Thread started 20 Oct 2013 (Sunday) 13:28
Flash Bracket Needed Upcoming Wedding
picworx
Joined Jun 2005
Oct 20, 2013 13:28 |  #1
I purchased a Vello but I am not happy with it, it also does not work on a gripped 5D MKIII, so I am looking for a light, solid, anti-twist folding flash bracket, I would like some ideas on what units you folks use.
I want to keep the costs down to under $150 if I can. I found this one on BH but does not fold but does do gripped cams.
http://www.bhphotovide​o.com …tal_T_Flash_Rot​ating.html (external link)
cheers
The Print is What Really Matters
D ­ Thompson
Oct 20, 2013 15:01 |  #2
Basically the same one that folds - http://www.bhphotovide​o.com …_T_Folding_T_Br​acket.html (external link). I use it with a gripped 5D.
Dennis
Canon 5D Mk III 5D 20D
I have not yet begun to procrastinate!
Wilt
Oct 20, 2013 16:15 |  #3
Newton Camera Brackets...a professional grade flash bracket, which comes in several different versions, including folding bracket Di100FR2
http://www.newtoncamer​abrackets.com (external link)
picworx
Joined Jun 2005
Oct 20, 2013 16:25 as a reply to  @ Wilt's post |  #4
D Thompson
How do you like this bracket, is it solid?
Also when you flip I understand it has a spring that holds it in position?
D ­ Thompson
Oct 20, 2013 17:24 |  #5
picworx wrote in post #16385560 (external link)
D Thompson
I haven't had it too long, but so far I like it. Feels solid to me. I assume there is a spring in the elbow, it's hard to tell by looking. I can get some detail shots later if you'd want. The only drawback, and it's small imo, is when shooting in portrait orientation the bottom of the bracket could be a little more rounded where your hand hits it. I guess one could add a little foam or something to help if it bothered. I like the balance of it.
Dennis
picworx
Joined Jun 2005
Oct 20, 2013 17:47 |  #6
D Thompson wrote in post #16385687 (external link)
Getting some shots of your setup would be great, I was looking at the Digital Pro M but at almost $400 out of my price range. Post your shots when you get a moment,
Cheers
D ­ Thompson
Oct 20, 2013 22:54 |  #7
picworx wrote in post #16385723 (external link)
Cheers
Here you go, hope they help. 5D with 580 EXII.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/10/3/LQ_665673.jpg
Image hosted by forum (665673) © D Thompson [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/10/3/LQ_665674.jpg
Image hosted by forum (665674) © D Thompson [SHARE LINK]
Dennis
Nick5
Oct 20, 2013 23:36 |  #8
For my gripped 7D I chose the Custom Brackets RF-PRO. It allows quicker change in orientation and not as cumbersome as other brackets. Also other styles interfered with either grip portion in hand while shooting in portrait mode and also with shutter button in landscape. I like this very much and does a nice job.
http://www.custombrack​ets.com/products/featu​red/rf-pro.html (external link)
Canon 5D Mark III (x2), BG-E11 Grips, Canon Lenses 16-35 f/4 L IS, 17-40 f/4 L, 24-70 f/4 L IS, 70-200 f/2.8 L IS II, 70-200 f/4 L IS, 70-200 f/4 L IS Version II, 100-400 f/4.5-5.6 L IS Version II, TS-E 24 f/3.5 L II, 100 f/2.8 L Macro IS, 10-22 f3.5-4.5, 17-55 f/2.8 L IS, 85 f/1.8, Canon 1.4 Extender III, 5 Canon 600 EX-RT, 2 Canon ST-E3 Transmitters, Canon PRO-300 Printer
Green ­ Li
Gallery: 15 photos
Oct 21, 2013 02:32 |  #9
I don't use brackets often, but when I do I either go for Demb Flash Bracket or Ray Flash Rotator
PHOTO-TIPS-ONLINE.com – photo tips, photography reviews (external link)
Facebook (external link) | Twitter (external link) | Google (external link)+
picworx
Joined Jun 2005
Oct 21, 2013 10:30 as a reply to  @ D Thompson's post |  #10
Thanks Dennis, a photo tells you the whole story, thanks for taking the time....
picworx
Joined Jun 2005
Oct 21, 2013 10:32 as a reply to  @ Nick5's post |  #11
Nick5 - I thought the whole point of a bracket was to get the flash away from the lens as far as possible for run and go weddings?
The RF-PRO looks like the flash is still pretty much still "on camera" within an inch or so as they say....?
The ­ Loft ­ Studios
Oct 21, 2013 11:10 as a reply to  @ picworx's post |  #12
I use a Stroboframe Pro RL as well as Custom Brackets..... Once you have one of these, you'll never want to use anything else!
http://www.youtube.com​/watch?v=y7Sl88hfVp4 (external link)
MARK
philodelphi
Gallery: 50 photos
Oct 21, 2013 11:42 |  #13
Do people use these brackets with wireless triggers? Wouldn't that be less cumbersome?
Sony DSC-RX100M2 α7R III / ILCE-7RM3 Cyber-shot DSC-RX10 IV | Voigtlander 65mm F2 Macro APO-Lanthar | Venus Optics Laowa 15mm f/4 Macro | Sony FE 24-240mm F3.5-6.3 OSS Sonnar T* FE 55mm F1.8 ZA FE 24mm f/1.4 GM | Samyang 35mm f/1.4 ED AS UMC | Canon MP-E 65mm f/2.8 1-5x Macro Photo EF 100mm f/2.8 Macro USM | Sigma 100-400mm f/5-6.3 DG OS HSM | Tokina Firin 20mm f/2 FE MF | Tamron 28-75mm F2.8 Di III RXD
Wilt
Oct 21, 2013 12:26 |  #14
This is my own Newton flash rotator bracket, though not the newer folding version
IMAGE: http://i69.photobucket.com/albums/i63/wiltonw/bracket1.jpg
IMAGE: http://i69.photobucket.com/albums/i63/wiltonw/bracket2.jpg
IMAGE: http://i69.photobucket.com/albums/i63/wiltonw/bracket3.jpg
Very rigid, very compact, and very light weight. It keeps the flash over the axis of the lens, for no side-shadow. There is a vertical extension available, if you want to raise hotshoe flashes even higher (I don't bother). There is no need to adjust flash head angle after rotating between Portrait/Landscape orientations. You can use it without battery grip, and you can use it with battery grip! I use it both for dSLR (without grip) and also with my Bronica medium format (with motor drive grip added).
D ­ Thompson
Oct 21, 2013 14:06 |  #15
Wilt wrote in post #16387678 (external link)
Wilt, have you ever noticed any weird shadows having the camera in portrait while the flash is still in landscape with that setup? The reason I ask is salesman-A sold me a "camera rotating" bracket similar to your setup. Unfortunately when I got home it wouldn't take my grip, even though I asked about that. When I returned, salesman-B told me it's preferable to have the flash rotate so it would always match the orientation of the camera sensor. It made sense, but figured it might only show up using a wide angle lens maybe.
Dennis
4,960 views & 0 likes for this thread, 10 members have posted to it.
1510 guests, 132 members online
