Thread started 07 Oct 2013 (Monday) 07:52
Misbehaving 5d2 battery
uOpt
Oct 07, 2013 07:52 |  #1
Any cure for this?
One of my (original Canon) 5d2 batteries has started a habit of suddenly going dead, usually in the middle of live view with the mirror open.
It then only wants a couple minutes charge, or so it tells the charger, but the next morning you can charge it all day long before full. Then it pretends to work until the circle completes.
My imagine composition sucks. I need a heavier lens.
amirshakoor
Oct 07, 2013 08:02 |  #2
If it's over a year old you may need to buy a new one :(
[R3 | R5 | 135 f1.8L | 15-35 f2.8L | 28-70 f2L | 70-200 f2.8L | 100 f2.8L Macro | Speedlite EL-1 | Detailed Gear and Feedback...]
amirshakoor
Oct 07, 2013 08:05 |  #3
Let me add to that: most lithium ion batteries ago dead after 1 year, maybe two. Some will last for 3 years if you are lucky. Camera batteries are no exception, it's just the nature of the beast. Luckily the 5D2 batteries are still manufactured and still readily available (and they will be for a long time). You may want to get a chipped 3rd party battery if you don't want to pay Canon the outrageous cost for a new one.
Aswald
Joined Oct 2013
Oct 07, 2013 08:13 |  #4
uOpt wrote in post #16352236 (external link)
Any cure for this?
Is it an original battery or 3rd party?
How old is your battery?
What's the usage like?
Does it see continuous use or more storage than use?
How do you store the battery, for how long and do you store it fully charged?
How do you normally charge your battery?
All these things will affect battery performance and life. Under normal use and maintainance, all Li-ion batteries should last 2-3 years.
Depending on your answers above, you may be able to rescue your battery.
uOpt
Oct 07, 2013 08:19 |  #5
It's one out of 3 of my original Canon batteries. I don't think it had other use and storage than my other batteries and if so - less. Couple years old, maybe 3.
It's not a case of bad recharge performance. It suddenly goes from 90+% full to so dead it can't close the mirror.
Aswald
Joined Oct 2013
Oct 07, 2013 08:25 |  #6
Try to recalibrate your battery. You need to slowly discharge your Li-ion until it reads 0v (when the protection circuitry kicks in and cuts off the internal circuit). The reserve voltage is still about 6.5volts. Then use the canon charger and charge it to full again. In some cases, you may need to repeat twice.
I've been using my originals and 3rd party since 2008 and it still works almost 90% capacity.
amirshakoor
Oct 07, 2013 08:33 |  #7
Aswald wrote in post #16352320 (external link)
...You need to slowly discharge your Li-ion until it reads 0v...
How is this done? Normal camera usage, live view, etc?
Aswald
Joined Oct 2013
Oct 07, 2013 09:00 |  #8
amirshakoor wrote in post #16352345 (external link)
When the 5Dmk2 reads min battery left, the actual voltage left in the battery is still about 7volts. You need to take the battery out and discharge it like how is described in my previous post.
I was surprised how much energy the LP-E6 can actually store! I've done recalibration on original Canon LP-E6, BP-511, NB-2HL. Also performed recalibration on the Wasabi 3rd party, same models with good results.
nekrosoft13
Gallery: 185 photos
Joined Jun 2010
Oct 07, 2013 09:03 |  #9
uOpt wrote in post #16352304 (external link)
When you buy a camera it doesn't come with 3 batteries. so the question is were did you get it?
Places like Amazon, and ever Newegg, was selling counterfeit batteries before, they can look like original.
plus 3 years, depending on use, could simply be end of life for that battery.
Lowner
"I'm the original idiot"
Oct 07, 2013 09:34 |  #10
If you are in the habit of recharging batteries before they are really flat, some will remember this and expect it all the time. Do try not to recharge until the battery in question is truly flat.
Richard
PitaDaVespa
Oct 07, 2013 12:17 |  #11
Sometimes I use my camera with one charged battery in the grip and one uncharged, until both go flat, to ensure the uncharged one gets totally flat. Then I repeat the process, swaping battery roles.
1,577 views & 0 likes for this thread, 6 members have posted to it.
Latest registered member is EBiffany
1597 guests, 95 members online
