Thread started 03 Oct 2013 (Thursday) 07:28
Focus stacking less than perfect results - blurry splotches
JonK
Joined Feb 2004
Oct 03, 2013 07:28 |  #1
Hey guys - doing focus stacks for some product photos and I usually get good results. I use a Canon 5DII w/ 100 2.8L Macro for nearly ALL of my product photos as I find it gives a true or more accurate representation of angles and lets me work in almost any sized room, generally.
If I have a unit that is about 6" deep or so I will stack maybe 5 - 6 photos from about a 3 - 4' focal length (I try and put the subject in center of the frame with about 10 - 20% of the view finder of space on top and bottom, if that makes sense). If I have a unit that is much larger, like 20 - 24" deep, I'll shoot maybe 15 - 18 stacked shots but am usually further back, so DOF is a little better. I always shoot f/8.
Every now and then, though, I get lousy results. Most of the time I get great results. I find when a subject has a large surface with little variation is when I have issues. For instance, see the images below -
Here is a good one:
IMAGE: http://farm8.staticflickr.com/7442/10068293793_75c46c41e6_c.jpg
IMAGE LINK: http://www.flickr.com …67031861@N08/10​068293793/  (external link)
Stack_Good (external link) by Jon Kensy (external link), on Flickr
Everything is sharp, in focus, stacked nicely, no weirdness.
Here is a poor one:
IMAGE: http://farm4.staticflickr.com/3788/10068159494_7bf3f542e8_c.jpg
IMAGE LINK: http://www.flickr.com …67031861@N08/10​068159494/  (external link)
Stack_Poor (external link) by Jon Kensy (external link), on Flickr
Zoomed in for better detail:
IMAGE: http://farm3.staticflickr.com/2833/10068246756_86b71f623b_c.jpg
IMAGE LINK: http://www.flickr.com …67031861@N08/10​068246756/  (external link)
Stack_Poor2 (external link) by Jon Kensy (external link), on Flickr
So - what's up? Can PS CS5/CS6 just not do a great job on larger flat/less distinct areas? Or am I just asking too much? I am finding I have to go throw my "rear focused layer" back in and selectively erase which is extremely time consuming as I also have to align it. Any suggestions?
Obviously the super blurred parts are intentional.
7NE | 7D | 5DII | 16-35/2.8L II | 24/1.4L II | TS-E 24/3.5L II | 50/1.4 | 85/1.2L II | 100/2.8L IS | 70-200/2.8L IS II | 400/5.6L | PIXMA Pro 9500 Mark II
check my blog:
www.jonkensy.com (external link)
armis
Joined Jan 2012
Oct 03, 2013 08:21 |  #2
Well I can see how it would be hard for software to decide, for smooth surfaces with no edges or contrast, whether a given point is in focus or not. I don't have a solution for your problem; I would suggest doing it manually. CS6 allow you to load multiple images and automatically align them, which would probably help you quite a bit (you can either go to file > script > load as stack, or manually load the images in layers then select them all and go to Layers > Auto-align).
Fuji X-T4, 18-55 and 55-200 zooms, Samyang 12
www.wtbphoto.com (external link)
852 views & 0 likes for this thread, 2 members have posted to it.
1053 guests, 104 members online
