Thread started 18 Oct 2013 (Friday) 04:44
Can i replace my EF-S 17-55mm for a FF that will do a good job on Crop
Nick_Reading.UK
Joined Nov 2011
Oct 18, 2013 04:44 |  #1
Can i replace my EF-S 17-55mm for a FF that will do a good job on Crop?
I really like my EF-S 17-55mm on my 60D but times have moved on and I am now FF, I would like to replace it with a FF lens that will also work on my 60D..
I am thinking maybe the 16-35mm 2.8.. Or any other suggestions.. ??
Nick
EOS 5Dmk3 X2, 60D, EF24-70mm f2.8L mk2, EF70-200mm f2.8L IS mk2, EF85mm f1.8, EF50mm f1.4, EF50mm f1.8 mk1(350D with 18-55mm Sh"kit" lens).
Speedlite 600EX-RT, 430EX II Flash. manfrotto 190XDB tripod, Giottos GTMML 3290B Monopod, B+W 77mm 110 Single Coated filter, Hama 77mm Variable Neutral Density Filter.
kin2son
Joined May 2011
Oct 18, 2013 05:07 |  #2
Just sell your crop kit and move on, absolutely no point to cling on it...
5D3 Gripped / 17-40L / Σ35 / 40 Pancake / Zeiss 50 MP / Σ85 / 100L Macro / 70-200 f2.8L II IS / 430 EX II / 580 EX II / Canon 2xIII TC / Kenko Ext. Tubes
EOS M / EF-M 18-55 / EF-M 22f2 / Ricoh GR aka Ultimate street camera :p
Flickr (external link) | My Images on Getty®‎ (external link)
JoYork
Oct 18, 2013 05:24 |  #3
24-70 is probably your best alternative, although there's no IS.
Jo
marcosv
Oct 18, 2013 05:29 |  #4
If you are willing to give up wide angle on the crop, 24-70/2.8L II. If you want to get at least 18mm or 17mm in a full frame zoom lens, you are looking 16-35L or 17-40L or the equivalent in 3rd party lens.
Thing is, those lens are compromises on a crop compared to a 17-55.
Personally I'd reflect on whether or not you need to stick with crop sensors. If the answer is no, sell your 60D and 17-55 to maximize what you can get for them and move on.
Since buying my 2nd full frame body, I never used my old crop sensor stuff. I loaned my 40D, 10-22, and 17-55 on essentially a permanent basis to a friend of mine.
EOS-M | 40D | 5DII | 5DIII | EF-M 22 | EF-M 18-55 | 10-22 | 17-55 | 17-40L | 24-70L mk II | 24-105L | 70-200/2.8L IS mk II| 35L | 85L II |35/2 | 40/2.8 pancake | 50/1.8 | 50/1.4 | 100/2 | Rokinon 14/2.8 | 90 EX | 270 EX II | 580 EXII | 600 EX-RT
Nick_Reading.UK
Joined Nov 2011
Oct 18, 2013 06:19 |  #5
marcosv wrote in post #16379938 (external link)
I really want to keep my 60D as I need it for None serious stuff and Brazil next year..
kin2son
Joined May 2011
Oct 18, 2013 06:33 |  #6
Nick_Reading.UK wrote in post #16379992 (external link)
Pick up a M or m43 etc for travel.
TeamSpeed
01010100 01010011
Gallery: 111 photos
Joined May 2002
Oct 18, 2013 06:40 |  #7
The 60d stays, deal with it :)
Seriously why even suggest this? The op is just asking about a lens, not a format or body change. Some people actually don't mind the apsc format. You don't like crop, we get it, doesn't mean others don't.
For Sale: 2x Teleconverter
For Sale: Sigma USB Dock
bratkinson
Joined Dec 2011
Oct 18, 2013 06:53 |  #8
Knowing I was going to go full frame one day, I replaced my EF-S 18-135 with a 16-35 f2.8L ii. I also had a 24-105 which just wasn't 'wide enough' on the 60D, and the 16-35 fit the bill perfectly. Now that I've moved to a 5D3, the 24-105 is generally 'wide enough', but there are still times I need 'wider' and the 16-35 does just that.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." General George S Patton, Jr 1885-1945
RayinAlaska
Gallery: 11 photos
Joined Sep 2013
Oct 24, 2013 16:59 |  #9
Tokina 16-28 f/2.8 for FF, but can be used for cropped, although using filters with it will make it more expensive.
