good as you did then projects it all for the inspiration of the others.
Way to go and enjoy remaining warm nights of summer/early autumn.
Weak retaliates,
Strong Forgives,
Intelligent Ignores!
Samsen
Picture editing OK
samsen
Oct 04, 2013 17:06 |  #6
Also I did play a little bit on PS with your image and see you can do a lot better with a push of post processing. I see that you have not marked "OK" for Image Editing otherwise would post the result here. Any way give it a bit more of CS and I am sure you can bring out more even without modified sensor.
Additionally for my normal orientation, though I see the North America nebula very well as is, I believe it worth to give a clockwise rotation of 12 to 15 degree.
Any way well done job.
Weak retaliates,
Strong Forgives,
Samsen
Picture editing OK
Madweasel
Oct 04, 2013 18:21 as a reply to  @ samsen's post |  #7
Thanks for the encouragement Samsen. I lined the shot up with the plane of the milky way, rather than the orientation of the North American outline, but I see what you mean.
I'd be very interested to see what you were able to do with additional processing, because that's definitely still my weak spot with this sort of image. Please post it up - I don't have processing ticked because I don't want people playing with my images without permission generally, but I'd like to see your edit - and let me know what you did.
Mark.
ecce_lex
Oct 06, 2013 03:06 as a reply to  @ Madweasel's post |  #8
I like your shot a lot: maybe not so much detail, but soft processing and no burnt-white stars. Nice job.
For annotations, calibration and many geeky details, try running your photos through astrometry.com
Schrodinger's cat walked into a bar - and didn't.
Gear: 60mm Takahashi, 200mm C8, 7Dmod, EQ6
Website: https://plus.google.co​m …873112797282158​324/albums (external link)
samsen
Oct 06, 2013 05:43 |  #9
Sorry for the delay. Weekends go crazy.
I will leave the link to larger file size image in dropbox for the photoshop *.psd file so that you can see all the layers I used. Check your PM box for the link. Just download that (About 10Mb) and uncheck all the layers from top to bottom leaving background only that is your current picture, then check them from bottom upward to see the progression.
Also two very compressed pictures are attached here that do loss a lot of quality due to compression.
Not sure if you like my processing but if you do, and need more info, let me know.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/10/1/LQ_664279.jpg
Image hosted by forum (664279) © samsen [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/10/1/LQ_664280.jpg
Image hosted by forum (664280) © samsen [SHARE LINK]
Weak retaliates,
Strong Forgives,
Samsen
Picture editing OK
the ­ jimmy
Oct 06, 2013 07:52 |  #10
ecce_lex wrote in post #16349374 (external link)
Cool site and great resource. BTW it is astrometry.net
2,330 views & 0 likes for this thread, 5 members have posted to it.
1076 guests, 114 members online
