Thread started 30 Jan 2006 (Monday) 16:24
Who uses the bundle program for post-processing?
Calzinger
Jan 30, 2006 16:24 |  #1
I happen to use the software that my 350D came with to post process RAW: Raw Image Task which opens from ZoomBrowser EX. I find it very simple and straightforward. It's pretty useless if you need dramatic changes, but I think it works, at least for me.
I tried RawShooter, but found it almost too expansive.
Your thoughts on the bundle app for post-processing?
"That building in the background is distracting."
"Oh OK, I'll move it out of the way next time."
internet forum fail
R ­ Hardman
Jan 30, 2006 19:49 |  #2
I use it to export my images into PS5. Works for me. Like you said it is pretty easy.
"Whatever you can do to avoid Photoshop is worth it"
EOS 7D, EOS 350D, EF 17-40mm f/4L USM, EF 70-200mm f/4L USM, EF-S 18-55mm f/3.5-5.6 USM (Kit)
Rick's Digital Desert (external link)
PacAce
Joined Feb 2003
Jan 30, 2006 21:13 |  #3
If I have a whole bunch of raw files to process, I use DPP to convert to TIFF and then use PSCS to further edit the image. But there are times when I also use EVU and ACR.
...Leo
tim
Light Bringer
Jan 30, 2006 21:28 |  #4
I always use CS2 for raw conversion, because i'm used to its workflow.
jfrancho
Jan 30, 2006 21:59 as a reply to  @ PacAce's post |  #5
Leo, what drives you preference for DPP in this situation?
Calzinger
Jan 31, 2006 05:29 |  #6
What is DPP anyway? All these acronyms are throwing me off. :|
I tried using that Adobe RAW image plugin to no avail. Whenever I try to open a .cr2, CS2 doesn't open it and says something in regards to not being able to open the file ty pe. Do I have to convert to dng first before opening in CS2? (i think that's the right extension?
internet forum fail
usukshooter
Jan 31, 2006 06:47 as a reply to  @ Calzinger's post |  #7
Sounds like you need to update the Camera Raw Plugin. Support for the 350D came with 3.2 so you'd need that or the new 3.3 - your current plugin is probably 3.1
http://www.adobe.com …/photoshop/came​raraw.html (external link)
Calzinger
Jan 31, 2006 07:01 as a reply to  @ usukshooter's post |  #8
I have 3.3. Should it be able to open .cr2?
internet forum fail
usukshooter
Jan 31, 2006 07:09 |  #9
You should be able to open them if you have Camera Raw 3.3. You're not trying to open them straight off the camera are you?
Calzinger
Jan 31, 2006 07:39 as a reply to  @ usukshooter's post |  #10
Nope, I'm transfering them to my drive first, then opening from there.
internet forum fail
jfrancho
Jan 31, 2006 07:54 |  #11
First off, DPP is Digital Photo Professional, it's from Canon. Not the prettiest app, but dose a nice job converting raw files. Second, if you have PS CS2, and have installed the ACR 3.3 plugin correctly, cr2 files from your 350d should open fine. I suspect that it was either installed improperly or the downloaded file was corrupt. Open Photoshop CS, and click Help>About Pug-in and look for Camera Raw. Click on that and note what version it is. It should be 3.3. If it isn't, download the latest ACR from Adobe.com, rename whatever Camera Raw file that is there to Camera Raw.8bi_BAKUP, and extract the Camera Raw.8bi file to: C:\Program Files\Common Files\Adobe\Plug-Ins\CS2\File Formats folder. Close any PS windows and restart PS. If you still can't open a cr2 file, contact Adobe support.
PacAce
Joined Feb 2003
Jan 31, 2006 08:06 as a reply to  @ jfrancho's post |  #12
Just the fact that I can copy recipes from one image to several others with two clicks of the button so that I don't have to work on each set of images individually. It's more convenience than anything else. I also like the fact that I can use curves to adjust the raw image before conversion (something that ACR 3 also has but I'm still running ACR 2).
...Leo
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Jan 31, 2006 09:52 |  #13
STILL Free RSE is pretty good. RSEP is better, but the average PS user probably doesn't need to buy it.
EOSAddict
Book Committee Immortal
Jan 31, 2006 10:11 |  #14
Leo,
RSE has 2 click copy and paste and RSP has curves.... just to mention.
Al
My Gear, My Website: www.endofthetrailphoto​graphy.com (external link)
PacAce
Joined Feb 2003
Jan 31, 2006 11:15 as a reply to  @ EOSAddict's post |  #15
EOSAddict wrote:
Leo,
Yup, I tried using RSP once but that was on my old PC which I hardly use now. I'm running a Mac and RSP doesn't run on it. :confused:
...Leo
1,722 views & 0 likes for this thread, 10 members have posted to it.
2070 guests, 100 members online
