was at a workshop today and it was drizzling, not too hard but occasionally some good drops. i have never worked in the rain. Should my lens withstand it ok? it got a few drops, nothing major but I still want to ask.
abbypanda Goldmember 1,804 posts Likes: 6 Joined Nov 2011 More info | Oct 15, 2013 23:13 | #1 was at a workshop today and it was drizzling, not too hard but occasionally some good drops. i have never worked in the rain. Should my lens withstand it ok? it got a few drops, nothing major but I still want to ask.
-dave-m- Senior Member More info | Oct 15, 2013 23:31 | #2 Depends on the lens. 5D MkII Gripped | 7D MkII Gripped | 200 f/2.8L | 17-40 f/4L | Σ 24-105 OS f/4 Art | Σ 50 f/1.4 Art | Σ 150-600 OS f/5-6.3 C | 430EX II
Oct 16, 2013 01:00 | #3 Today used 50l
Saint728 Goldmember 2,892 posts Likes: 1 Joined Jun 2009 Location: Honolulu Hawaii More info | Oct 16, 2013 01:08 | #4 That lens is weatherproof so you should be fine. It also depends on the camera body your using with it? Canon EOS 1Ds Mark III | 17-40mm f/4.0L | 70-200mm f/2.8L USM | 100mm f/2.8L IS Macro | 300mm f/4.0L IS
Oct 16, 2013 01:12 | #5 5diii
Oct 16, 2013 06:35 | #6 |
Oct 16, 2013 06:48 | #7 davidfarina wrote in post #16375035 Well, every "waterproof" lens is just 100% waterproof when you attach a filter... There are no 'waterproof' Canon lenses. The best you'll get from Canon is 'Drip-Proof'. Only a fraction of 'Drip-Proof' lenses require a filter to complete the 'sealing'. Frank Hollis - Retired mass spectroscopist
amfoto1 Cream of the Crop 10,331 posts Likes: 146 Joined Aug 2007 Location: San Jose, California More info | Oct 16, 2013 08:35 | #8 At best, Canon gear (lenses, cameras and accessories) are "weather/dust resistant". Some more than others, but none are "waterproof" by any means, and certainly never "100%". Except maybe inside an underwater case, and then only to the rated depth... if the case and its seals are in good shape and everything is properly installed. Alan Myers
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Oct 16, 2013 09:42 | #9 On top of what's said in the previous two posts, Canon will simply refuse to repair any camera or lens that has been damaged by liquid intrusion into them. Skip Douglas
Oct 16, 2013 10:29 | #10 Thanks for the replies and I didn't assume waterproof but I kinda figured about the equivalent of an iPhone say? Few drops never hurt mine. But on a lens would even slight moisture or moisture in air lead to fungus at some point?
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Oct 16, 2013 10:45 | #11 abbypanda wrote in post #16375533 ..... But on a lens would even slight moisture or moisture in air lead to fungus at some point? It's possible. We've heard here of someone pressing a camera's button (I forget which button) with a wet finger and having the camera fail to function shortly thereafter. I don't remember the details, but the incident was far different from the camera being splashed or used in a rain storm. Skip Douglas
I use both my 5DII and 7D in light drizzle or snow with a 'sealed' lens and so far have not had a problem even though they can get quite wet (but not absolutely drenched). Edward Jenner
| Latest registered member is semonsters 884 guests, 128 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
