I bought a couple if Yongnuo flash triggers and they don't always work. I want to buy something that is dependable but won't break the bank. Could anyone make some suggestions on what to purchase. Pocket Wizards?????
Nov 03, 2013 21:02 | #1 I bought a couple if Yongnuo flash triggers and they don't always work. I want to buy something that is dependable but won't break the bank. Could anyone make some suggestions on what to purchase. Pocket Wizards????? Website
BrickR Cream of the Crop 5,935 posts Likes: 115 Joined Mar 2011 Location: Dallas TX More info | Nov 03, 2013 21:12 | #2 Which triggers did you get? My junk
Nov 03, 2013 21:18 | #3 mdaddyrabbit wrote in post #16422240 I bought a couple if Yongnuo flash triggers and they don't always work. I want to buy something that is dependable but won't break the bank. Could anyone make some suggestions on what to purchase. Pocket Wizards????? What functionality do you need in the trigger? If you just need a manual trigger, Phottix Strato II Multi is a great reliable choice. You can get a pair for around $100. If you need more control (E-TTL, remote zoom, HSS, SCS) then I recommend the Phottix Odin. Reliable and also compatible with the Strato II receivers for mixed E-TTL/manual use. If that's over the budget you can get the cheaper YN-622 which supposedly is a reliable option but you said you don't want YongNuo. http://www.twilightandtulle.com
Nov 03, 2013 21:18 | #4 |
Nov 03, 2013 21:20 | #5 amirg wrote in post #16422278 What functionality do you need in the trigger? If you just need a manual trigger, Phottix Strato II Multi is a great reliable choice. You can get a pair for around $100. If you need more control (E-TTL, remote zoom, HSS, SCS) then I recommend the Phottix Odin. Reliable and also compatible with the Strato II receivers for mixed E-TTL/manual use. If that's over the budget you can get the cheaper YN-622 which supposedly is a reliable option but you said you don't want YongNuo. Not having TTL control is not a big thing, I can change my settings manually. I just want dependability with I press the shutter. Website
sirquack Goldmember More info | Nov 03, 2013 21:20 | #6 OP, please let us know what triggers and the specific problems you are having. I have had my Yongnuo 622 triggers for a few months and have had no issues. I want to make sure what the type of issue you are having so I can either replicate or try to diagnose the issue. Name is Ron.
Nov 03, 2013 21:21 | #7 mdaddyrabbit wrote in post #16422280 Yongnuo RF600TX and Yongnuo RF602RX I see. The YN622 system should be much better in terms of reliability and functionality. I would start there and look into Phottix as a more refined alternative (with a price difference reflecting that). http://www.twilightandtulle.com
Nov 04, 2013 07:37 | #8 sirquack wrote in post #16422288 OP, please let us know what triggers and the specific problems you are having. I have had my Yongnuo 622 triggers for a few months and have had no issues. I want to make sure what the type of issue you are having so I can either replicate or try to diagnose the issue. I don't represent Yongnuo, but I am a recovering IT guy and it might be a simple issue you can solve without having to replace your current triggers. They will fire the flash every 3rd or 4th time. Brand new enloops batteries int them. Last shoot I could not get neither one to fire. I replaced the batteries in both the receiver and the transmitter but they would not fire. Later that night I tried them again and didn't work at first but after 20 minutes or so messing with them they fired 2 times and stopped again. Been in my bag every since. Website
sirquack Goldmember More info | Nov 04, 2013 07:44 | #9 Sorry for the redundant question yesterday. I must have not refreshed my page before I sent off my query. I would second the folks who mention the Yongnuo 622. I can personally vouch for the fact that they have been reliable when I use them. They just keep working. Name is Ron.
Trailboy Senior Member 541 posts Likes: 8 Joined Jan 2009 More info | Nov 04, 2013 07:44 | #10 mdaddyrabbit wrote in post #16423056 They will fire the flash every 3rd or 4th time. Brand new enloops batteries int them. Last shoot I could not get neither one to fire. I replaced the batteries in both the receiver and the transmitter but they would not fire. Later that night I tried them again and didn't work at first but after 20 minutes or so messing with them they fired 2 times and stopped again. Been in my bag every since. Yn 600/602s are very reliable, just as reliable as my 622s.
sirquack Goldmember More info | Nov 04, 2013 07:55 | #11 Trailboy may be onto something. I only use regular batteries in my triggers. If they used more juice to run them like a flash, I might try rechargables, but I am still on my first set of batteries in the triggers. I have heard several people say they are good for thousands of shots before needing to be changed. Name is Ron.
Nov 04, 2013 07:57 | #12 Trailboy wrote in post #16423076 Yn 600/602s are very reliable, just as reliable as my 622s. I've used them profesionaly for several years, and have never had a problem. Do not use rechargeable batteries in them, especially non recharged brand new eneloops. Use duracell type batteries as they run at higher (1.5v vs 1.2v) voltage. This is widely known. Or you may have duff units. Do not necessarily think that paying more will bring reliability. You would have the same problems, if not worse, with rechargeables in 622s. So you are saying don't use any type of rechargeable batteries in the Yongueo equipment? Website
Trailboy Senior Member 541 posts Likes: 8 Joined Jan 2009 More info | Nov 04, 2013 08:14 | #13 Triggers, no. Don't.
Nov 04, 2013 08:39 | #14 What kind of battery life does one get using regular alkaline batteries? Website
Trailboy Senior Member 541 posts Likes: 8 Joined Jan 2009 More info | Nov 04, 2013 08:55 | #15 A long time, more than enough to justify not using rechargeable anyway.
| Latest registered member is semonsters 1511 guests, 131 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
