Maybe a touch too much color pop... the browns and the yellow legs look a little fake.. very little though. The other thing I like to do is to spot adjust the head, specifically the eye area, a little brighter. Most shots of birds shot up from the ground, end up with a shadow across the head. A bit more emphasis on the eye by reducing the head shadow would be great.
However, those are picky observations, and only because you asked. The edited image you put up was very good on its own. If you really want to play with edits, you should be using RAW. The only thing jpeg is good for straight from the camera is for taking the memory card to the drug store and printing them directly.
