Thread started 15 Oct 2013 (Tuesday) 09:40
Can you save all your 5Dmk3 camera settings to your PC?
Nick_Reading.UK
Joined Nov 2011
Oct 15, 2013 09:40 |  #1
As "Other" people do like to Mess things up within the settings..
EOS 5Dmk3 X2, 60D, EF24-70mm f2.8L mk2, EF70-200mm f2.8L IS mk2, EF85mm f1.8, EF50mm f1.4, EF50mm f1.8 mk1(350D with 18-55mm Sh"kit" lens).
Speedlite 600EX-RT, 430EX II Flash. manfrotto 190XDB tripod, Giottos GTMML 3290B Monopod, B+W 77mm 110 Single Coated filter, Hama 77mm Variable Neutral Density Filter.
John ­ from ­ PA
Joined May 2003
Oct 15, 2013 12:52 |  #2
Go to the thread at https://photography-on-the.net …/showthread.php​?t=1215497. A few models, like the Canon 1DMkIV, support what you desire. When you get to the link, go to the 2nd page where an individual mentions a utility that might do this. I didn't try it back then nor now so you get to be the test case.
lovemyram4x4
Gallery: 97 photos
Joined Mar 2013
Oct 15, 2013 12:58 |  #3
Didn't they add this feature to EOS utility but it only works some bodies? I haven't got around to installing it on my new laptop as I don't use the Canon software that often and the need for it hasn't came up, otherwise I'd verify if it is there and works on the 5DIII.
John ­ from ­ PA
Joined May 2003
Oct 15, 2013 14:10 |  #4
lovemyram4x4 wrote in post #16373146 (external link)
Interesting point you bring up. I only have the Help File for EOS Utility version 2.9.0 and I've attached two pages that indicate some items can be "registered" which I assume means saved to the PC. The current version is 2.13.25.1 - I'll have to update and give it a try.
virsago_mk2
Oct 15, 2013 21:06 |  #5
AFAIK that feature is exclusive for 1D series bodies.
So for a 5D3 users like us, we'll have to write down the settings ourselves & keep it safe somewhere.
Gear: Here | Portfolio: Flickr (external link)
lovemyram4x4
Gallery: 97 photos
Joined Mar 2013
Oct 15, 2013 22:51 |  #6
virsago_mk2 wrote in post #16374277 (external link)
If that's the case, it seems pretty silly to support it on bodies that can already save settings to CF/SD card.
apersson850
Oct 16, 2013 14:44 as a reply to  @ lovemyram4x4's post |  #7
The registration mentioned in the extract from the manual above is the setup of the six items you can bring together in the User's menu, a feature introduced with the 40D/1D Mark III.
There are a few other settings you can do via EOS Utilities too, but not an overall storage of all settings, like the 1DX can do to its memory card.
Anders
1,347 views & 0 likes for this thread
Latest registered member is aaalex7
1068 guests, 326 members online
