deanbayley wrote in post #16342795
When you say 1,000w are you talking about 4x 250w? or 4x1,000w?
Any particular models to look for?
I bought some nice used Dynalite stuff. The strobes themselves are fan cooled heads and they require a power pack to provide the energy to fire them off. The pack is a 4 port 1,000 watt unit which is where the number above came from.
The heads are actually 1,000 and 2,000 watts by spec, IIRC.
On my kit the pack has two zones and adjustments to let me fire off the heads at fractions of full power (1/8, 1/4, 1/2, etc.) in each zone.
I can also control the 250w modeling lights the same way.
Many folks prefer monolights which integrate the power supply into each individual light. The ones you linked to above were that type.
There are, of course, advantages and disadvantages to each type.
All told you probably won't ever need more than 800w to light the space you've got and, for most shoots, you'll probably need a lot less. I use my pack at 1/4 power most of the time. The key, though, is to get sufficient lighting in the right spots which is why you'll probably want at least 3 sources.
Folks do, however, do really great work with single strobe setups so it's going to be about what you want your shots to look like, what you can afford, etc.
BTW, I bought the Dynalite stuff because I tend to be the kind of person who would rather have a used Mercedes than a new Kia. YMMV.
