Hi,
I recently acquired a 5D online through a reputable brick and mortar shop.
I test shot at f22 (using the 50 1.8 II) to see how dirty the sensor was. I was not expecting crystal clean, but I found more than dust spec. I just want to know if I have to deal with a scratch sensor or a lousy cleaning that left residue. I know the dot are dust that I can probably blow using a rocket blower, but I am more concern with the horizontal linear stripes.
If it is just lousy cleaning, I will have it clean, but if it is scratch I will return it.
Here is the shot in question
![]() | HTTP response: 403 | MIME changed to 'text/html' | Byte size: ZERO | PHOTOBUCKET ERROR IMAGE |
Here it is again, but with increase contrast and reduce brightness using GIMP.
If you clock on them you can see the larger version of it.
I can post the raw somewhere if that could be useful, but I don't know where I can do that (e.g. photobucket).
Best regards,