That's the lens I plan to buy in the near future for both my 5D II and 7D, but I also have a Tokina 11-16 that I use with the 7D.
DreDaze
Gallery: 45 photos
Oct 24, 2013 19:05 |  #10
i'd sell it, and then maybe buy a cheaper sigma 17-50OS, and just use it exclusively on the 60D...you'd save some money, and not give up much/if any IQ wise...i mean if you're going to hold onto the 60D anyways, might as well have a lens that works best for it
if you go for a FF lens, you're either giving up f2.8, IS, the wide end, or the long end...
16-35mm f2.8, gives up the long end and IS
17-40mm f4 gives up f2.8, IS, long end
24-70mm f2.8 gives up IS, wide end
tamron 24-70VC only gives up the wide end
24-105L gives up f2.8, and the wide end
if you can't afford to keep a lens just for the 60D, then you'll have to just decide what your priorities are for use on the crop
Andre or Dre
gear list
Instagram (external link)
phantelope
Oct 24, 2013 19:16 |  #11
I got the Tammy 24-70 for FF, but keep my 17-55 for my crop. To go wider on FF, I got the Rokinon 14mm this week, great lens and the all manual is no issue for this kind of lens. Much sharper than any of the ultra wide zooms and a LOT cheaper too :-)
If canon had a 24-70 with IS I'd probably have bought that, but they don't for some reason.
40D, 5D3, a bunch of lenses and other things :cool:
FEChariot
Gallery: 13 photos
Joined Sep 2011
Oct 24, 2013 19:20 |  #12
If I were you, I would pick the focal length I would be using when I was using the FF body as the priority. So if I wanted an UWA, I would get a 16-35 or 17-40 and have a normal for the 60D. If I wanted a normal or standard zoom, I'd get a 24-x and have a short tele on crop too.
Canon 7D/350D, Σ17-50/2.8 OS, 18-55IS, 24-105/4 L IS, Σ30/1.4 EX, 50/1.8, C50/1.4, 55-250IS, 60/2.8, 70-200/4 L IS, 85/1.8, 100/2.8 IS L, 135/2 L 580EX II, 430EX II * 2, 270EX II.
YashicaFX2
Joined Aug 2013
Oct 24, 2013 23:13 |  #13
TeamSpeed wrote in post #16380022 (external link)
Thank you, from all of us dedicated APSc shooters.
I bought a 5D about a year ago. I played with it and couldn't find much difference for what I do, which is mainly cats, dogs and grandkids. For me, the IQ benefits do not follow the cost. Lots of money for not lots of IQ difference. I am much happier with my 60D now that I have glimpsed the other side. Or peeked down the rabbit-hole, depending on your perspective.
Dedicated APS-c shooter. Gripped 60D, 60 2.8, 10-22, 15-85, Σ70-200 OS and a big white something or other! Plus a 5D w/28-75.
Poe
Oct 24, 2013 23:56 |  #14
Sure you can. Get a 16-35 + 40 2.8 + 50 1.4. Done.
Nikon D750, D7200 | Nikon-Nikkor 14-24G, 60G Micro, 70-300E | SIGMA 35A, 105 OS, 24-105 OS | ZEISS Distagon 2.0/25 Classic, Apo-Distagon 1.4/55 Otus, Apo-Planar 1.4/85 Otus, Makro-Planar 2/100 Classic, Apo-Sonnar 2/135 Classic
Nick_Reading.UK
Joined Nov 2011
Oct 25, 2013 01:44 |  #15
Poe wrote in post #16397261 (external link)
I think that's what I will do :-)
2,585 views & 0 likes for this thread
Latest registered member is dayuan99
709 guests, 223 members online
