guntoter wrote in post #16372581
I see. OK that makes sense.
EDIT: Sounds like it is time for Canon to update the IS on this lens.
There's more to it than just choosing the correct shutter speed.
Someone with a screen name "Guntoter" should have a pretty good idea what some of them are...
With any long lens you also need to pay a bit more attention to good handholding techniques (a solid stance, timing your breathing, elbows tucked, etc.) or use some sort of support: a monopod or a tripod, perhaps with a gimbal head if shooting moving subjects. And you need to get in the habit of "squeezing the trigger", not stabbing at it and causing unnecessary camera movement. IS is great, but can only do so much. A lot of it is similar to target shooting, actually. Think of the difference in accuracy between a sort of gritty, sloppy factory trigger with 7 lbs of pull versus a gun that's had a trigger job to smooth things out and "break like glass" with a 3 lb pull.
Someone who hasn't used long IS lenses before also has to learn that it takes a moment for IS to do it's thing, so one might want to get in the habit of starting it and letting it "settle", a half second before taking your first shot. It's not a long delay, actually is about the same amount of time as and concurrent with the lens achieving focus. You can see IS cause the image to "snap" into steadiness, in the viewfinder.
Further, the 100-400 has the type of IS that needs to be turned off manually when there is no movement... Such as when the lens is locked down on a tripod. If there is no movement, the IS actually can go into sort of a feedback loop that creates movement and causes some image blur. If you handhold the lens really, really steady this can happen, too, but it's rare to be able to hold it that steady.
Also with IS, every once in a great while you get a shot where the IS seems to cause problems rather than solve them, for somewhat unexplicable reasons. I think it's just that IS happened to be in mid-correction when you tripped the shutter, or something unavoidable like that. I just chalk it up to bad luck the occasional lost shot. It is a pretty rare occurance.
IS is great... best thing since sliced bread as far as I'm concerned. But it has its limits and takes a little practice to learn to use it really well.
And, modern zooms are mostly varifocal designs, I think including the 100-400. That means you need to refocus (or use continuous AI Servo focus) any time you change the zoom's focal length, or it will be out of focus. Back in the days of manual focus only, more zooms were parfocal designs, that maintained focus when zoomed, but makes for a more expensive design and additional adjustments that need to be set and maintained. With today's AF systems that can correct focus on the fly, simpler and less finnicky varifocal designs can be used without a lot of concern... but the user has to be aware of it and sure to refocus any time they change focal length.
There are also nuances of particular lenses...
The 100-400mm is somewhat unusual among today's zooms, with it's push/pull zoom design. Some people really like that design for the speed possible when using it. Others don't care for it. I'm one of the latter. I've used push/pull zooms in the past and always had trouble getting steady shots with them. I prefer a second ring for zooming, that I rotate with the hand I'm using to cradle the lens. But that's just me. Other folks have better luck with the push/pull design.
Also, the 100-400mm is known to "not play well" with filters. Virtually any filter on it is likely to degrade (soften) images. Many users have noted a big IQ difference between the lens with and without a filter on it, no matter how high quality the filter.
