FORUMS Post Processing, Marketing & Presenting Photos HDR Creation
Thread started 01 Oct 2013 (Tuesday) 11:06
Magic Lantern - Dual ISO readout
kirkt
Oct 01, 2013 11:06 |  #1
This is pretty slick - I am going to try this over the next week or so and see how it works. THe forum write up looks pretty promising. The PDF documentation that is downloadable from the forum starts like this:
Would you trade half of vertical resolution for 3 stops of extra dynamic range?
If you are tempted to answer “yes”, read on.
Pretty intriguing!
Here is the link to the ML Forum post:
http://www.magiclanter​n.fm …ic=7139.msg5968​7#msg59687 (external link)
In essence, ML permits you to set up your exposure so that, for a single click of the shutter release, half of the sensor data is acquired at ISO 1 and the other half acquired at ISO 2. So, for example, you could use ISO 100 and 800 and shoot a scene that will read off half of the sensor at ISO 100 and the other half at ISO 800 (alternate sensor rows - actually alternating every two sensor rows to get the complete RGGB sensel block). This means you are capturing a single image, including motion blur and moving objects with two exposures simultaneously. The tradeoff is half vertical resolution, as the above quote indicates, as well as aliasing in the highlights and shadows, where the skipping of lines is more evident.
I look forward to trying this.
The workflow required to convert your raw image to something useable is provided by additional applications or adaptation of existing open applications (like EXIFTool and dcraw).
Previous extension of DR with ML (especially for video) used alternating ISOs but per frame - that is, capture frame 1 at ISO 1 and frame 2 at ISO 2 and combine these two frames into a single frame and repeat. This leads to some complex frame blending issues that have been pursued and solved in novel ways, thanks to John Hable (GingerHDR). A1ex's dual ISO readout is an equally clever approach that promises even better coping with motion with extended DR.
A1ex never ceases to amaze.
Enjoy!
kirk
Kirk
ejenner
Gallery: 98 photos
Joined Nov 2011
Oct 02, 2013 22:34 |  #2
I've been using this for a couple of months. It's impressive and the software to convert to a .dng has improved significantly to the point where it can be really hard to see any resolution differences. I need to test a bit more for high-res landscapes, but even for that it's looking pretty good.
A recent test. Full image processed as similarly as I could (i.e. I did try to bring out the shadows on both) and 100% crops (unsharpened) with a +1 EC to see the dark details. I don't think I need to tell you which is which.
Looking at this I find it hard to see the loss of resolution and obviously with some sharpening - well one could actually sharpen the DualISO image in the shadows. Just goes to show what the Canon sensors are really capable of.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/10/1/LQ_663997.jpg
Image hosted by forum (663997) © ejenner [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/10/1/LQ_663999.jpg
Image hosted by forum (663999) © ejenner [SHARE LINK]
Edward Jenner
5DIV, M6, GX1 II, Sig15mm FE, 16-35 F4,TS-E 17, TS-E 24, 35 f2 IS, M11-22, M18-150 ,24-105, T45 1.8VC, 70-200 f4 IS, 70-200 2.8 vII, Sig 85 1.4, 100L, 135L, 400DOII.
http://www.flickr.com/​photos/48305795@N03/ (external link)
https://www.facebook.c​om/edward.jenner.372/p​hotos (external link)
kirkt
Oct 03, 2013 11:14 |  #3
In essence, this technique is an in-camera version of the Zero Noise concept we discuss here every once in a while. If you read A1ex's white paper:
http://acoutts.com/a1e​x/dual_iso.pdf (external link)
This technique is very similar to the “zero noise” “technique of the 4 f-stops“ developed by
Guillermo Luijk [6], where he uses only two bracketed images, at 0 and +4 EV, to achieve great
interior shots without the ”radioactive“ HDR look.
This is sufficient to extend dynamic range for about 95% of the shots I take, making time-consuming HDR acquisition even less necessary, with better results. I know that when I was emailing with Guillermo as I was experimenting with Zero Noise, his goal was ultimately to output a DNG instead of a TIFF. Essentially, this is what you get from the ML dual-iso image plus the conversion in the cr2HDR application.
