Thread started 04 Oct 2013 (Friday) 11:05
Lens shadow
mtnsldr@gmail.com
Joined May 2013
Oct 04, 2013 11:05 |  #1
First let me say, thank you for taking the time to look at my thread. I have been a lurker up to this point in this forum and have learned a lot so thank you again for that.
Attached is a photo I took while trying some HDR real estate photography recently and I keep getting this shadow when I use my off camera flash. Anyone know how to get rid of this annoying shadow? This only happens when I use my canon 10-22 lens, my other lenses don't do this.
Camera: Rebel xti (sorry thats all I can afford)
lens: Canon 10-22 wide angle with UV filter to protect glass
setting: f/8, 10mm, av setting, 400ISO.
flash is off camera, just to the side and behind me, with shoot through umbrella.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/10/1/LQ_664125.jpg
Image hosted by forum (664125) © mtnsldr@gmail.com [SHARE LINK]
amerituner
Joined Jun 2013
Oct 04, 2013 11:24 |  #2
First your camera is a lot better than what others may be able to afford. Have you tried setting the flash just in front of you to the side? I would imagine any light behind you is going to cast a shadow in front of you. Also how does the lens behave without off camera flash?
Canon T5, Canon 40D, Canon 24-105L, Canon 10-18
Canon Nifty 50, Tamron 70-200 F2.8, Tamron 150-600 G2
You can edit my photos, haven't found the setting to tell you that yet :)
tmoore323
Oct 04, 2013 12:27 |  #3
1. take the filter off, 2. bounce the flash from the ceiling - this looks straight on, 3. what is your shutter speed?, 4 You say your trying to do hdr, are you doing FEC?
mtnsldr@gmail.com
Joined May 2013
Oct 04, 2013 15:41 |  #4
amerituner wrote in post #16345777 (external link)
I have tried moving the flash around, to the side, more to the side, in front about the camera, right next to me, etc.
It does not do this with my 18-55 lens, just the wide angle?
flowrider
Gallery: 127 photos
Oct 04, 2013 15:45 |  #5
The shadow is from the light being behind the camera. An umbrella throws a lot of light in many different directions and if it behind camera at all it will cause a shadow. It could also be that your umbrella is not very efficient and light is being reflected off a wall behind you and forward again with a shoot through.
~Steve~
~ My Website-stevelowephoto.com (external link) ~ Facebook (external link)
Feedback Feedback Feedback
mtnsldr@gmail.com
Joined May 2013
Oct 04, 2013 15:48 |  #6
tmoore323 wrote in post #16345929 (external link)
Camera is set to AV and automatically adjusts the shutter speed. I think photo it was at 1/60.
I have tried the bouncing method however I don't get as much light and I am trying to get as much like onto the subject to get the realistic colors to pop out and lighten the room as well as help make the room lighter and not so dark.
Not sure what you mean by FEC?
NeutronBoy
Oct 04, 2013 20:56 |  #7
look it up in the user manual = flash exposure compensation.
I think the shadow is YOU!
Sony A7C, Sony A6000, 5D Mark II, 40D, 350d
Canon 70-200 f2.8 IS II L | Canon 100-400 IS L [COLOR=black]| Canon 24-70 L | Canon 100mm Macro f2.8 | Canon 50 f1.4| Canon 10-22 | Canon MP-E 65 | Rokinon 14mm f2.8 | Sigma 17 - 70 macro
MT-24 & 430 flashes | other junk
mtnsldr@gmail.com
Joined May 2013
Oct 05, 2013 11:33 |  #8
NeutronBoy wrote in post #16346973 (external link)
Great minds think a like, and I thought the same thing, so I moved the flash stand around (further to the side, in front of the camera, aimed higher, and lower). The out come was the same. Like I said my 18-55 lens does not have this shadow.
Qbx
Gallery: 52 photos
Oct 05, 2013 18:42 |  #9
If you are using two flashes, off camera and on camera, then the shadow is probably from the on-camera flash hitting the lens. Make sure your pop-up flash is not firing or cover it with some tape. If as you say the shadow remains when you move the off-camera flash to the side (and the shadow does not move) then there is something obstructing the lower part of your lens, otherwise the shadow would move opposite the flash. If the shadow does move when you move the flash, then move the flash higher and see if that helps.
-- Image Editing OK --
tmoore323
Oct 05, 2013 18:48 |  #10
mtnsldr@gmail.com wrote in post #16346353 (external link)
Try manual, or TV (Shutter priority) to your camera's sync speed. Probably 1/200 or 1/250.
Again, how are you trying HDR, if you don't understand FEC?
Take that filter, throw it in the trash.
KirkS518
Joined Apr 2012
Oct 05, 2013 21:41 |  #11
In the posted photo, looks like there is a mirror behind you (mirror in the mirror visible). My guess is the mirror behind you is bouncing the flash, and causing your shadow to be captured. It won't matter whee the light is positioned, it will always bounce that light back out. Take the second mirror down, or cover it with a sheet, then try again.
If steroids are illegal for athletes, should PS be illegal for models?
Digital - 50D, 20D IR Conv, 9 Lenses from 8mm to 300mm
Analog - Mamiya RB67 Pro-SD, Canon A-1, Nikon F4S, YashicaMat 124G, Rollei 35S, QL17 GIII, Zeiss Ikon Ikoflex 1st Version, and and entire room full of lenses and other stuff
mtnsldr@gmail.com
Joined May 2013
Oct 06, 2013 00:22 as a reply to  @ KirkS518's post |  #12
All great information here, and it is all appreciated very much.
Let me see if I can address the last couple questions.
I am doing HDR buy setting my camera to AV, F/8 and taking 3-5 shots changing the exposure with each shot.
Can't be the mirror as it does this in many different rooms and houses.
I am using the pop up flash to trigger my flash (Youngnuo 560 III) as a off camera slave.
I have become familiar with EFC, and I am manually adjusting the flash no TTL.
Qbx
Gallery: 52 photos
Oct 06, 2013 07:39 |  #13
mtnsldr@gmail.com wrote in post #16349235 (external link)
Please read my post. There's your problem.
edit: Solution is to put a bit of aluminum foil in front of your popup so the light is directed upward or backward not forward toward the lens. It still should trigger your slave.
mtnsldr@gmail.com
Joined May 2013
Oct 06, 2013 10:24 |  #14
Qbx wrote in post #16349624 (external link)
We have a winner, the shadow is from the pop up flash and the larger diameter lens.
However, this brings up another question, why is my larger flash not killing this shadow? If the flashes are truely firing at the same time shouldn't the off camera flash over power the small pop up?
Thanks guys, this is exactly why this forum is great.
Qbx
Gallery: 52 photos
Oct 07, 2013 06:36 |  #15
Simple answer is no - the off camera flash will never completely overpower the popup; the shadow will always be there by varying degrees depending on flash power and location of the slave and power setting of the popup. Try the foil or some other redirecting mechanism and let us know how it works out.
3,364 views & 0 likes for this thread, 9 members have posted to it.
Lens shadow
1244 guests, 121 members online
