Thread started 04 Nov 2013 (Monday) 20:02
B&W XS Pro CPL filter ?
Diver-Down
Nov 04, 2013 20:02 |  #1
Didn't get any replies in the Accessories section, thought I would try here:
How does the B&W XS Pro Kaseman CPL filter compare to the Slim MRC or the discontinued Kaseman Slim MRC F-Pro as far as Vignetting goes ?
I'm looking to use it on a 10-22 and it looks like the XS Pro is the way to go since it has front threads to accepts a lens cap but just want to be sure it's still slim enough to not get in the way.
amfoto1
Nov 04, 2013 20:29 |  #2
Well, you really don't need a slim filter on the 10-22mm. A regular B+W filter is slim enough, won't vignette at all. I have been using both B+W MRC F-Pro and Kaesemann without any problems. So, unless you want the improved "Nano" coatings of the XS Pro CPL, I'd save some money.
ROGERWILCO357
Joined Sep 2009
Nov 05, 2013 03:54 |  #3
I second the motion save the cash unless you really want that nano coating . I have both and love them..
EOS 5DMKII gripped;EOS 7D;30D:Rebel Xti Digital;24-105L,70-200 f/2.8L.II,85mm f1.2L.II,16-35Lmk2, SP AF90mmF/2.8DI,28-135mm x 2,580EX II-430ExII with Pocket Wizards II,(Adobe CS5)
Diver-Down
Nov 05, 2013 06:14 as a reply to  @ ROGERWILCO357's post |  #4
That's interesting, I always thought that you needed a slim mount for the ultra wides.
I often stack a ND with a CPL on my 17-50 set up but I figured stacking would be out with the 10-22. So what are the chances I would be able to get away with stacking a thin CPL and a ND filter ? I don't think they make a thin ND filter.
eddie3dfx
Joined Sep 2009
Nov 05, 2013 06:31 |  #5
Will you need to step up on a 10-22 to avoid vignetting? Or buy the b+w extra wide polarizer
I read somewhere that people don't recommend using a polarizer on the 21mm zeiss due to uneven light in the sky.
I use a non slim 86mm b+W KSM MRC polarizer on my 24-105 and it's great... with a uv filter it vignettes.
I have nano UV filters and regular MRC Filters and honestly I can't tell the difference.
Canon 6D, Canon L 24-105, Zeiss Distagon 28mm 2.8, Planar 50mm 1.4, Planar 85mm 1.4, Sonnar 135mm 2.8 & Zeiss Mutar 2x, Canon 50mm 1.8
http://www.edwinraffph​otography.com/ (external link)
ejenner
Gallery: 98 photos
Joined Nov 2011
Nov 05, 2013 15:21 |  #6
Diver-Down wrote in post #16425712 (external link)
Two regular filters just vignette at 10-12mm. The problem with ND and CPL filters is that they are usually a bit thicker (especially the 8-10 stop ones) than UV filters, so even with a slim CPL, you probably won't be able to stack them at 10mm.
Thus, slim CPL will allow you to go wider than a regular one when stacked with an ND so you stack them 'often', then I guess the slim will be beneficial. You'll still be able to go fairly wide with an ND and regular CPL, but I don't remember how wide though. I'd have to check, but I'm guessing in the 12-14mm range. If 14mm, it may not be enough over the 17-50.
Edward Jenner
5DIV, M6, GX1 II, Sig15mm FE, 16-35 F4,TS-E 17, TS-E 24, 35 f2 IS, M11-22, M18-150 ,24-105, T45 1.8VC, 70-200 f4 IS, 70-200 2.8 vII, Sig 85 1.4, 100L, 135L, 400DOII.
http://www.flickr.com/​photos/48305795@N03/ (external link)
https://www.facebook.c​om/edward.jenner.372/p​hotos (external link)
Diver-Down
Nov 05, 2013 16:07 |  #7
I'll mainly be shooting waterfalls with this set up and I only add a 3 stop ND for brighter conditions. I'm thinking it's worth me going to a slimmer filter if allows me to stack and get 12-14mm out of it. Most of my waterfalls are surrounded by trees and dark areas so a little vignetting would probably go unnoticed and if some does show up it can always be dealt with in post.
Thanks for the input everyone
2,438 views & 0 likes for this thread, 5 members have posted to it.
1332 guests, 137 members online
