Thread started 31 Oct 2013 (Thursday) 15:57
Speedlight Softbox
rivas8409
Joined Mar 2011
Oct 31, 2013 15:57 |  #1
Ok, I want to get a 24x36 softbox to use with my speedlights. I'm finding that even though my umbrellas give great soft light there's too much spill and I'm wanting to control the light more. My question to you all is which would you suggest I get; a speeding mount softbox (with a speedlight attachment of course) or an umbrella style where the light stand actually goes into the box?
Body: Canon 5DmkII│Canon M50
Glass: Tamron 35mm f/1.4│Canon 85mm f/1.8│Canon 24-105mm f/4L│Canon 135mm f/2L│Canon EF-M 22mm f/2.0
Lights: Flashpoint XPLOR 400PRO│Flashpoint Streaklight 360│Flashpoint Zoom Li-on│AB800
Results: WEBSITE (external link)FACEBOOK (external link)
gonzogolf
dumb remark memorialized
Gallery: 559 photos
Oct 31, 2013 16:00 |  #2
What is your triggering system? The umbrella style boxes are handy and you get a nice even spread of light, but you need to be using RF triggering of some sort.
protege
Oct 31, 2013 16:09 |  #3
I personally don't recommend the umbrella style softboxes where the light source is inside the softbox bouncing backwards towards the silver element before going through the white diffuser. #1 you're losing mobility meaning you can't tilt up & down too much with it. And, #2 if you don't have remote ettl control or any type of remote control, you're going to have to rip open the white diffuser every time you want to make a setting change.
frugivore
Gallery: 11 photos
Oct 31, 2013 16:33 |  #4
How about a parabolic umbrella?
IMAGE: http://farm9.staticflickr.com/8503/8340571374_a463ccd9bc_b.jpg
rivas8409
Joined Mar 2011
Oct 31, 2013 16:36 |  #5
I've currently got YN-603 triggers, and the Canon 540EZ and YN-560II (both manual) but I'm getting some YN-622's and a YN-568EX or 2 so I can have the E-TTL capabilities, HSS, and be able to manually control the flash from the camera menu. I've got them in my cart on Amazon and only waiting to decide on a softbox to press the checout button.
rivas8409
Joined Mar 2011
Oct 31, 2013 16:40 |  #6
frugivore wrote in post #16414380 (external link)
Never considered a parabolic umbrella to be honest. Seems kind of....big. ;)
gremlin75
Oct 31, 2013 18:18 |  #7
rivas8409 wrote in post #16414388 (external link)
Speedlites + 622c + umbrella style softbox (westcott and phottix both make them) + phottix multiboom = Amazing set up!!
I use two 568ex's mounted on a phottix multi boom (allows multiple lights to be mounted and allows tilting of the box) inside a westcott Apollo.
HERE is a link to the multi boom (external link) if you're interested. I think it was Elv (from flash havoc and here) that designed it for phottix. You can buy it from amazon or Adorama
draderusa
Joined Dec 2012
Oct 31, 2013 18:49 |  #8
protege wrote in post #16414322 (external link)
This completely solves the tilt issue: http://flashhavoc.com/​phottix-multi-boom/ (external link)
Also with something like the Westcott Apollo the zippers on the bottom easily open enough to give full access to the flash units without touching the front diffuser. A pair of $78 YN622C ETTL radio triggers makes even that easy task unnecessary. I don't disagree that this is slightly more involved than using a shoot through softbox with the flash mounted on the rear but you generally get one stop more light out of the reflective type like the Appollo since you are only shooting through one layer of diffusion material instead of the two layer diffusion necessary with shoot through softboxes to avoid a hot spot in the center.
Dave
EOS 7D Mark II, EOS T4i -- EFS 18-135 STM, EFS 10-22 USM, EF 40 f2.8 STM, EF 50 f1.4, 600EX-RT (3), YN-E3-RT, AD-360, FT16 (2), YN560II, YN622C (4), YN622C-TX
draderusa
Joined Dec 2012
Oct 31, 2013 18:52 |  #9
gremlin75 wrote in post #16414621 (external link)
Sorry Gremlin. Looks like I virtually duplicated your post. :D I started my reply before you posted then went upstairs to check my facts in person before hitting submit.
Dave
Nonnit
Gallery: 22 photos
Joined Oct 2012
Oct 31, 2013 19:00 as a reply to  @ draderusa's post |  #10
For control of spill I would go with gridded softbox rather than parabolic umbrella.
I have 90x90cm softbox with Y560II (1 or 2 depending on power needs) and Y603.
I have to open up the diffusion panel to adjust the flash, still a good setup.
https://photography-on-the.net …/showthread.php​?t=1335133
Nonnit
5DMKIII // 70-200mm f2.8 L II // 35mm f2.0 IS // 50mm f1.4 // 85mm f1.8 // 100mm f2.8 Macro // 135mm f2.0 L // stuff
Film: https://www.flickr.com​/photos/souloffilm/ (external link)
Film: https://www.instagram.​com/souloffilm/ (external link)
Digital: http://nonnitryggva.is (external link) //
frugivore
Gallery: 11 photos
Oct 31, 2013 20:31 |  #11
rivas8409 wrote in post #16414403 (external link)
That's the 86", but I have the 51" ones which are a better fit for speedlights. Without the diffuser panel, the light is similar to a gridded soft box, and doesn't eat up as much light as one. With the diffuser, you get the soft box look. Here is a sample of two speed lights in the 51" PLM with diffuser:
IMAGE: http://farm4.staticflickr.com/3771/9266663531_1ea6371bc1_b.jpg
rivas8409
Joined Mar 2011
Nov 01, 2013 18:49 |  #12
No denying it's nice light from that PLM but what I'm wanting to use this for (on location) a huge parabolic is nothing more than a huge sail. Can't tell you how many times a small breeze has caught my umbrella and sent it hurling towards the ground. I have since added some weighted bags to minimize that but still...51" of open umbrella can produce a lot of lift with a breeze! Hahaha!
4,554 views & 0 likes for this thread, 7 members have posted to it.
Speedlight Softbox
1361 guests, 131 members online
