Thread started 14 Oct 2013 (Monday) 13:07
Newbie Studio Light/Ambient light question!
lisaannephotography
Joined Apr 2013
Oct 14, 2013 13:07 |  #1
So I used to shoot in a room with no natural light, & now I use my living room which has a large sliding door (with curtain). I just use an AB 800 with a large octabox and I notice since I switched rooms my white balance is a little funny & I have weird lighting on some photos. I thought that my strobe would overpower the natural light and not make a difference? I've read SS can affect ambient light. Help a newb out - should I throw a blackout curtain over the window or what?
sdipirro
Oct 14, 2013 13:16 |  #2
You have a number of options. However, you're right that SS will impact the amount of ambient. What are you shooting for aperture, shutter speed, and ISO in the studio? You can raise the SS to your camera's xsync speed to see if that kills the ambient. You can do as you say and cover the window. You can also gel the strobe to match the color temp of the window light.
Cameras: 1DX, 1D4, 20D, 10D, S90, G2
Lenses: Canon 10-22mm, 16-35mm f2.8L II, 24-70mm f2.8L, 70-200mm f2.8L IS, 300mm f2.8L IS, 200mm f2L IS, 50mm f1.4, 50mm f1.2L, 85mm f1.2L, 1.4x TC, 2x TC, 500D macro, Zeiss 21mm
Lighting: 580EX, Elinchrom 600 RX's, D-Lite 4's, ABR800, 74" Eli Octa, 100cm/70cm DOs, Photoflex Medium Octa and reflectors, PW's, Lastolite Hilite, Newton Di400CR bracket
Scatterbrained
Gallery: 263 photos
Best ofs: 12
Oct 14, 2013 13:19 |  #3
Well you could:
Shoot at a time of the day when the sun isn't streaming through the window.
Get a heavier curtain.
Use your base iso (100).
Use your max sync speed.
Use a smaller aperture.
Wait until the sun goes down.
500px (external link)
1x (external link)
instagram (external link)
lisaannephotography
Joined Apr 2013
Oct 14, 2013 15:14 |  #4
sdipirro wrote in post #16370383 (external link)
I'm shooting F/stop between 3.2-5.6 ( I shoot newborns & babies, toddlers, etc.), ISO 100, SS 160 If I raise the SS by a lot will I need to adjust other settings? Thanks for your comment!
D ­ Thompson
Oct 14, 2013 17:15 |  #5
A simple way to tell if ambient is contributing is to take a shot without the AB800 on with the same camera settings.
Dennis
Canon 5D 20D
I have not yet begun to procrastinate!
sdipirro
Oct 15, 2013 11:06 |  #6
Raising the shutter speed (up to max synch speed for your camera) will only affect the ambient light contribution. You won't have to change other settings UNLESS ambient light is a major contributor to the overall lighting. If you have a light meter, meter the strobe at f8 and set the shutter speed to 1/200 or 1/250, leaving the ISO at 100, and see if there's any contribution from the ambient light.
gonzogolf
dumb remark memorialized
Gallery: 296 photos
Oct 15, 2013 11:08 |  #7
D Thompson wrote in post #16371026 (external link)
Try this before you do anything else. If you take a shot at the max sync speed of your camera without the lights you will see exactly what your ambient contribution will be. Then you will know for certain whether its worth the bother.
Submariner
Joined May 2012
Oct 16, 2013 09:05 as a reply to  @ gonzogolf's post |  #8
If you are getting erratic exposures and use a tripod. Try covering the viewfinder.
As in extreme and pretty unusual circumstances they say light entering this can effect exposure.
Not happened to me but something to rule out. The cover is / came on the strap on my 2 Canons.
Canon EOS 5DS R, Canon EF 70-200 F2.8 L Mk II IS USM, Canon EF 70-300 F4-5.6 L IS USM, EF 40mm F2.8 STM , RC6 Remote. Canon STE-3 Radio Flash Controller, Canon 600 EX RT x4 , YN 560 MkII x2 ; Bowens GM500PRO x4 , Bowens Remote Control. Bowens Pulsar TX, RX Radio Transmitter and Reciever Cards. Bowens Constant 530 Streamlights 600w x 4 Sold EOS 5D Mk III, 7D, EF 50mm F1.8, 430 EX Mk II, Bowens GM500Rs x4
1,310 views & 0 likes for this thread
Latest registered member is Dirtstar
863 guests, 227 members online
