Thread started 29 Sep 2013 (Sunday) 21:33
Colour management .. help!!
philbyuk
Gallery: 52 photos
Joined Nov 2005
Sep 29, 2013 21:33 |  #1
hi there , struggling to get colour matching on screen to what I print out .. what I see on screen is good same as on web as well as in PS cc
when I print the colours seem more vibrant /saturated , maybe a colour cast to them .. i.e. grey seems brownish ! grass is a lot greener almost to green !
tried printing same pic out from picture viewer still same so thinking its printer driver /icm although icm turned off when I'm using Photoshop to print
so I guess what I'm asking is
is the printer next to useless (also tried other icm profiles from Epsom still same problem) or am I missing a setting or not using correct settings?
software ..Photoshop cc
printer Epson stylus photo R360
calibrated monitor ..with optix xr
settings in p/shop cc..
Photoshop settings
colour settings
setting.Europe prepress 3
workspace... adobe RGB(1998)
CMYK... Coated forgra39
gray ...dot gain 15%
spot ...dot gain 15%
all else as std settings
proof setup (although I don't think this matters to the actual colour management side )!!
Device to simulate ..stylusPhotoR360 R390 Series
preserve rgb numbers ticked
print settings ..
printer set up Epson Stylus PhotoR360 Series
colour management .. Document profile .. Adobe RGB9(1998)
colour handling ..photoshop manages Colours
printer profile ...stylusPhotoR360 R390 Series
normal printing
relative colourmetric
black point .ticked
printer settings ..
paper Epson premium glossy paper
quality ..photo
size 13X18 cm (as paper size)
ICM.. (off) No Colour Adjustment ticked
hope someone can help thanks in advance ..phil
My 365 '2018' (external link)
tim
Light Bringer
Sep 29, 2013 22:44 |  #2
Please post:
- A screen shot of your color settings - I'm unsure whether you're using aRgb or CMYK.
- Tell us what monitor/OS you're using (Monaco XR doesn't work with LED monitors)
- Post a link to a high res image exactly as you printed it
Also read this thread. Turn on the three checkboxes in the color management dialog - after you do the screenshot.
philbyuk
Gallery: 52 photos
Joined Nov 2005
Sep 29, 2013 23:22 |  #3
As requested screencapture of colour settings
monitor is a NEC multisync 90gx pro lcd
As for high res pic of print I don't have access to web space, and think it would be to big to fit here .. although it would still be a picture of pre print
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/09/5/LQ_663726.jpg
Image hosted by forum (663726) © philbyuk [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/09/5/LQ_663727.jpg
Image hosted by forum (663727) © philbyuk [SHARE LINK]
hope this helps
thanks in advance
looking at the print against the picture it seems more yellowish tint overall grass looks almost lime coloured .if that helps
Mark ­ Vuleta
Gallery: 48 photos
Sep 30, 2013 01:05 |  #4
Sorry, I can't really help with anything specific. I have not been able to find anything regarding the R390 or R360's. I did download the drivers for the R320 which I assume will be just a regional difference.
The ICC file for the R320 is "E_FIC9FA.ICM" and it's plot is almost a like for like match to sRGB so perhaps your would be better off working in sRGB anyway.
As far as your issues go, I assume that you have done all of the normal things like ensuring that the inks are still in date range, that the print head nozzels are clear & a print head alignment has been performed. I would also try the Perceptual rending intent rather than the Relative Colorimetric.
EDIT: I also think you should un-check "Preserve RGB Numbers" in your proof setup.
tim
Light Bringer
Sep 30, 2013 02:36 |  #5
Your color settings look fine, but I can't say about the print dialog, I never print myself.
Send the image to yourself using yousendit.com or put it on dropbox in a public folder. The reason being someone else calibrated can check it looks right.
Lowner
"I'm the original idiot"
Sep 30, 2013 04:18 |  #6
Knowing that Epson are normally pretty good printers, I'd start thinking about monitor calibration rather than immediately blaming the printer. Of course the internet shots will look like your own, but both might still be wrong.
And yes, your particular printer could be faulty. As you are UK based, try getting an Epson Engineer to pop round and check it out. They did that for me on my R2880 when I found a snag with the black ink swop.
