Thread started 01 Nov 2013 (Friday) 16:31
Smoother lighting
quadwing
Gallery: 6 photos
Joined Sep 2009
Nov 01, 2013 16:31 |  #1
Hi POTN,
I notice in some of my photos, I'll get a bit of a harsh transition of light--although the light is soft, when it starts going into the darks, it gets grainy looking and awkward.
How do you combat that? I've tried different positions, but I only have one light and a reflecting umbrella.
Wat do?
Example:
IMAGE: http://i.imgur.com/GpNdxcA.png
Camera gear: Canon 5D Mark IV | Canon 24-70mm f/2.8L II | Canon 70-200mm f/2.8L II | Lights: Elinchrom Ranger RX Speed AS
BrickR
Joined Mar 2011
Nov 01, 2013 17:47 |  #2
Sounds like you're saying you want more wrap-around with your light. Try:
1. Put the umbrella closer. This will make the light source bigger.
2. Try shoot through instead of bounce if possible.
3. Zoom out your flash if possible.
My junk
The grass isn't greener on the other side, it's green where you water it.
quadwing
Gallery: 6 photos
Joined Sep 2009
Nov 01, 2013 18:30 |  #3
BrickR wrote in post #16417069 (external link)
Exactly, but I'm mainly looking to minimize that botchy and grainy look that comes with the shadow transition.
1. I can do that!
2. Definitely can do as well.
3. What does zoom even do? /google
The ­ Loft ­ Studios
Nov 01, 2013 18:44 |  #4
quadwing wrote in post #16417145 (external link)
When you are "pixel peeping" at that close of a magnification, several things will come into play, one of them being the quality of your camera.....
Large Medium Format -vs- 35mm DSLR Format
Full Frame DSLR -vs- Cropped
High Quality Lenses -vs- Regular or Low Quality Lenses
Newer type camera -vs- Older type Camera (EXAMPLE: Canon 20D -vs- Canon 7D :: Both are cropped frame cameras, but the quality of image that each produces at the same given situations, are like night and day...)
**Sometimes a Lower ISO (if possible) can combat this problem if the original was shot at a higher ISO
Although some of what you show can probably be adjusted in PhotoShop, the true quality comes down to the Camera and Lens.....
MARK
quadwing
Gallery: 6 photos
Joined Sep 2009
Nov 01, 2013 19:56 as a reply to  @ The Loft Studios's post |  #5
Well, I shot it with a 7D and 24-70. I mean, I don't think quality should be bad. ISO was 100 I think.
Hm. Any photoshop techniques in mind for photoshopping this issue out?
dmward
Gallery: 29 photos
Nov 01, 2013 22:33 |  #6
The example you provided is B&W. What blotchiness I could see, and its subtle is likely skin undertones and the way they translate to B&W tonality which will depend on how you do your B&W conversion.
Generally these situations are dealt with in post processing.
starlights
Gallery: 16 photos
Joined Apr 2011
Nov 10, 2013 23:24 |  #7
Bounce Cards and powder based makeup.
Submariner
Joined May 2012
Nov 11, 2013 07:35 |  #8
I had a similar issue shooting an older woman circa 44 years old.
I discovered by using a big Octa softbox ( 1.4m diam), positioned as close as possible made a huge difference. It softened the skin - bleached out wrinkles, blotchy skin, and cellulite!
I then bought 2x YN 560 II ( very cheap £41 each manual flashes ) and used them with 2x £5 ebay shoot through brollies )
The more lights and the bigger and closer the light soirce, the smoother the skin!
All you need then is a light meter to balance the 430ex II
Canon EOS 5DS R, Canon EF 70-200 F2.8 L Mk II IS USM, Canon EF 70-300 F4-5.6 L IS USM, EF 40mm F2.8 STM , RC6 Remote. Canon STE-3 Radio Flash Controller, Canon 600 EX RT x4 , YN 560 MkII x2 ; Bowens GM500PRO x4 , Bowens Remote Control. Bowens Pulsar TX, RX Radio Transmitter and Reciever Cards. Bowens Constant 530 Streamlights 600w x 4 Sold EOS 5D Mk III, 7D, EF 50mm F1.8, 430 EX Mk II, Bowens GM500Rs x4
quadwing
Gallery: 6 photos
Joined Sep 2009
Nov 12, 2013 00:53 as a reply to  @ Submariner's post |  #9
I was thinking about buying a couple of monolights, stands and soft boxes exactly for this purpose.
Submariner
Joined May 2012
Nov 14, 2013 20:03 |  #10
quadwing wrote in post #16444478 (external link)
Well it certainly works but be very careful !
You will get addicted and its an expensive addiction!
Or You could cheat.
Stay as you are, and use "portraiture" editing s/w - it solves 98 % of your problems!
dmward
Gallery: 29 photos
Nov 14, 2013 22:58 |  #11
Learn about feathering, wrap, and other techniques that help you apply light from a source onto a subject.
There have been some outstanding portraits shot with a single umbrella and speedlite. It just take time to learn how to control your light to get the result you are after.
If you change light source and modifier, you'll restart the learning curve.
2,134 views & 0 likes for this thread, 6 members have posted to it.
Smoother lighting
1452 guests, 127 members online
