Leafy Photography wrote in post #16397093
2 and 3 are the strongest of the set in my opinion.
In photo 1 the car seems a tad out of place with the white being so dominant. It almost looks like a composite.
I would adjust the white balance on the car to better match the rest of the photo, or use a couple gradients to blend some colour and contrast...
Numbers 6 and 7 would be more interesting if both shots were recomposed. 7 would look better with the car composed on the right of frame, and 6 would look better if the car was right centre instead of lower right of frame. Would've turned the wheel toward the camera too.
Overall great quality though, keep em coming dude! PS. You fellow Ontarian. Look me up on facebook. We should network haha.
Thanks for the critique, every photographer will see a subject in a certain way. I like to compose my shots where a subject is sitting comfortably in a scene, and create a mood with the surrounding environment and lighting. I took a quick gander at your work and can see based on what you do, your suggestions reflecting on to mine. A lot of your composition and subject placement tend to have them facing towards the outside of the frame, something that I am not content with and as shown do not do in my work. To each his own in that regard. As I said, everyone sees something in a different way than another person.
Regarding the first image, quite a bit of color correction was done to reduce the harsh yellow WB of the ambient light sources that were present at the location. I did not want to completely change the temperature of the lighting as I felt it would have been too bland and otherwise a boring image. White by nature should be fairly neutral and should not have a certain coloring to it, which would suggest incorrect WB adjustment. I did apply some color balance on top of the whole image to unify both exposures for the car and background and the not have major coloring discrepancies.
While I appreciate constructive criticism, I can't justify changing the way I do my compositions/framing/editing just to suit the likes of other creative individuals who do things another way. If everyone did the exact same thing, same framing, same lighting, same settings, etc, there would be no competition and no differentiating yourself from others.
