Thread started 04 Oct 2013 (Friday) 17:22
Fast shutter speeds and IS improvements
davidfarina
Gallery: 43 photos
Joined May 2013
Oct 04, 2013 17:22 |  #1
Silly question by the way:
I bought the 70-300L and the IS works amazingly so i get usable shots even at 1/30s at 300mm. However, i was thinking about daytime shoting, will IS improve my shots even if used at something like 1/250s or even faste? I guess the improvement will be less visible as at shorter times less movement is possible, but will i get the last tick of sharpness out of it while using like i said something like 1/250s at 300m?
Sony A7RII | Sony A7S
EF 40 | EF 70-300L | FD 35 Tilt-Shift
FE 16-35 | FE 28 | FE 90
CV 15 4.5 III | CV 40 1.4 MC | Summilux 50 ASPH
Website (external link) | 500px (external link)
JeffreyG
Gallery: 42 photos
Oct 04, 2013 17:25 |  #2
Depending on how shaky you are, you might see some improvement in very large prints up to somewhere around 1/ (2 X focal length). So around 1/640 for a 300mm lens.
Above that and I can only imagine much help for someone with a health issue that is making for extreme shake.
ed ­ rader
"I am not the final word"
Oct 04, 2013 17:27 |  #3
davidfarina wrote in post #16346575 (external link)
1/250s isn't that fast for 300mm especially if you are shooting a cropper. so yeah IS will definitely help with sharpness. with IS you can shoot razor sharp landscapes even in low light without a tripod.
5D4 x2, 16-35L F4 IS, 24-70L II, 70-200L F4 IS II, 100-400L II, 14L II, sigma 15 FE, sigma 28 f1.4 art, tc 1.4 III, 430exII, gitzo 3542L + markins Q20, gitzo GT 1545T + markins Q3T, gitzo GM4562
Tapeman
Sliced Bread
Joined Jan 2004
Oct 04, 2013 17:28 |  #4
Your keeper rate should be higher if you use higher shutter speeds than 1/30s. One advantage of IS is that the image in your viewfinder will be steadier.
Canon G1X II, 1D MKIV, 5DSR, 5DIV, 5D MKII, 16-35/2.8L II, 24-70/2.8L II, 70-200/2.8L IS II, IS, 100-400/4.5-5.6 L IS II, 500/4 L IS II, 24-105/4 IS, 50/2.5 macro, 1.4x MKII, 1.4X MKIII, 2X MKIII,580EX II, 550EXs(2), ST-E2.
Gitzo 1228, 1275, 1558, Lensbaby 3G. Epson 3880, Bags that match my shoes.:)
sandpiper
Oct 04, 2013 17:48 as a reply to  @ Tapeman's post |  #5
Although the IS will be of little importance for camera shake, once you get past about 1/600th, it does still help as it steadies the viewfinder and makes it easier to keep your AF point exactly where you want it. that isn't always an isue, but sometimes a slight movement of the camera can move it off target enough to spoil the shot. When shooting birds for example, I want my AF point right on the eye at all times, with small birds it takes very little camera movement sometimes to slip off the eye and onto a twig behind the head.
The best thing is to just play with your setup and see when and how you are finding an improvement with IS and at what speeds and in what situations you feel better off without it. A lot depends on your personal shooting techniques and habits.
Personally, I rarely turn IS off, even when using fast shutter speeds. I would only do so if tracking an unpredictable target which can suddenly change direction, as that can cause the IS to fight the panning as you adjust your movement. But, that's me. Others may turn it off more than I do, some never turn it off. Experiment to see what works for you.
davidfarina
Gallery: 43 photos
Joined May 2013
Oct 04, 2013 18:04 |  #6
Allright. I was a bit questioning this things as its not recommended to let the IS on when on tripod, so fast shutter speeds + IS seems useless for more sharpness lets say at 1/2000s but a steady viefinder is definitely a plus and since newer IS should detect tripod its just a question which was flying in my head as i never really used IS efficiently.
Thanks guys!
hollis_f
Oct 05, 2013 04:50 |  #7
sandpiper wrote in post #16346630 (external link)
I've always suspected that having a stabilised image on the AF sensor can only help with AF accuracy. But I may be totally wrong.
Frank Hollis - Retired mass spectroscopist
Give a man a fish and he'll eat for a day. Teach a man to fish and he'll complain about the withdrawal of his free fish entitlement.
Gear Website (external link)
ed ­ rader
Oct 05, 2013 11:24 |  #8
davidfarina wrote in post #16346663 (external link)
Thanks guys!
I put gaffer tape over my IS lenses' buttons so I can't accidentally turn off IS or AF. so I "always" leave IS on.
the only exception is when i'm doing long exposures -- say over five seconds. I have had some weird results in long exposures that I think occurred because of tripod vibration and IS.
davidfarina
Gallery: 43 photos
Joined May 2013
Oct 05, 2013 13:57 |  #9
ed rader wrote in post #16348009 (external link)
Well the buttons on the 70-300 L are very nice built id say its almost impossible to accidentaly tutn it off with that lens. So leaving it on is better thanks for responses and yeah, for tripod shots i wont use it. I mean its even unnessecaury
ed ­ rader
Oct 05, 2013 15:11 |  #10
davidfarina wrote in post #16348297 (external link)
I managed to do it and blew all my whistle pig shots in june. I returned to Mormon Row a few days ago and and the WPs are hibernating. turning the switch off and on doesn't work for me. it's like me using my seat belt only when I think I need it. thus I have taped mine into the on position as a default. if i'm doing long night exposures the tape comes off.
davidfarina
Gallery: 43 photos
Joined May 2013
Oct 05, 2013 18:09 |  #11
ed rader wrote in post #16348419 (external link)
Well i have a similiar problem with my 6D. The 6D can only shoot in-built HDR when turning Raw Image data off. This resulted in a few Images which are now saved as ONLY jpeg. I know the problem might be the same you want to say in a case where i forget to turn on IS...
ed ­ rader
Oct 05, 2013 20:25 |  #12
davidfarina wrote in post #16348703 (external link)
some guys are better at micromanaging the little things but some of us just have to K.I.S.S. ;).
davidfarina
Gallery: 43 photos
Joined May 2013
Oct 06, 2013 06:37 |  #13
ed rader wrote in post #16348909 (external link)
Hahaha yeah, or maybe train the memory :)
1,801 views & 0 likes for this thread, 6 members have posted to it.
1605 guests, 142 members online
