Thread started 29 Jan 2006 (Sunday) 15:54
Are all DVD-Rs the same format?
Tapeman
Sliced Bread
Joined Jan 2004
Jan 29, 2006 15:54 |  #1
I tried to do a back-up of my pics on a "100 year archival" DVD and get the error message "this disc not formatted for this drive"
I thought all DVD-Rs were the same. Is this correct?
Canon G1X II, 1D MKIV, 5DSR, 5DIV, 5D MKII, 16-35/2.8L II, 24-70/2.8L II, 70-200/2.8L IS II, IS, 100-400/4.5-5.6 L IS II, 500/4 L IS II, 24-105/4 IS, 50/2.5 macro, 1.4x MKII, 1.4X MKIII, 2X MKIII,580EX II, 550EXs(2), ST-E2.
Gitzo 1228, 1275, 1558, Lensbaby 3G. Epson 3880, Bags that match my shoes.:)
Robert_Lay
Jan 29, 2006 16:00 |  #2
There are many different problems possible here.
Non-re-writable DVDs come in at least 3 forms, DVD-R, DVD+R and DVD RAM.
My burners are generally sensitive to whether they like -R or +R.
Then we have the issue of re-writable blanks, DVD-RW and DVD+RW.
If you are trying to write to a DVD-R when you are using the software that writes to DVD-RW, then naturally it will refuse.
Not really 100% sure of which of these problem areas you are falling under.
Bob
Quality of Light (external link), Photo Tool ver 2.0 (external link)
Canon Rebel XTi; EF-S 10-22mm f/3.5-f/5.6 USM; EF-S 18-55 mm f/3.5-f/5.6; EF 28-135mm f/3.5-5.6 IS USM; EF 50mm f/1.4 USM; Canon Powershot G5; Canon AE1(2); Leica R4s; Battery Grip BG-E3; Pentax Digital Spotmeter with Zone VI Mod & Calibration.
Tapeman
Sliced Bread
Joined Jan 2004
Jan 29, 2006 16:10 as a reply to  @ Robert_Lay's post |  #3
So it is not a hardware problem, it's the program that I am trying to use?
snappa
Joined Jun 2005
Jan 29, 2006 17:15 |  #4
I may be wrong but feel certain that DVD RAM is a re-writable disc.
www.pbase.com/snapz (external link)
http://www.johns-snapz.co.uk (external link)
http://Johnssnaps.zenf​olio.com (external link)
Hellashot
Joined Sep 2004
Jan 29, 2006 17:50 |  #5
Make sure you have the current firmware for your DVD burner. They update the burner to add data for different brand discs as well as speed, etc. Your manufacturer may also have a "recommended" DVd brand and type that will burn best on their website.
5D, Drebel, EOS-3, K1000
lenses from 12mm-500mm
Robert_Lay
Jan 29, 2006 20:03 as a reply to  @ Tapeman's post |  #6
That depends!
You haven't clarified anything beyond your original post.
Bob
StoneJer
Jan 30, 2006 01:21 |  #7
The problem can be in hardware or software or both. Your problem is so called compatibility problem. Only the vendor can quickly solve for you.
Union Brothers
www.unionbrothers.net (external link)
www.unionandbrothers.c​om (external link)
EOS_JD
Jan 30, 2006 08:00 as a reply to  @ Robert_Lay's post |  #8
Guys DVD RAM is most certainly a re-recordable media and is the best of any on the market. The only problem is a lot of drives are not compatible with DVD-RAM.
All My Gear
5D MkIII & 5D MKII + Grips | 24-70 f2.8L IS | 24-105 f4L IS | 70-200 f2.8L IS MkII | 50 f/1.4 | 85 f1.8 | 100 f2.8 | 1.4x MkII | Tamron 17-35 f2.8-4
Robert_Lay
Jan 30, 2006 09:39 as a reply to  @ EOS_JD's post |  #9
Did I actually group DVD-RAM in with the non-rewritable media?
Good Heavens! Sorry about that!
Bob
EOSAddict
Book Committee Immortal
Jan 30, 2006 09:58 |  #10
I use DVD-RAM for my main archive (incremental) as it is supposed to have a better life expectancy and I use cheap DVD-Rs for a second and third archive (full backup each time) I have an LG drive that handles everything...
Al
My Gear, My Website: www.endofthetrailphoto​graphy.com (external link)
StoneJer
Jan 30, 2006 16:17 as a reply to  @ snappa's post |  #11
Theoretically speaking, you are right. DVD Random Access Memory is of course re-writeable per defination. Access means READ, WRITE, which also implies CODING, DECODING, FORMATING….
Union Brothers
StoneJer
Jan 30, 2006 16:34 |  #12
In fact, to resolve your question is simple:
(1) Clean your drive. The reader or writer is dust-sensitive.
(2) Make sure your DVDs are nearly dust-free and compatible to Drive/software
In most case, you problem looks like is caused by minor hardware malfunction or software has been infected.
Union Brothers
NickC
Joined Dec 2001
Jan 30, 2006 19:16 as a reply to  @ StoneJer's post |  #13
You cannot give that solution without knowing what his drive's capabilities are or what software is being used -- and to this point the OP has not stated such. It could simply be that the media being written to is not supported by the drive.
EOS_JD
Jan 30, 2006 21:41 as a reply to  @ Robert_Lay's post |  #14
Easy mistake Robert haha:lol:
All My Gear
jfrancho
Jan 30, 2006 21:58 as a reply to  @ Robert_Lay's post |  #15
That'll cost you 1,000 posts!
1,969 views & 0 likes for this thread, 10 members have posted to it.
2070 guests, 100 members online
