Thread started 05 Nov 2013 (Tuesday) 12:01
Your thoughts on Vignette
CanonVsNikon
Joined Jan 2013
Nov 05, 2013 12:01 |  #1
What are your thoughts regarding vignetting in post?
I used to use it pretty heavy in the past but now am a bit more judicious. Most of my shots do have some vignette as I don't like bright edges
These are examples of the heaviest I set it at now, probably -10 to -15 in LR
IMAGE: http://farm3.staticflickr.com/2817/10321800596_34dd5f2365_b.jpg
IMAGE: http://farm4.staticflickr.com/3666/10320371885_1b002f6e1c_b.jpg
And here are stronger vignettes
IMAGE: http://farm6.staticflickr.com/5089/5258835468_22fc981dab_b.jpg
I guess tastes change once you start doing it so much.
sapearl
Gallery: 152 photos
Nov 05, 2013 12:04 |  #2
It has its place but I would certainly use it sparingly as you have decided, otherwise it becomes pretty cliche. In my own shooting style I lean more towards DOF control: shallow DOF to concentrate attention on close in subjects, or even farther objects with long lenses.
MY WEBSITE (external link)- MY GALLERIES (external link)- MY BLOG (external link)
Artists Archives of the Western Reserve (external link) - Board
Owain ­ Shaw
Some of my best friends are people.
Gallery: 67 photos
Nov 05, 2013 15:17 |  #3
I use a strong one, but have also been told repeatedly (here) not to. I use it because I like it and none of my clients have told me not to. I could probably try a less strong one, such as in your examples that look like a happy medium.
| New website. (external link) |
| Gear | Flickr (external link) |
nathancarter
Gallery: 32 photos
Nov 05, 2013 15:28 |  #4
I use a small amount of dark vignette on certain images, generally only on moody portraits. Definitely not on all images.
White vignette is right out.
ejenner
Gallery: 98 photos
Joined Nov 2011
Nov 05, 2013 15:39 as a reply to  @ nathancarter's post |  #5
Can you control the shape in LR, like make it oval instead of round? To me the biggest problem is exemplified by image #2 where the corners are dark, but the center bottom of the image is bright.
If you can add some 'shape' to it, I think it is better. Personally if I have to do anything more than a very,very subtle one, I bring the shot into PS and work the image and crease a completely custom vignette which may also use luminosity masks to create it.
The last one looks OK to me, just becasue a flash was obviously used and one expects the brightness to fade away from the subject (although the bright spot on his head is another matter).
Edward Jenner
5DIV, M6, GX1 II, Sig15mm FE, 16-35 F4,TS-E 17, TS-E 24, 35 f2 IS, M11-22, M18-150 ,24-105, T45 1.8VC, 70-200 f4 IS, 70-200 2.8 vII, Sig 85 1.4, 100L, 135L, 400DOII.
http://www.flickr.com/​photos/48305795@N03/ (external link)
https://www.facebook.c​om/edward.jenner.372/p​hotos (external link)
CanonVsNikon
Joined Jan 2013
Nov 05, 2013 15:44 |  #6
ejenner wrote in post #16427081 (external link)
Yes there are ways to control the vignette. In LR I use the default "Highlight" vignette. If you use the Paint or other variation it will vignette more symmetric and even. And there are a host of other options to help control it light feather and midpoint.
In LR 5 you now have a radius tool that can control even more. I have not used it but have seen videos and it looks quite nice
nathancarter
Gallery: 32 photos
Nov 05, 2013 15:47 |  #7
To some extent, yes. There are four sliders in the current version of Lightroom (actually ACR): Amount (how dark or white), Midpoint, Roundness, Feather.
CactusJuice
Nov 05, 2013 17:01 |  #8
My $0.02, I vignette sometimes. Of course it depends on the subject. In most cases I don't like it to be noticeable.
Tiberius
Nov 05, 2013 19:57 |  #9
I usually use a bit of a vignette. Just to darken the edges a little. If it's noticeably a vignette, then it's too much.
My photography website!PHOCAL PHOTOGRAPHY (external link)
Thomas ­ Campbell
Joined Jun 2010
Nov 05, 2013 20:10 |  #10
One of my biggest regrets with my early photography/editing was heavy use of vignettes.
If I had time, I would go back and reedit all those weddings. :(
Houston Wedding Photographer (external link)
Houston Sports Photographer (external link)
Current Gear List
M_Six
Gallery: 59 photos
Nov 05, 2013 20:51 |  #11
I like it with landscapes and portraits to draw attention to the subject if it's done very subtly. But if you look at an image and the vignette is obvious, it's overdone, IMO. It should be subtle enough to go unnoticed except to the subconscious.
On a full size image I pull a wide oval around the subject, feather to 300-400 pixels, reverse the selection, use the selection to create a new layer, then change the new layer blend mode to Multiply. Then I reduce opacity way down until it's just a hint. If it turns out I don't like it, I just dump the layer. It doesn't always work, but it's often worth trying.
Mark J.
Gear
John37
Joined Feb 2012
Nov 05, 2013 21:21 |  #12
Owain Shaw wrote in post #16427004 (external link)
Same here. Other photographers hate my using them. But I like them and continue to use them as I like. :lol:
"The most endangered species? The honest man!' ~ Neil Peart
5Dii, 5Dc, 135L, 70-200 f2.8, 24-105L, 17-40L, 85 f1.8, 50 f1.8, 430exll, Yongnuo 560ll x 2, wife, 2 kids :cool:
http://www.flickr.com/​photos/dajaphotographs​/ (external link)
goldboughtrue
Nov 06, 2013 00:01 |  #13
I almost never use it or at least use just a bit.
http://www.pbase.com/g​oldbough (external link)
5D II, Canon 100 macro, Canon 70-200 f/4L, Canon 24-105 L, Canon TS-E 45, Sigma Art 35mm f/1.4
jefzor
Joined Jul 2013
Nov 06, 2013 00:08 |  #14
I like it in moderation. If you can notice it's been there, it's too much imo. The examples you posted look good to me.
www.jefpauwels.be (external link)
Tiberius
Nov 06, 2013 02:17 |  #15
jefzor wrote in post #16428275 (external link)
I agree with every thing you said (in that post, at least. I'm sure we have wildly differing opinions on other stuff.)
3,093 views & 0 likes for this thread
Latest registered member is ArcticRose
726 guests, 288 members online