I've been "learning" how to use it, and I am still experimenting with getting the best initial metering for the dual ISO capture.
Cool stuff, thanks for sharing!
kirk
Kirk
tombu
Joined Jan 2013
Oct 03, 2013 11:32 |  #4
If I remember reading correctly, 600D also supports this?
ejenner
Gallery: 98 photos
Joined Nov 2011
Oct 03, 2013 22:34 |  #5
kirkt wrote in post #16343323 (external link)
kirk
Originally, the conversion software didn't seem to work very well if the camera ISO was higher than the DualISO, but the latest version seems to do just about the same. The only difference is the camera calibration I have to use in ACR.
So I usually am shooting for the shadows and I set the DualISO to 100 to preserve highlights as much as possible. This also works with flash. If the subject is in the shadows and you want to set the camera ISO to 100 and use 800 or 1600 in the ML menu, then what I have found to work is just set EC to -3EV. If using a flash I just set the flash EC to -3EV as well +/- whatever I'd normally set. Normally now I just have the ML menu ISO set to 100 though.
For landscape and the above shot example, where I absolutely do not want to clip highlights, then I just use the raw histogram, set ISO100 and make sure the highlights are not clipped. Then set the DualISO to 800 for my 7D or 1600 for the 5DII.
I did have to create camera profiles for both cameras for DualISO and also different ones for the 100/800 and 800/100 combinations.
If you end up doing something different, I'd certainly be interested.
Edward Jenner
kirkt
Oct 04, 2013 08:51 |  #6
The raw histogram is really a huge help. I have pretty much started to home in on a similar approach to yours. I may have time today to take some test shots and see how they come out. I also typically have been using 100-800 or 100-1600 on my 5DII. I have been experimenting with various approaches of converting the processed DNG into an RGB image for editing. Depending upon the DR of the scene, the post-processing is very similar, for obvious reasons, to that I use for Zero Noise images. That is, the processed DNG is scaled so that the image resembles the shot taken at the lowest ISO (highlights preserved, everything else very dark).
As I start to get a better grasp on the workflow and the challenges of using the dual iso images, I'll post back here too.
kirk
Kirk
kirkt
Oct 07, 2013 13:26 |  #7
Here is an example of an image I shot this weekend at a revolutionary war reenactment of the Battle of Germantown, in Philadelphia.
Here is the default rendering of the DualISO DNG, converted using the cr2hdr application - the DNG was rendered in RPP (Raw Photo Processor):
IMAGE: http://kirkt.smugmug.com/Photography/Link-Share/i-ph4NZhZ/0/X3/defaultRPP1024-X3.jpg
Here are a couple of 100% crops.
1) The sniper in the highlight face of the house:
IMAGE: http://kirkt.smugmug.com/Photography/Link-Share/i-XKTxFsG/0/X3/_0002_Sniper_Highlight_%200-X3.jpg
1a) The same crop, pushed 4 stops using the exposure tool in Photoshop
IMAGE: http://kirkt.smugmug.com/Photography/Link-Share/i-cbJfmnp/0/X3/_0003_Sniper_Highlight_%204-X3.jpg
2) The sniper on the shadow side of the house:
IMAGE: http://kirkt.smugmug.com/Photography/Link-Share/i-6ppN3tg/0/X3/_0000_Sniper_Shadow_%200-X3.jpg
2a) The same crop, pushed 4 stops:
IMAGE: http://kirkt.smugmug.com/Photography/Link-Share/i-d27ZrP4/0/X3/_0001_Sniper_Shadow_%204-X3.jpg
These give you an idea of the dynamic range that is useable in this kind of scene. Note in 2a that there is acceptable observable noise in the crop, even in the deep shadows within the house. Note: RPP has no noise reduction (other than hot pixels).
This is pretty promising.
Here is a quick edit of another scene shot the same day. This scene contains the foreground actors in shade, marching actors in the background in bright sun (along with the flagpole and green foliage) and the dynamic element of the canon smoke and moving subjects - a potential HDR ghosting nightmare.
