Thread started 29 Sep 2013 (Sunday) 18:09
My 430ex + yongnuo transmitter just took a bath..
Christopher ­ Steven ­ b
Sep 29, 2013 18:09 |  #1
I was at the park this evening photographing an engagement session when I very stupidly placed my lightstand + umbrella + 430ex near to the water. One gust of wind when I went to change the lens up and into the water it went. It was submerged for about 5 seconds before I scooped it up. I had a laugh with the couple and simply started using my backup flash. In terms of the one that took a bath, I turned it off, took the batteries out and just put it in my bag. I did the same with the yongnuo transmitter that it was attached to.
My question: what should I do to give the flash and / or transmitter the best chance of survival ?
christopher steven b. - Ottawa Wedding Photographer
www.christopherstevenb​.com (external link)| Blog (external link)
sirquack
Gallery: 66 photos
Joined Jan 2013
Sep 29, 2013 18:22 |  #2
Put them both inside a plastic bag with rice. This has saved many of my electronic devices including my sons almost new I phone.
Name is Ron.
Bodies - 6D/5D3/7D2-Gripped
Lenses - Canon 17-40 F4/24-70 F2.8 II/85 F1.8/Canon 70-200 F2.8 II/F4/Sigma 30 DC/Tamron 150-600
Website (external link)
Sep 29, 2013 18:31 |  #3
Thanks Ron. Would you open the battery doors or even go further and disassemble ?
sirquack
Gallery: 66 photos
Joined Jan 2013
Sep 29, 2013 18:56 |  #4
I would not open the battery compartment unless you can make sure the rice does not end up in the compartment. No need to disassemble. The rice soaks up the excess. Just make sure you get as much of the excess water cleaned up before putting it all in rice. I would leave it there for a few days before you try it out.
Name is Ron.
Tiberius
Sep 29, 2013 19:39 |  #5
You could always open the battery door and then put the flash inside a sock or something to keep the rice out.
My photography website!PHOCAL PHOTOGRAPHY (external link)
sirquack
Gallery: 66 photos
Joined Jan 2013
Sep 29, 2013 20:25 |  #6
I even thought about maybe stuffing the battery compartment with rolled tissue to keep the rice out of the gaps. The only thing I would worry about is rice getting into a gap and causing its own problems after everything is dried out.
Name is Ron.
FlashZebra
This space available
Sep 29, 2013 22:11 |  #7
Do not put them inside anything. Why contain the moisture inside a moisture barrier with your flash?
1) Assuming the water was relatively clean and not salt water, remove the batteries and tape open the battery doors.
2) Drain any water from the flash and radio receiver.
3) Place the flash and radio receiver in an open area and place a fan on them. Increase the air flow over the flash and radio receiver, do not restrict it. Water evaporates fastest with INCREASED air flow.
4) Change the orientation of the flash and radio receiver from time to time.
5) Do this for at least 2 days, longer if you do not need the gear.
6) Replace the batteries and things will likely be fine.
Enjoy! Lon
1,446 views & 0 likes for this thread, 4 members have posted to it.
1686 guests, 141 members online
