Thread started 04 Nov 2013 (Monday) 11:50
Going To Israel. Need Adaptor/Converter Recommendations For Charging
DavidSR
Nov 04, 2013 11:50 |  #1
Hello,
I will be going to Isreal on 11/11 and need to buy an adaptor/converter to charge my camera battery and tablet. I have seen one at Best Buy for $40, but I'm not sure which prongs I need for use in Israel. The one at Best Buy said it was for use in the UK, Europe and I'm not sure where else. Would that work in Israel?
It also had a converter built in so I don't fry my batteries, which was 220V to 120V. Would that be a good and safe option to use? Or are there any better ones at Fry's? I'm not looking to spend much on it, but I also don't want to fry my batteries or tablet.
Would preferably like a unit that is an adaptor and converter built into one unit.
Thank you for your input!
T4i, 18-55mm IS, 55-250mm IS, 50mm 1.8, 3 Vivitar 285HV's and a set of Cactus V5 Triggers!!
Jon
Joined Jun 2004
Nov 04, 2013 12:07 |  #2
Your camera's battery charger, and probably also your tablet's, work fine on anywhere from 100-240V 50 or 60 Hz, so essentially anywhere in the world. So you don't need a converter. Their ungrounded plug is the standard "C" type, used in most of Europe. Here's a handy site for more info on what outlets and voltages are used where: http://www.kropla.com/​electric2.htm (external link)
Jon
Cocker Spaniels
airdima
Nov 04, 2013 12:16 |  #3
just as Jon suggested, check the voltage range on your chargers. most likely they will support the 220v as well
as for the wall socket, unless you are going to stay in a very old apartment which has ungrounded sockets, this http://electricaloutle​t.org/type-h (external link) is the most common socket type
assuming your chargers support 220v, all you need is a simple http://electricaloutle​t.org/type-a (external link) to http://www.kropla.com/​electric2.htm (external link) adapter
My Facebook Page (external link)
My Website (external link) || My Blog (external link) (Hebrew)
Canon ­ Bob
Nov 06, 2013 03:21 as a reply to  @ airdima's post |  #4
European style plugs work fine in the majority of Israeli socket outlets.
Bob
1Dx2 (2), 5DSR, 1Ds3, 1D4, 5D2(590nm), 5D2(720nm) EF600 EF400 EF300-II EF300 EF200 EF200-II EF180L EF135L EF100 EF85-II EF50L TS-E17/4 TS-E24L-II TS-E45 TS-E90 MP-E65 EF70-200-II EF24-70/2.8-II EF16-35/4 EF8-15/4 EF11-24/4 Zeiss 15/2.8 21/2.8 25/2 28/2 35/1.4 35/2 50/2 85/1.4 100/2 135/2 T/C's L-SC & a WIFE!
Phoenixkh
a mere speck
Gallery: 67 photos
Joined May 2011
Nov 06, 2013 07:04 |  #5
Our retirement Plan B involves a move to Indonesia. I was surprised to learn how flexible my Canon battery charger is. I thought I'd need a new battery charger so I contacted Canon tech service. Just as Jon stated, there will be no problem in Indonesia. I was a bit surprised it was the flexible.
I suspect my laptop is the same but I'll have to check the specs on the charger.
Kim (the male variety) Canon 1DX2 | 1D IV | 16-35 f/4 IS | 24-105 f/4 IS | 100L IS macro | 70-200mm f/2.8L IS II | 100-400Lii | 50 f/1.8 STM | Canon 1.4X III
RRS tripod and monopod | 580EXII | Cinch 1 & Loop 3 Special Edition | Editing Encouraged
digital ­ paradise
Awaiting the title ferry...
Gallery: 157 photos
Nov 07, 2013 07:04 |  #6
Canon Bob wrote in post #16428487 (external link)
Bob
I picked up a universal adapter at London drugs for about $30.
Image Editing OK
DavidSR
Nov 07, 2013 16:56 |  #7
Thank you for all the responses! That makes things easier now since I won't need to spend extra on an adapter and converter.
MDJAK
Nov 07, 2013 19:30 |  #8
And if you call BH customer service, I'll go out on a limb and say they'd know the answer. ;-)a
3,626 views & 0 likes for this thread, 7 members have posted to it.
1600 guests, 140 members online
