Before anyone asks, I did a search already. I found loads of people with this problem, but none of the suggestions that worked for them helped for me. I had a CF card (lexar professional) with 15 gigs of images on it fail on me. First time since I started shooting has this ever happened. It says "You need to format drive H: before you can use it" when I insert the CF card reader into the usb slot. If I do that, I lose the files.
I've tried five pieces of recovery software, including lexar's version, 4 don't work and 1 seemed to pull out 256 files...but they won't open in photoshop or bridge. Say the file is a read only file and can't be opened, or is read only.
Thoughts?
