I haven't done a whole lot of weddings so C&C's are always appreciated. Here are a few highlights.
More highlights
tonman23 Member 155 posts Likes: 2 Joined Sep 2010 Location: Cleveland More info | Oct 08, 2013 09:27 | #1 I haven't done a whole lot of weddings so C&C's are always appreciated. Here are a few highlights. More highlights Canon 5d mk iii | 24-70 2.8L | 85 1.2L | 70-200 2.8L IS | 50 1.4 | Sigma 35mm 1.4A | 50mm Macro w/ Lifesize converter
Oct 08, 2013 10:02 | #2 My favorite is #3 5DMKII | 50mm 1.4 | 24-105 f/4 | Speedlights - Strobes |
neimad19 Senior Member 767 posts Likes: 5 Joined Mar 2012 More info | Oct 10, 2013 13:19 | #3 Nice set! What lens/body setup were you using? #4 looks razor sharp on the fellas. Good work
SethWilliams Member 128 posts Joined Oct 2012 Location: Cookeville, TN More info | Oct 10, 2013 15:17 | #4 Love them. I do wish #4 was a bit tighter crop though as I have trouble seeing the guy's faces. Other than that, great work! 5D MK II x2 | 35L f1.4 | 85 f1.8 | 135L f2
jskaggs72 Member 237 posts Joined Oct 2013 Location: Noroflk Va More info | Oct 10, 2013 20:45 | #5 I like the ring shot. The one at the lightpost looks awkward to me too far apart. Also the guys wideout could be tighter fill the frame with them. Jay Skaggs
Oct 11, 2013 10:35 | #6 neimad19 wrote in post #16360897 Nice set! What lens/body setup were you using? #4 looks razor sharp on the fellas. Good work neimad19 wrote in post #16360897 Nice set! What lens/body setup were you using? #4 looks razor sharp on the fellas. Good work SethWilliams wrote in post #16361146 Love them. I do wish #4 was a bit tighter crop though as I have trouble seeing the guy's faces. Other than that, great work! neimad19 wrote in post #16360897 Nice set! What lens/body setup were you using? #4 looks razor sharp on the fellas. Good work neimad19 wrote in post #16360897 Nice set! What lens/body setup were you using? #4 looks razor sharp on the fellas. Good work Thanks. #4 was 5d mkiii with 85 1.2 on it. It's actually a stitch of 18 images using the brenizer method found here here are links to the higher res of the two lmk which you guys prefer: tight crop: http://www.anthonyeliasphotography.com …SVz/0/X3/i-C66DSVz-X3.jpg stiched: http://www.anthonyeliasphotography.com …Qm9/0/X3/i-d42wQm9-X3.jpg Canon 5d mk iii | 24-70 2.8L | 85 1.2L | 70-200 2.8L IS | 50 1.4 | Sigma 35mm 1.4A | 50mm Macro w/ Lifesize converter
Oct 11, 2013 10:49 | #7 i really like the cropped version and love the ring pic. great job on these a7+batis 18
robots4joey Senior Member 287 posts Joined Oct 2011 Location: Wichita, KS More info | Oct 11, 2013 14:22 | #8 Great Set! Do you mind sharing the technique for the ring shot? Website for Weddings: Wichita Wedding Photographer
Oct 11, 2013 15:08 | #9 robots4joey wrote in post #16363500 Great Set! Do you mind sharing the technique for the ring shot? I need to find a tutorial on these ![]() Thanks, Canon 5d mk iii | 24-70 2.8L | 85 1.2L | 70-200 2.8L IS | 50 1.4 | Sigma 35mm 1.4A | 50mm Macro w/ Lifesize converter
robots4joey Senior Member 287 posts Joined Oct 2011 Location: Wichita, KS More info | Oct 14, 2013 12:16 | #10 Thanks Tonman, do you shoot wide-open as well? Website for Weddings: Wichita Wedding Photographer
professorman Goldmember 1,661 posts Likes: 1 Joined May 2009 Location: VA More info | Oct 14, 2013 12:22 | #11 tonman23 wrote in post #16363636 I have the 50mm macro with a life size converter I used for that shot. . #3 is my favorite as well, but they are all awesome. MyGear | Feedback | facebook
Oct 15, 2013 14:00 | #13 professorman wrote in post #16370239 #3 is my favorite as well, but they are all awesome. How well does the life-size converter work for the 50 macro? I have that lens as well, but found it adequate for ring shots without the life-size converter. I bought them both used as a package deal and pretty much use them both together all the time. I do think ring shots look pretty solid with the 50 alone so it might not really be worth the investment if you're happy with the way your shots are turning out. There's a used one on ebay right now which is a nice deal. robots4joey wrote in post #16370221 Thanks Tonman, do you shoot wide-open as well? I usually shoot as wide open as possible while still getting all the subjects in focus. I will close down the aperture if I have time to setup lighting properly. Otherwise I try my best to line everyone up as parallel as possible and see how shallow a depth of field I can get away with. Canon 5d mk iii | 24-70 2.8L | 85 1.2L | 70-200 2.8L IS | 50 1.4 | Sigma 35mm 1.4A | 50mm Macro w/ Lifesize converter
Oct 16, 2013 06:17 | #14 dmitrim wrote in post #16371527 4th image is awesome! thanks! I just checked out your work. So creative and totally unique. Dynamic range in your photos are nuts! Canon 5d mk iii | 24-70 2.8L | 85 1.2L | 70-200 2.8L IS | 50 1.4 | Sigma 35mm 1.4A | 50mm Macro w/ Lifesize converter
wrankin Member 41 posts Joined May 2010 Location: Perrysburg, USA More info | Oct 17, 2013 21:28 | #15 I like them all!
| Latest registered member is NekoZ8 1076 guests, 105 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
