Thread started 14 Oct 2013 (Monday) 19:21
Beginners Luck ?
Diver-Down
Oct 14, 2013 19:21 |  #1
Made my first attempts at shooting stars over the weekend and I think I got a shooting star (meteor) in the one frame ? When I saw it on the camera I thought it was a darn plane, but when I saw it on the computer it looks more like a meteor. I see there is a plane behind it with a blinking light. Also looks like it's going away from me so I wouldn't think it would be a planes headlight. The exposure was 30 sec. long
Meteor or Plane or UFO ?
IMAGE: http://imageshack.us/a/img513/251/r2vt.jpg
NovaTJ
Oct 14, 2013 19:50 |  #2
Well, if it were a plane, it should have blinking lights as the one near it in the image. The consistant color and brightness lends me to believe it's either a satellite, ISS, or a UFO. Most iridium satellites have a very bright reflection somewhere along it's path. My best guess...
Astro-Tech 8" f/4 imaging Newtonian,Baader MPCC,Orion ED 80 APO F7.5,Skywatcher EQ-6 Pro,ASGT, Modified Canon 50D, Meade DSI Guide Camera, 8" SCT dovetail mounted relic, Criterion Dynascope RV-6, modified 300D, custom astro shed,and still just getting started!
Diver-Down
Oct 14, 2013 20:22 as a reply to  @ NovaTJ's post |  #3
Wasn't thinking about a satellite, I have seen them in the past.
I just took a closer look at the original and I can faintly see a blinking light in the bright streak. That sounds like a plane ?
ecce_lex
Oct 15, 2013 03:30 as a reply to  @ Diver-Down's post |  #4
Hello there,
Looks like the ISS to me. Look at the data in your photo (exact time, length of exposure, orientation) and compare it with what CalSKY tells you about events at that time in your area - you'll be able to identify what it is.
Until then it's a UFO.
Schrodinger's cat walked into a bar - and didn't.
Gear: 60mm Takahashi, 200mm C8, 7Dmod, EQ6
Website: https://plus.google.co​m …873112797282158​324/albums (external link)
mtbdudex
Gallery: 35 photos
Oct 15, 2013 04:57 as a reply to  @ ecce_lex's post |  #5
Via Heavens-above website (external link), took me 5 minutes to do the below....
Using your EXIF data, Original Date/Time = 2013:10:11 20:24:51
and your location of Bethlehem PA
IMAGE: https://lh4.googleusercontent.com/-3larGQuh2SA/Ul0Ofo6071I/AAAAAAAAQpw/l-Cd5hbBYUo/s512/Bethlehem%2520PA.jpg
Shows there was a visible ISS pass at 19:47:08 max, not 20:24:51 like your camera says, is your clock slightly wrong?:
IMAGE: https://lh6.googleusercontent.com/-2qHqg6ZI8GE/Ul0Ofngeg_I/AAAAAAAAQpw/UhhB7iUJ5ro/s512/ISS%2520Oct-11.jpg
Here is star chart of that ISS pass
IMAGE: https://lh4.googleusercontent.com/-Yc7kiM19oIU/Ul0Pc6D_u-I/AAAAAAAAQqI/gx_9iLlZ4ZM/s800/ISS%2520Oct-11%2520skychart.png
fwiw, I think your camera clock is off, and you did capture the ISS.
here is the ISS taken 10-26-2010 (4) 25 sec exposures stacked.
IMAGE: https://lh5.googleusercontent.com/--otr0qvA6yo/TNDcbYtHFZI/AAAAAAAAQck/q14PDWiZp8g/s1024/ISS%252010-26-2010%2520%25284%2529%252025%2520sec.jpg
Mike R, P.E. ...iMac 27"(i7), iPad2, iPhone14Pro, AppleTV4K, MacBook
Canon: Body R5, lens RF 24-105mm L F4, RF 100-500mm f/4.5-7.1L, 1.4 TC, EF 70-200 L f2.8 IS II / TC 1.4x 2x
FEISOL tripod CT-3441S + CB-40D Ball Head
My top 10 in Astrophotography. . .DIY acoustic panels (external link) . . APOD Aug-5-2011 (external link)
Diver-Down
Oct 15, 2013 06:21 as a reply to  @ mtbdudex's post |  #6
Wow that's pretty cool. I'll have to play with that site when I have time tonight. I was actually about 200 miles NW of home, near Warren PA, looking NW. Maybe that's why the time difference. Time and date are correct in camera.
Would the ISS have a blinking light ?
NovaTJ
Oct 15, 2013 18:50 as a reply to  @ Diver-Down's post |  #7
...and one I took several years ago.
Blinking light...I don't think so unless someone on-board was blinking his flashlight out the window.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/10/3/LQ_665152.jpg
Image hosted by forum (665152) © NovaTJ [SHARE LINK]
mtbdudex
Gallery: 35 photos
Oct 15, 2013 18:56 |  #8
Diver-Down wrote in post #16372357 (external link)
well sorry to say then it's definitely not the ISS, as upon input of Warren PA you are still seeing the same event as your home location.
Now, you can plan ahead and use that site to make sure it is the ISS for future capture.
So, plane most likely.
Diver-Down
Oct 15, 2013 19:21 as a reply to  @ mtbdudex's post |  #9
Yes, I saw there was very little difference for Warren, It sure looks like the ISS shots you guys have though. How about a satellite ? Maybe the one below ? Checked my camera again and the time was off by about 2 min. so actual time was around 20:22to 20:23 Not sure if the direction of travel is correct though, the moon was behind me. Brightness is higher than the ISS too, if I'm reading the numbers right. Higher is brighter ? Also why two times on some days for the ISS, are there two ?
Also included a close up of the trail. Not sure if it's a blinking light in the beginning of the trail but there's something there. Looks quite different from the plane behind it.
IMAGE: http://imageshack.us/a/img209/2219/dm3e.jpg
IMAGE: http://imageshack.us/a/img30/4765/g4wl.jpg
Toxic ­ Coolaid
Oct 15, 2013 19:33 |  #10
Come on Greg... look at you... Big Dipper / ISS and all out of focus LOL. It is fun to know in advance and set up to catch it if the clouds will let you. It'll be so bright sometime you swear you should hear something. I use an app on my iphone called GoSatWatch. You can have it give you an alarm before passes if you want.
One thing the original pic could be is an airplane with a landing light on at it's front gear. If there's dotted lights beside it... it's not the ISS.
If you have a remote timer and wide lens you can get some cool passes
http://mophopix.smugmu​g.com …005858&k=h33LLm​J&lb=1&s=A (external link)
IMAGE: http://i347.photobucket.com/albums/p446/mokpt/ISS4-12-12med.jpg
IMAGE LINK: http://s347.photobucke​t.com …ia/ISS4-12-12med.jpg.html  (external link)
Mo
SteveInNZ
Oct 15, 2013 20:28 |  #11
Maybe if an astronaut is outside on a smoke break. :)
"Treat every photon with respect" - David Malin.
Miki ­ G
Oct 16, 2013 13:01 |  #12
SteveInNZ wrote in post #16374197 (external link)
bw!
Toxic ­ Coolaid
Oct 16, 2013 18:18 |  #13
Diver-Down wrote in post #16374049 (external link)
The lower the number the brighter the object will be. when you get to -3 it's pretty bright. ISS gets to -10 sometimes. I have thought is was a helicopter leaving a local hospital before. Your cropped picture looks to have something flashing... I still think a plane with a landing light on... but that is pretty much what a 7 or 8 second ISS trail would look.
2,590 views & 0 likes for this thread, 7 members have posted to it.
Beginners Luck ?
1332 guests, 137 members online