RPP default
IMAGE: http://kirkt.smugmug.com/Photography/Link-Share/i-kbHvbLL/0/X3/_MG_0183-1024RPP-X3.jpg
Compressed edit:
IMAGE: http://kirkt.smugmug.com/Photography/Link-Share/i-v76vNML/0/X3/_MG_0183-X3.jpg
Here is the cr2hdr output data log (I shot at ISO 100 + 1600):
Input file : _MG_0183.CR2
Canon EOS 5D Mark II detected
Full size : 5792 x 3804
Active area : 5634 x 3753
White level : 12500
Black borders : 158 left, 51 top
Black level : 972
ISO pattern : BddB GBRG
Noise levels : 13.57 9.03 9.37 12.44 (14-bit)
Estimating ISO difference...
ISO difference : 4.21 EV (1845)
Black delta : -9.86
Interpolation : mean23-chroma5x5-alias
Dynamic range : 10.32 (+) 9.73 => 13.94 EV (in theory)
Matching brightness...
Looking for hot/cold pixels...
Hot pixels : 23
Full-res reconstruction...
ISO overlap : 3.1 EV (approx)
Half-res blending...
Chroma filtering...
Building alias map...
Filtering alias map...
Smoothing alias map...
Noise level : 2.96 (16-bit), ideally 2.51
Dynamic range : 13.93 EV (cooked)
Black adjust : -4
Output file : _MG_0183.DNG
14EV of DR - that seems pretty good, because if you play your exposure and image editing cards right, that's about the observable DR for the human visual system.
The edit is meant to be a little over the top in terms of tonal range compression (note how the compression killed the detail in the canon smoke, for example) - I would probably edit this normally to let some of the background blow out - however, the idea was to demonstrate the useable DR of these dualISO images.
I also shot some moving car images and will post those edits when I get a chance. I also want to find some static test scenes where I can shoot with and without the DualISO hack and compare the results in terms of usable DR and noise.
kirk
Kirk
kirkt
Oct 07, 2013 14:17 |  #8
Here is a static example - I will go back and reshoot this scene when there is sun, and I will shoot it with and without the DualISO setup.
default rendering in RPP and a +4 exposure rendering in RPP. I find it better to demonstrate the 4 stop push with the precision of RPP compared to PS. Overall image and 100% crops ( I rendered at 1/2 res in RPP, so these are 50% crops, really).
cr2hdr log:
Input file : _MG_0081.CR2
White level : 15258
Black level : 978
Noise levels : 8.94 6.96 7.27 8.64 (14-bit)
ISO difference : 3.17 EV (898)
Black delta : 9.30
Dynamic range : 11.00 (+) 10.64 => 13.81 EV (in theory)
Hot pixels : 396
ISO overlap : 4.8 EV (approx)
Chroma filtering...
Noise level : 3.16 (16-bit), ideally 3.14
Dynamic range : 14.14 EV (cooked)
Black adjust : -3
Output file : _MG_0081.DNG
Default RPP - 0EV exposure
IMAGE: http://kirkt.smugmug.com/Photography/Link-Share/i-6h7h54J/0/X3/_MG_0081-0EV-X3.jpg
+4EV push RPP rendering
IMAGE: http://kirkt.smugmug.com/Photography/Link-Share/i-jV7ZFWz/0/X3/_MG_0081%204EV-X3.jpg
100% crop comparison
IMAGE: http://kirkt.smugmug.com/Photography/Link-Share/i-zdc9Sd4/0/X3/_MG_0081-0%204EVcompare-X3.jpg
Kirk
kirkt
Oct 07, 2013 14:30 |  #9
Here is an example with a moving element. Same idea, original 0EV rendering from RPP, then +4EV. For the 100% crops i rendered at full res from RPP this time, so they are full res 100% crops.
cr2hdr log:
Input file : _MG_0093.CR2
White level : 15257
Black level : 973
Noise levels : 14.04 9.55 10.12 13.17 (14-bit)
ISO difference : 4.21 EV (1850)
Black delta : -9.47
Dynamic range : 10.55 (+) 9.99 => 14.20 EV (in theory)
Hot pixels : 50
ISO overlap : 3.3 EV (approx)
Chroma filtering...
