Thread started 30 Oct 2013 (Wednesday) 05:25
shooting school formal
pelooyen
Oct 30, 2013 05:25 |  #1
I am shooting a formal this Friday, with a mix of full length shots as well as waist high (couples and small groups.)
I have an 80cm soft box, and two umbrellas, one silver one white (both 60cm)
From what I have read is that I should have a main light off to the side, with the female closer to the side and a fill light on camera axis , a bit higher than the camera.
(both are flash based and using wireless remotes)
My thoughts are the soft box as the main and the silver umbrella as a fill, with an approximate ratio of 2:1 (main : fill)
Plan to use two cameras - one crop with 28-135 for full length and the 70-200 on a FF for closer.
Does this sound right
(happy if you point to relevant threads)
cheers, Paul
Flickr (external link) | My Website (external link) | Like me on Facebook (external link)
6D | 5Dc | 17-40mm L | 28-135mm IS USM | 70-200L f4 | 100mm f2.8 macro USM | MPE65 | MT-24EX | 580EX | Kenko extension tubes | 1.4x TC
| couple of umbrellas and softbox and other lighting stuff
Curtis ­ N
Master Flasher
Oct 30, 2013 06:16 |  #2
If you have enough room, the 70-200 on the 5D will be the only camera you need.
Keep it simple if you can.
Be careful with the group shots that people don't block the main light from one another.
783 views & 0 likes for this thread, 2 members have posted to it.
1504 guests, 136 members online
