frugivore wrote in post #16435527
I'm pretty sure that auto ISO tries to keep the ISO as low as possible until the required shutter speed drops below the set limit. Then the ISO goes up one stop. Is this not correct?
It may well be correct, but dmitrim said that he always shoots in manual. As soon as you set auto ISO you are no longer shooting in manual, you are in an auto mode that will adjust exposure as it sees fit, and can be altering it based on a change in the tone of a background or subject, whilst the actual exposure wanted has NOT changed.
Therefore, no, auto ISO does NOT do the same as shooting manual.
Trent Gillespie wrote in post #16435539
Auto ISO works in Manual exposure mode as well. It selects the lowest ISO possible, while retaining an adequate exposure.
No, it doesn't.
Yes, you can set the auto ISO with the mode set to "M", but it is then no longer manual, as the camera is altering the exposure. Shooting "manual" means setting all three components yourself and shutting the camera out of the decision making process. "M with auto ISO" is another auto mode like Av or Tv, that just happens to use the "M" setting to access it. It is not "manual".
To go back to the OPs question. I don't like auto ISO, but I accept that it does have uses. I never use it on my 40D (which I believe has it in a more primitive form) and have used it twice on my 5DIII in over a year of ownership. Both times I used it I was shooting in a theatre and stage lighting was altering exposure significantly from shot to shot, so manual was not an option. I wanted the camera to handle exposure for me, but needed the aperture fully wide and wanted to set my minimum shutter speed myself. So I set the aperture wide open, shutter speed where needed from shot to shot (slower for stationary actors, faster for dance routines) and let the camera adjust ISO to cope with the stage lighting.
That allowed me to keep ISO as low as possible, and it was really useful in that situation. In other situations though, I am happier in manual, or using Av or Tv with EC, depending on the requirements.
As with all such features, auto ISO is a tool in the toolbox, it may or may not be one that you want / need to use much, but it does have its uses and can perform a function that cannot be achieved another way.