Richard
philbyuk
Gallery: 52 photos
Joined Nov 2005
Sep 30, 2013 05:46 as a reply to  @ Lowner's post |  #7
thank you all for your help .. ,the printer is actually a few years old now and its not exactly a pro model so maybe time for an upgrade.
as far as colour profiling I calibrated it with Monaco optix colorimeter ,,so I'm guessing the monitor isn't to far off. tried a few different settings different icm profiles and black dot , use numbers off etc. still the same
maybe the drivers are outdated now and not really supported although the drivers are from Epson they haven't been updated by them since 2012
time to look for a newer model ..thanks
anyone got suggestions for a good printer .. probably looking at spending ..£300- £450
BaliHai
Sep 30, 2013 09:28 |  #8
What ICC profile are you using for your paper that can be critical. I've used the wrong profile before and it completely skews the colors. Also if you are low on one color of ink that messes with things. I use Epsons a 7600 and a 3800 and those are a couple of our problem areas we check first when we see color issues.
Canon 5D and 20D, 70-200mm f2.8L, 24-70mm f2.8L,
35-80mm, 70-210mm, 18-55mm, 85mm f/1.8, 135mm f/2L
lightmeter, tripod, studio lights
notastockpikr
Joined Aug 2011
Sep 30, 2013 15:53 |  #9
Based on my brief research, your printer prints with six colors and will never match the output of your screen regardless of the color management settings. I think it's time for a new printer.
Based on the amount of printing you do, I would recommend the Epson R2880 or R1900. In addtion, I would use the sRGB color space rather than RGB(1998). Use the sRGB for your monitor(if you can set it) and use this same color space in your camera.
Also, when you get your new printer, download the ICC printer profile for the paper you are using. Once the printer is upgraded, your print should match what you see on your monitor. (YMMV)
philbyuk
Gallery: 52 photos
Joined Nov 2005
Oct 01, 2013 00:29 |  #10
thanks fir the replies food for thought there
I noticed the suggestion of srgb colour space in camera .and monitor that's no problem as monitor has srgb setting ..but doesn't this negate monitor profiling ? or is it still needed? if so will I have to re-profile but using the srgb which wont allow me to set rgb values obviously as you can see im pretty new to colour managing
thanks in advance .. phil
tim
Light Bringer
Oct 01, 2013 00:36 |  #11
The color space of your camera is independent of your monitor color space. Suggest you get yourself a book on color management, there's one in my book thread but you might also want one about printing.
Color's complex.
Lowner
Oct 01, 2013 03:13 |  #12
Sorry if I missed it, but you don't say what paper you use. The ICC profiles need to match the paper or all bets are off. I stick with Epson papers for all my more important prints and use something cheap and cheerful for anything less so.
Richard
Mark ­ Vuleta
Gallery: 48 photos
Oct 01, 2013 03:21 |  #13
notastockpikr wrote in post #16336373 (external link)
No, the greater majority of monitors are at or around sRGB
The monitor profile is quite different to sRGB (which is a colour space, not a device profile). In camera colour space has no bearing if he shoots in raw anyway.
Generally for pro-sumer printers, the canned profiles are pretty close when used with OEM papers. I tend to think the issue here is more of a ink age, print head issue.
iii
tzalman
Fatal attraction.
Oct 01, 2013 05:28 |  #14
Based on my brief research, your printer prints with six colors and will never match the output of your screen regardless of the color management settings.....In addtion, I would use the sRGB color space rather than RGB(1998).
With six colors, most likely CMYK plus light M and light C, I would expect it to exceed sRGB and Adobe RGB (1998) would be the appropriate working space for any image with a wide range of greens and blues, such as landscapes, nature, etc.
In addition to the six colors mentioned above the R2880 adds two shades of grey pigment (light black and light light black). Again, Adobe RGB would be the best working space. The R1900 (which I have) uses either C/M/Y/K-photo or C/M/Y/K-matte plus the addition of red and orange, which extends its gamut significantly in the orange and yellow directions beyond Adobe RGB, as can be seen below, and I would recommend therefore a wider working space like ProPhoto RGB or Chrome 2000 RGB.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/10/1/LQ_663855.jpg
Image hosted by forum (663855) © tzalman [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/10/1/LQ_663856.jpg
Image hosted by forum (663856) © tzalman [SHARE LINK]
Elie / אלי
philbyuk
Gallery: 52 photos
Joined Nov 2005
Oct 01, 2013 08:41 |  #15
Lowner wrote in post #16337536 (external link)
The paper I'm using is Epsom premium glossy
ICC profiles StylusphotoR R390 series360 or SPR360 390 Epson PGPP these came with the Epsom driver install so should work fine
3,940 views & 0 likes for this thread, 7 members have posted to it.
647 guests, 119 members online