Noise level : 4.89 (16-bit), ideally 2.61
Dynamic range : 13.51 EV (cooked)
Black adjust : -3
Output file : _MG_0093.DNG
kirk
IMAGE: http://kirkt.smugmug.com/Photography/Link-Share/i-LwT9RWw/0/X3/_MG_0093-0EV-X3.jpg
IMAGE: http://kirkt.smugmug.com/Photography/Link-Share/i-ZZpLV7d/0/X3/_MG_0093%204EV-X3.jpg
IMAGE: http://kirkt.smugmug.com/Photography/Link-Share/i-d6St2Vt/0/X3/_MG_00930EV%204EVComparison-X3.jpg
Kirk
kirkt
Oct 07, 2013 14:33 |  #10
Pretty much like Zero Noise only done in your camera all at the same exact instant in time.
Totally bad ass.
kirk
Kirk
kirkt
Oct 07, 2013 14:44 |  #11
A panning example! At full res in the deep shadows, when boosted, you can see the artifact of the line pairs. Not a biggie. At half res, they are gone.
cr2hdr log:
Input file : _MG_0059.CR2
White level : 15257
Black level : 972
Noise levels : 13.91 10.05 10.43 13.02 (14-bit)
ISO difference : 4.22 EV (1859)
Black delta : -7.10
Dynamic range : 10.47 (+) 10.00 => 14.22 EV (in theory)
Hot pixels : 26
Chroma filtering...
Noise level : 7.37 (16-bit), ideally 2.58
Dynamic range : 12.92 EV (cooked)
Black adjust : -4
Output file : _MG_0059.DNG
IMAGE: http://kirkt.smugmug.com/Photography/Link-Share/i-BntZ5RQ/0/X3/_MG_0059-0EV-X3.jpg
IMAGE: http://kirkt.smugmug.com/Photography/Link-Share/i-RMRddsk/0/X3/_MG_0059%204EV-X3.jpg
IMAGE: http://kirkt.smugmug.com/Photography/Link-Share/i-8fN5ZRn/0/X3/_MG_0059comparison-X3.jpg
Kirk
kirkt
Oct 07, 2013 15:09 |  #12
Another example - indoor-outdoor scene. RPP rendering at half res.
kirk
cr2hdr log:
Input file : _UAL0034.CR2
White level : 15259
Black level : 972
Noise levels : 10.71 5.94 6.01 10.49 (14-bit)
ISO difference : 3.20 EV (918)
Black delta : 25.09
Dynamic range : 11.23 (+) 10.38 => 13.58 EV (in theory)
Hot pixels : 111
Cold pixels : 17347
ISO overlap : 5.0 EV (approx)
Chroma filtering...
Noise level : 3.76 (16-bit), ideally 3.76
Dynamic range : 13.89 EV (cooked)
Black adjust : -5
Output file : _UAL0034.DNG
IMAGE: http://kirkt.smugmug.com/Photography/Link-Share/i-gtG8SZm/0/X3/_UAL0034-0EV-X3.jpg
IMAGE: http://kirkt.smugmug.com/Photography/Link-Share/i-r4CP8Qd/0/X3/_UAL0034%204EV-X3.jpg
IMAGE: http://kirkt.smugmug.com/Photography/Link-Share/i-smjs4Ck/0/X3/_UAL0034comparison-X3.jpg
Kirk
tzalman
Fatal attraction.
Oct 08, 2013 16:42 |  #13
A side note that might be of interest to some for whom file size is a consideration. The dng file, apparently because it is 16 bit, is somewhat larger than the original CR2. 42 MB rather than the 22-30 MB of the CR2 (5D2). In LR (and I imagine in PSCS) the dng can be exported as a new dng - presumably with no loss of data - which is 25 MB. It may be that LR-produced dngs are more compressed than those from CR2hdr. There is also the option to export it as a lossy dng which would reduce file size further.
P.S. That CR2hdr does already do considerable compression may be judged from the fact that the size of an uncompressed 5D2 16 bit file would be 120 MB.
Edit: (Oct, 12) Dumb mistake. I forgot that the dng is greyscale and therefore would be 40 MB, so the CR2hdr output is uncompressed.
