Thread started 31 Jan 2006 (Tuesday) 05:57
Not responding?
dewmuw
Joined Jul 2002
Jan 31, 2006 05:57 |  #1
I am probably paranoid in that I back up to DVD (2 copies) and store off-site. However, I was just looking back for something on DVD and kept getting the message "This programme is not responding" when I tried to access a particular folder. Could it be that the folder contains too many images? Help!
Damian Waters
www.drumimages.co.uk (external link)
hemuni
Jan 31, 2006 06:06 |  #2
Are you using a mac?
On a pc i would try restarting the computer.
If that doesn't help try to scan the dvd with scandisk (if you have a pc) to see if there are any disk-errors.
((¯`•.¸hemuni¸.•´¯)) 1000D • 85F1.8 • 50F1.4 • 28F2.8 • 18-55IS • YN565EX - POTN gallery
EOSAddict
Book Committee Immortal
Jan 31, 2006 06:10 |  #3
What programme were you using to access the DVD? Win Explorer? As above, try a restart... if that doesnt work try restarting in safe mode
Al
My Gear, My Website: www.endofthetrailphoto​graphy.com (external link)
dewmuw
Joined Jul 2002
Jan 31, 2006 06:26 |  #4
Thanks for the tips. I'm using a PC.
I store on an external hard drive at home and that doesn't have a problem. Only when I put the folder on DVD and then try an access it does it not work.
Damian Waters
EOSAddict
Jan 31, 2006 06:52 |  #5
There are some limits to the ISO file system used on DVDs and CDs, I think for example there is a limit on how many nested directories you can have and a limit on the absolute (ie full path) filename length...
Al
jfrancho
Jan 31, 2006 07:57 |  #6
Is it like this on both copies? If not, it's more likely a corrupted disk. I've had this happen.
Ikinaa
Joined Jul 2003
Jan 31, 2006 08:01 as a reply to  @ jfrancho's post |  #7
The disk is probably corrupted. I've had this also.
Do you have a second DVD-reader to try?
Most often, when I can't read a DVD in the Reader, I put it in the Writer and that one can read it (sometimes...)
www.ikinaa.net (external link)
dewmuw
Joined Jul 2002
Jan 31, 2006 08:21 |  #8
It isn't a disc error - it happens on 3 dvds I have made. I've also tried it on a couple of DVD-readers in the office - to no avail.
Damian Waters
dewmuw
Joined Jul 2002
Feb 02, 2006 11:54 |  #9
So I had a brainwave and thought that if I could copy the files from the DVD to my laptop harddrive.......
"Cannot copy ****: Data error (cyclic redundancy check)"
So I've googled that and am more confused than when I started. Help!!! :(
Damian Waters
queenbee288
Gallery: 17 photos
Joined Dec 2004
Feb 02, 2006 12:54 |  #10
Right click on the properties of the file. See it is labled read only.
claudermilk
Joined Jun 2005
Feb 02, 2006 13:43 as a reply to  @ dewmuw's post |  #11
Sounds like a disk error to me. I ran into that once, I found a freebie utility that I was able to read the files back to my HD (IIRC, ISO Buster). Fortunately the trashed files were in a HTML index of the disk.
Since the files are on a DVD, by default they will all be read only.
20D/BG-E2/Katz Eye | Tokina 12-24/4 | 24-70/2.8L | 50/1.8 Mk I | 70-200/2.8L | PD70X
tim
Light Bringer
Feb 02, 2006 17:46 |  #12
If you were trustly paranoid you'd have two copies offsite on hard drive, you're much less likely to lose data that way. I don't trust optical media for backup of important data.
SkipD
Joined Dec 2002
Feb 02, 2006 18:03 |  #13
I doubt that this has anything to do with this particular problem after reading through the thread, but thought I'd just throw it out because a lot of folks don't know this. The root directory of ANY media can have only so many files (and I have forgotten the number) on it. You could have a 10 gigabyte drive and it will say that it's full when you've put too many files in the root directory (folder) - regardless if the drive is 95% empty. This goes for hard drives, CD's, or any other media format.
Skip Douglas
dewmuw
Joined Jul 2002
Feb 03, 2006 04:03 |  #14
Thanks for the advice everyone - I'll try and find a utility on the web.
Damian Waters
dewmuw
Joined Jul 2002
Feb 04, 2006 06:07 |  #15
Good news - ISOBuster worked a treat and I have my files back! Thanks for the advice.
Damian Waters
2,416 views & 0 likes for this thread, 11 members have posted to it.
Not responding?
2083 guests, 101 members online
