My 300 mm f2.8 lens has done 8.5 years hard work, almost invariably with a x2 Mk II extender attached. Initially I dismantled re-attached the extender every time I used the lens until, about 2 years ago I started to get problems with the extender and lens not coupling tight enough. After that I left the two coupled almost permanently. Now play has developed between the two and autofocus is beginning to fail once or twice every time I go out. It wasn't until I photographed the contacts on the lens and blew the images up that I discovered, to my horror, the extent of wear and tear on the lens. Has anyone else had this experience? If I replace the lens and extender, how can I guard against this in the future?
![]() | HTTP response: NOT FOUND | MIME changed to 'image/gif' | Redirected to error image by FLICKR |
lens3_A7607
lens2_A7608
lens1_A7609