Elie / אלי
kirkt
Oct 11, 2013 13:44 |  #14
Here is a difficult scene to capture -perfect for a comparison between the ML dual ISO result and a standard raw capture!
Methods:
I used Raw Photo Processor (RPP) to perform the conversion of the DNG file generated from the ML data as well as the 5DII raw file of the scene. Both shots were acquired at the same exposure and WB settings and no NR was used other than the very limited RPP tools (remove hot pixels, blur chroma).
It is overcast and raining here, outside of Philadelphia - it has been for two days. This is a scene that may typically be approached with HDR imaging techniques. Outside there is a bright (not bright direct sunlight, but bright) scene, with an interior scene lit by a window. I shot this scene so that the manikin head was essentially backlit - the black desktop bounces very little fill into the face, but the white pad of paper to the right of the face does provide a somewhat concentrated bounce fill.
The goal of my rendering and edit:
I am sitting at my desk trying to match, visually, what I see in the real scene versus what my edit is portraying.
As I perform very basic edits, I am applying the edits to both images identically. This may not be the best strategy in real life, as you often have to use different edits to get the most out of an image, but in this exercise I think it is fair and will permit comparison of the two images.
I will not go into detail as to how I edited - I rendered a conservative TIFF from RPP:
IMAGE: http://kirkt.smugmug.com/Photography/Link-Share/i-mQP2Rrn/0/X3/_MG_0001-RPPTIFF-X3.jpg
Then I edited this in Photoshop to achieve the following images:
Raw edit:
IMAGE: http://kirkt.smugmug.com/Photography/Link-Share/i-NHzdBrj/0/X3/_MG_0009-X3.jpg
ML Dual ISO edit:
IMAGE: http://kirkt.smugmug.com/Photography/Link-Share/i-rP2zcsL/0/X3/_MG_0001-X3.jpg
[OOOPS - looks like i output sharpened the ML dual ISO edit twice - sorry about that]. Continued in next post....
Kirk
kirkt
Oct 11, 2013 13:48 |  #15
Here is a composite screenshot of each of the two images in RPP, both boosted in exposure 4 stops.
IMAGE: http://kirkt.smugmug.com/Photography/Link-Share/i-4wQJKsn/0/X3/comp-X3.jpg
Inspecting the above images as well as the composite, and concentrating on the backlit face, it is pretty apparent that the raw file starts to fall apart. In situations like this, where you have a lot of dynamic range to deal with, you need to simultaneously decrease global contrast and make up for it by increasing or reestablishing local contrast. When you mess with local contrast, color often desaturates and suffers. Thus, to deal with such DR, you need good data with which to start.
Here is the cr2hdr log for the ML dual ISO DNG:
Input file : _MG_0001.CR2
White level : 12500
Black level : 974
Noise levels : 12.75 9.05 9.22 12.13 (14-bit)
ISO difference : 3.18 EV (904)
Black delta : -9.59
Dynamic range : 10.31 (+) 9.82 => 13.00 EV (in theory)
Hot pixels : 16
Cold pixels : 1
ISO overlap : 4.1 EV (approx)
Chroma filtering...
Noise level : 5.08 (16-bit), ideally 4.86
Dynamic range : 13.15 EV (cooked)
Black adjust : -7
Output file : _MG_0001.DNG
About 13EV of dynamic range from a 5DII - not bad. More importantly, as this exercise demonstrates, this is USEABLE dynamic range. And, to emphasize, no noise reduction was performed on the data - you could probably squeeze a little more out of the data if you added some light NR. In addition to noise as a visual distraction, noise also affects tonal gradations and color. No duh, right? Well it is worth repeating, because not only do you get better looking images with this approach, tolerant to more post production, but you also get better color and fewer tonal artifacts.
Even if you did not want to boost the image as much, the shadow tones will not have an awful tint that you will have to fix in post like the noisy shadows in a single raw capture.
Pretty awesome.
kirk
Kirk
109,371 views & 2 likes for this thread, 29 members have posted to it and it is followed by 12 members.
1454 guests, 131 members online
