FORUMS Photography Talk by Genre Critique Corner
Thread started 30 Oct 2013 (Wednesday) 12:18
Product test shots
CanonVsNikon
Joined Jan 2013
Oct 30, 2013 12:18 |  #1
Give me some critique on these test product shots. It's hard to keep things dust free, especially when flash sees everything.
These were in a mini photo booth box with flash in shoot thru umbrella on left side with white reflector on right. Use black plexiglass as base.
I know some of the reflections got cut off because my plexiglass piece was too small.
Shot manual everything. I believe flash output was 1/2 to 1/4 power with f-stop at f/8 to f/10
1
IMAGE: http://farm8.staticflickr.com/7429/10567473703_7d6218fe16_b.jpg
2
IMAGE: http://farm4.staticflickr.com/3831/10567210276_10ee5efda8_b.jpg
3
IMAGE: http://farm3.staticflickr.com/2872/10567207026_ed62ffffe8_b.jpg
4
IMAGE: http://farm4.staticflickr.com/3831/10567197606_006e952847_b.jpg
5
IMAGE: http://farm4.staticflickr.com/3773/10567196446_cdb8c6a113_b.jpg
lehmanncpa
Joined Aug 2012
Oct 30, 2013 12:44 |  #2
General comments:
1. Between photos #1 & #3, I prefer #1. The "GH2" is cut off on #3.
2. Dust specks can be removed in PP with a clone or heal tool. Takes some time, but it's worth it on shots like these were dust is very distracting.
3. Clean the lens using a Lenspen or similar carbon-based cleaner to remove smudges.
Specific photo comments:
Photo #1:
1. I like the angle, but you may want to zoom out a little more to capture more reflection.
2. Looks like a crack or fiber near the dial above "FullHD". Maybe remove in PP.
3. Lighting looks good. I like the shadows and reflections.
4. Maybe stop down to gain DoF to focus "GH2". This may have been done on purpose, but it may look better with a greater DoF.
5. Watch out for the dark shadow at the bottom of the silver strip on the grip. It would look better without the dark shadow there - it's not on the reflection.
Photo #2:
1. Not feeling the steep angle, although you are able to see more of the features on the top of the camera body.
2. Lighting is weak on top. Could use additional light above, near the hotshoe.
Photo #3: Same as #1, but I prefer #1 since "GH2" is not cut off.
Photos #4 & #5:
1. I like the lighting and lack of reflections on the body of the flashlight.
2. I prefer the angle of #5 as you can see the lens - which is the most important aspect of a flashlight.
3. On #5, you could have composed a little lower to include the entire reflection and reduce the space above the flashlight.
Overall a good series, but they just need some cleaning up.
Alex
Feedback
Photography (external link)
CanonVsNikon
Joined Jan 2013
Oct 30, 2013 13:06 |  #3
Thanks for your input. The "crack" above the Full HD is actually a hair. And yes dust is a problem. I have seen some shots here where there is absolutely no dust. Amazed at how things can get dust free.
I was at f8 and could have shot further away and cropped in post do give a broader DOF.
lehmanncpa
Joined Aug 2012
Oct 30, 2013 13:22 |  #4
CanonVsNikon wrote in post #16411143 (external link)
I don't mind shallow DoF with product shots as long as it's consistent. In these shots, it appears as though the front to the center is in focus and everything behind the center is OOF. I would either open up and create a shallow DoF where only the "LUMIX" is in focus and everything in front and behind are OOF, or create a greater DoF and have everything in focus.
Years ago when I used to do product photography, I would create a negative air space by placing 3 or 4 electric fans facing away from the product. It would keep dust away and was fairly effective for close macro work.
You've got a good setup here, just tweak it here and there and it'll be better.
Alex
Feedback
jefzor
Joined Jul 2013
Oct 31, 2013 01:21 |  #5
Looks pretty good to me, but yea, the dust needs to be adresses. Would be nice if you could get a bigger piece of plexiglass, that way you can use a lower angle without cutting off the reflection. Other than that, it really has a professional look about it.
www.jefpauwels.be (external link)
CanonVsNikon
Joined Jan 2013
Oct 31, 2013 08:33 |  #6
Thanks. Yeah dust is everywhere here in Colorado with our dry climate. It really is an issue with these shots. And a bigger plexiglass is definitely needed.
683 views & 0 likes for this thread
Product test shots
Latest registered member is lindahaynesss
811 guests, 209 members online
