Having used the 50mm on the 6D a few times now without a hitch I switched back to use the lens again earlier on, and now see the Err 01
The camera to lens communication is somehow being interfered with… could be a problem within the lens itself, possibly the camera body, or something as simple as a smudged fingerprint on the lens mount contacts.
If I pop the lens on the 7D body all is fine, I can shoot without a problem. All other lenses work fine too
So I've given the contacts on the lens, and camera body a wipe to no avail. What would you suggest the next step was? Should I look inside the lens at the other end of the contact points?
