Thread started 25 Oct 2013 (Friday) 01:56
Lightroom moving pictures around and adding TIFF when exporting to photoshop
steelbluesleepr
Oct 25, 2013 01:56 |  #1
I just built a new computer (PC) and am using LR5, and it's doing something really annoying now. whenever I am done with the "develop" tab, I hit CTRL-E, which used to do nothing but open the image in photoshop. the photo would not move on the bottom tab and I knew exactly where I was when I go back to LR. Now it moves the photo to the end of the group I'm working on and adds a second copy of it, a TIFF file, directly next to it.
There must be a setting I have missed that will change this back. I tried searching, but didn't even know what this is called. Does anyone know what I'm doing wrong?
-Jayson- my flickr (external link)
In the bag: 5D mark II+Vello grio/10d+grip/Canon 17-40L/Canon 28-135/Canon 50 1.8/Canon 35-80 Macro Conversion/Vivitar 135 2.8 M42/Vivitar 28 2.5 M42/Yongnuo YN460II x3/Yongnuo RF-602 x3
Lowner
"I'm the original idiot"
Oct 25, 2013 02:45 |  #2
I use DPP before transferring to Photoshop. To switch from one to the other is impossible with the Canon RAW file, so DPP creates a TIFF version that I can open in Photoshop. I suspect you are doing the same.
Richard
Grizz
Gallery: 321 photos
Oct 25, 2013 04:07 |  #3
I think you may have changed the sort order in the Library Module. To have it behave like you want make sure its set to "Capture Time" That should work. Maybe. :)
Craig * Canon 7D Mark II * 60D * 10D * Tamron SP 150-600 f/5-6.3 Di VC USD * EF 400 5.6L USM * EF 17-40 4.0L USM * EF 70-210 4.0 * EF 28 2.8 * EF 50 1.8 MK1*Flickr (external link)
tzalman
Fatal attraction.
Oct 25, 2013 05:16 |  #4
First, what version of PSCS/ACR? Unless you have parallel versions (LR5.2 to ACR8.2) LR will create a tiff or psd.
Second, sort order by capture time puts the tiff at the end of the row. Sort order by name puts it next to the Raw.
Elie / אלי
steelbluesleepr
Oct 25, 2013 11:34 as a reply to  @ tzalman's post |  #5
I'm using LR5 and PS/CC
Lowner wrote in post #16397469 (external link)
I know it has to create TIFF files, i just don't want them to display in lightroom. If I go back and try to edit again, I have to look at the file name to make sure I'm working with the .cr2 file like I want to.
tonylong
...winded
Gallery: 60 photos
Oct 25, 2013 12:32 |  #6
steelbluesleepr wrote in post #16398277 (external link)
The Tiff shows up in Lightroom, that's how LR is designed to work when you use the "Edit In" function: the tiff is automatically incorporated into the LR Library.
Tony
steelbluesleepr
Oct 25, 2013 13:28 |  #7
tonylong wrote in post #16398434 (external link)
it used to not do that, and it's really annoying. there has to be a setting I can change to make it not put the tiff in my library
Grizz
Gallery: 321 photos
Oct 25, 2013 14:04 |  #8
If you open the image to edit in PS by using CTRL-E what do you do when your done editing in PS? If you do a SAVE then it will add the TIFF in LR, If you do a SAVE AS and choose a location to save to it will not add the TIFF in LR. But will add the TIFF or PSD or whatever you choose to save wherever you choose to save it. But leave it out of LR.
steelbluesleepr
Oct 25, 2013 14:18 |  #9
Grizz wrote in post #16398662 (external link)
I always do a "Save As" in photoshop. My issue is as soon as I hit CTRL-E in LR, before PS even finishes opening, it moves the image and adds another.
Grizz
Gallery: 321 photos
Oct 25, 2013 14:30 |  #10
Hmmm Mine does not work that way? If I CTRL-E an image into PS CC From LR 5.2 it does not add the tiff immediately in LR. Only adds it when I preform the Save from PS.When hitting CTRL-E Do you get the dialogue window that asks you if you want to render using lightroom or does it just open in PS?
Grizz
Gallery: 321 photos
Oct 25, 2013 14:40 as a reply to  @ Grizz's post |  #11
Could it be that LR 5 uses camera Raw 8.1 and PS CC is using 8.2 ( as is LR 5.2), Thus having to create a TIFF in LR before PS can edit it? Just guessing. :)
steelbluesleepr
Oct 25, 2013 14:46 as a reply to  @ Grizz's post |  #12
well, it is set to create a tiff rather than a PSD when exporting for editing, would that have anything to do with it? (I'm at work right now, away from my home computer so I can't test this theory until then).
tzalman
Fatal attraction.
Oct 25, 2013 14:50 |  #13
Grizz wrote in post #16398748 (external link)
Yes, if you are still on 5.0 update to 5.2. You should anyways, some nasty bugs were swatted.
And you can set a prefix for the tiffs in Preferences that will make it easier to separate the wolves from the sheep. I use the prefix "RGB".
Elie / אלי
steelbluesleepr
Oct 26, 2013 02:06 as a reply to  @ tzalman's post |  #14
I figured it out. the library was sorted by "latest added" rather than "capture time." changing that back made the pictures stop moving around. also the export script was set to create a TIFF, and changing that to .PSD stopped the adding of new files to the bottom tab.
Thanks for the help!
tonylong
...winded
Gallery: 60 photos
Oct 26, 2013 02:11 |  #15
Well, OK then, but I'm not sure about the tiff/psd thing! Lightroom at least by default adds a "version", a tiff or a psd, to your Library containing the Photoshop edits, although you can change your preferences around. I don't mind having the version/copy if I'm doing important work in Photoshop...
Tony
2,646 views & 0 likes for this thread, 5 members have posted to it.
1038 guests, 114 members online
