Thread started 30 Sep 2013 (Monday) 11:37
Why does this photo look like this ? Pls help
platforminc
Joined Feb 2012
Sep 30, 2013 11:37 |  #1
I took a shot and just wondered why it appears so dark even in daylight, I tried taking the photo from an angle, this didnt seem to help. Are there any tips for taking pictures in sunlight apart from using the flash.
I just find it weird that in good ambient light, photos still look very dark.
Thanks.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/09/5/LQ_663772.jpg
Image hosted by forum (663772) © platforminc [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/09/5/LQ_663773.jpg
Image hosted by forum (663773) © platforminc [SHARE LINK]
Camera: Canon 500D, f1.8 50mm, kit lens, Tamron 17-50 f2.8 VC, 430EX flash, Remote control,Tripod, Cleaning kit.
sandpiper
Sep 30, 2013 12:12 |  #2
The light is behind your subject, so his face is NOT in sunlight. The camera has metered for the background which IS in bright sunlight so much brighter. You would need to increase exposure (by using +ve EC) to give enough to expose your subjects face correctly. That would however mean that the background is now very overexposed and so will appear very washed out or even blown out in places.
The best way to deal with this is to use fill in flash, where you set the camera to expose for the background and let the flash add enough light to expose the subject correctly. Alternatively, a reflector or piece of white card etc., could be used to bounce some sunlight back into their face (this can make them squint however if the reflector is bright)
Simonwalden
Joined Aug 2013
Sep 30, 2013 15:17 |  #3
Exactly, well put sandpiper
- Simon Walden
FilmPhotoAcademy.com. Photographer, teacher, author
phantelope
Sep 30, 2013 15:23 |  #4
spot meter, fill flash, or exposure compensation or a combo of all of those. Maybe even go up close, spot meter, set that in manual, go back, compose and focus, shoot.
If you have a smart phone, there are also light meter apps that work well, use one of those and then set your camera manually.
40D, 5D3, a bunch of lenses and other things :cool:
KirkS518
Joined Apr 2012
Sep 30, 2013 15:29 |  #5
EXiF says flash fired, so I'm thinking spot metering would have really helped here. (Pattern was used).
If steroids are illegal for athletes, should PS be illegal for models?
Digital - 50D, 20D IR Conv, 9 Lenses from 8mm to 300mm
Analog - Mamiya RB67 Pro-SD, Canon A-1, Nikon F4S, YashicaMat 124G, Rollei 35S, QL17 GIII, Zeiss Ikon Ikoflex 1st Version, and and entire room full of lenses and other stuff
neimad19
Joined Mar 2012
Sep 30, 2013 19:35 |  #6
sandpiper wrote in post #16335825 (external link)
A quick question from a flash newbie; Will the flash (say a 480EX II) automatically tell how hard it needs to fire to properly fill in the shadows of the guy? Or will you have to meter separately for the flash?
Awesome advice btw sandpiper.
sandpiper
Sep 30, 2013 20:06 |  #7
neimad19 wrote in post #16336855 (external link)
If you set the flash to ETTL mode it will work automatically. How it works with balancing the light depends on which mode you have the camera in though. The easiest way to use it for fill flash is to set the camera to Av mode and the camera will meter and expose for the ambient, to give you a correctly exposed background, while the flash will expose the subject correctly. You can manage the amount of fill by adjusting the FEC on the flash, so that the subject doesn't look overflashed. Typically you might turn down the FEC by half or a full stop to lighten the shadows but keep it looking natural.
You can control the balance with the ambient light with the shutter speed, as that will only affect the ambient exposure. The flash exposure is so short that it will give the same exposure for 1/250th as 1/60th, but the ambient exposure will be two stops greater at 1/60th.
If you need a shutter speed, for the ambient light, higher than your synch speed you can set the flash to HSS mode which will fire a sequence of flashes to deal with the fact that the shutter is never fully open but a travelling slit.
neimad19
Joined Mar 2012
Oct 01, 2013 00:30 |  #8
sandpiper wrote in post #16336904 (external link)
Wow. Thanks for the awesome reply! Definitely copying that and saving in a txt doc. for later. I appreciate it! Next step - start saving for the 480...
Damien
PixelMagic
Oct 01, 2013 02:56 |  #9
KirkS518 wrote in post #16336329 (external link)
Its obvious that flash was used in he first photo but not in the second. You can see distinct differences like the dark shadows on the subject's shirt and lack of facial details in the second photo. My guess is that the built-in flash was used and it couldn't provide enough fill light in such a strongly backlit situation.
Qbx
Gallery: 52 photos
Oct 01, 2013 08:03 |  #10
Tough job with dark skin and bright sky. The first one can probably be saved by selectively brightening his face - the second, doubtful. If you want to see some takes on it, turn on image editing in your profile.
-- Image Editing OK --
thedcmule2
Joined Nov 2011
Oct 01, 2013 09:09 |  #11
Or position your subject so the light hits his face and not his back...?
Dan ­ Marchant
Gallery: 19 photos
Joined Oct 2011
Oct 01, 2013 20:51 |  #12
thedcmule2 wrote in post #16338033 (external link)
The problem with that is that, in bright, direct sunlight, the face will look flat and washed out if the sunlight hits straight on and, if it hits from an angle, the strong (referred to as "hard") light will result in bright areas and very dark/strong shadows, which usually look unattractive. In addition, when facing into direct, strong sunlight the subject will often be dazzled and as a result squint.
Dan Marchant
1,685 views & 0 likes for this thread, 10 members have posted to it.
1349 guests, 131 members online
