Thread started 07 Nov 2013 (Thursday) 18:03
Dual Monitor set up for Lightroom only - which two sizes?
Engineersix
Joined Oct 2013
Nov 07, 2013 18:03 |  #1
Hi all,
I have read a few threads with answers to similar questions, I hope no one minds a specific, albeit similar query from me...
I am buying a new desk top for Lightroom work - my old family laptop isn't really up to the job. Base spec will be along the lines of:
i5 3.2Ghz processor
240GB SSD for software and live work
500GB HDD for archiving etc
8Mb RAM
This is sucking up most of the budget, but I have allowed for a 24" Dell U2412M IPS monitor. The PC has two video outputs, one DVI and one VGA - I am considering buying a second monitor also.
I anticipate using the 24" as my main 'Develop' screen, with the second monitor, (20"?) for a live version of the image I am editing - not sure why, but that is what I have in my head...
The laptop I am currently using has a 15" screen and with the side tool bars there isn't masses of space left for the actual image, so the thought of a nice big dedicated version is quite appealing.
My question(s) are:
Do I even need a second monitor to go alongside the 24"?
Does this use of two monitors sound sensible - or is there a better way?
Which should I feed from the higher quality DVI and which from the VGA?
If I feed the 'live final image' to the smaller screen using the DVI, am I wasting money on the, (for my budget) high spec U2412M if I feed it from the VGA port?
Dang, that's more questions than I anticipated when I started typing the post...
Maybe an easier question is - how do you guys recommend I configure two monitors, one DVI and one VGA and what sizes/specifications do you recommend?
I would really appreciate your experiences and suggestions.
regards,
Rob
Be gentle, I'm new to all this!
My Flickr: http://www.flickr.com …3/sets/72157636​178269434/ (external link) The aim is to show improvement as you scroll down!
tzalman
Fatal attraction.
Nov 08, 2013 02:38 |  #2
My own personal experience:
My computer is a laptop. Attached to it I have a 23 inch, 1080x1920 monitor which I use only for photo work. Initially I would have LR on the laptop with a secondary image filling the screen of the 23", but I found it annoying to be constantly looking back and forth between the two. Now I use only the 23" with only the right LR Develop panel open, Shift+F used to hide the menu bar and the T key used to toggle the tool bar as needed (usually off). This gives me an adequately large image area plus editing interface on one monitor. YMMV.
Elie / אלי
René ­ Damkot
Nov 08, 2013 06:11 |  #3
I use a second screen in LR, like this:
https://photography-on-the.net …p?p=10526121#po​st10526121
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
Engineersix
Joined Oct 2013
Nov 08, 2013 14:17 |  #4
Thanks for the suggestions - I guess it all comes down to personal preference...
Rob
steelbluesleepr
Nov 08, 2013 14:30 as a reply to  @ Engineersix's post |  #5
I use my second monitor to watch netflix and pirated movies while editing :cool:
I have a 19" widescreen and a 15" 4x3 screen that I got for $20 at a thrift store, but neither are big enough for my liking. I'd like to make my 19 my secondary and a 24" IPS screen my primary.
-Jayson- my flickr (external link)
In the bag: 5D mark II+Vello grio/10d+grip/Canon 17-40L/Canon 28-135/Canon 50 1.8/Canon 35-80 Macro Conversion/Vivitar 135 2.8 M42/Vivitar 28 2.5 M42/Yongnuo YN460II x3/Yongnuo RF-602 x3
m3thods
Joined Sep 2013
Nov 08, 2013 14:47 |  #6
To add my 2c:
I have a U2410 as my "secondary" panel. What I mean by that is that I have my U2410 filling up the image being edited as LR's secondary monitor. That means my non-IPS 22" in portrait is the "main" monitor with the main image and sliders. What I do is make edits on the right where the sliders are, and the "secondary" monitor is where I see the results of the edits. It helps me see the the image as a whole on the bigger monitor to spot any oddities with edits.
If you can't picture it, I can take a picture if you're interested.
Fuji X-E2 | 18-55 | 23 | Nikon 60mm AF-D Macro | 55-250 |YN-560EXIIx2 | YN-565EX | YN-622C | YN-622C-TX
Engineersix
Joined Oct 2013
Nov 08, 2013 16:05 |  #7
That sounds like exactly like what I intend to do, m3thods...
It'd be great to see a pic of your set up if possible, thanks!
Rob
m3thods
Joined Sep 2013
Nov 08, 2013 16:36 |  #8
Sure thing- I'm currently at work but I'll get that done once I get home.
Just a heads up- I plan on reformatting the PC to give it a kick in the pants, but lately (tail end of my LR3 and now with LR5) has been fairly laggy with 2 monitors in use. What I mean by lag is the dreaded "Loading" status, as well as edits not taking effect on the photo for 1-5 seconds. When moved to a single screen, the lag mostly disappears.
The hope is that a reformat will fix that up nicely.
My specs are:
AMD 6-Core
8GB Ram (I really wish I bumped up to 16 when RAM was cheap)
560Ti
128 SSD
1TB for archive (with several external HDs)
And I'm not sure if you're thought about it, but there really is no point to buying a nice IPS screen without having it calibrated. You should allocate the 150-200 dollars for a calibrator. Most mid-level ones even allow calibration on multiple screens.
Nightstalker
Nov 08, 2013 16:55 |  #9
I have a u2711 as my main and u2410 as a secondary.
I don't usually run LR across bth screens as I find the 27in is fine by itself - however so you can see what it looks like :
IMAGE: http://www.digitalfotoz.co.uk/desktop.jpg
As you can see there is not much difference between the 27in with sidebars and the 24in full screen.
m3thods
Joined Sep 2013
Nov 08, 2013 17:04 |  #10
^That's pretty much identical to what mine looks like, except mine is flipped.
My 24 is on the left showing the image by itself in landscape. My 22 in portrait shows all the sliders and the image living on the right side. I like portrait because I don't have to scroll too much for the slider that I want.
Thanks for saving me having to take a picture of my ugly desk :P
Tigerkn
Gallery: 10 photos
Nov 08, 2013 17:05 |  #11
Dual screen are awesome for culling. I love my dual 23".
Website (external link) | Facebook (external link) | Instagram (external link) | Gears (external link)
windpig
Chopped liver
Nov 08, 2013 17:05 |  #12
Dell U30 plugged into my laptop. All the screen I need.
Go ahead, spin the wheel.
Engineersix
Joined Oct 2013
Nov 09, 2013 07:31 as a reply to  @ windpig's post |  #13
Thanks for your insights all...
Nightstalker - appreciate the photo, really helps with my decision...
M3thods - never thought about a portrait orientation, but I can see how that would work with the LR toolbars - I have to set them to 'solo' at the moment or it gets messy!
I think I will go with a 24 U2412M to start with and see how I get on...
Cheers,
Rob
DetlevCM
Nov 09, 2013 07:59 |  #14
I hope it is GB of RAM, not MB ;).
As to monitors: I used a 13" laptop with 1280*800 for ages, that was fine. Then I got a 24" monitor with 1920*1200 and that is my baseline now - and at university (engineering department) I have a 1920*1200 and 1920*1080 monitor.
-> If you have one monitor, you can always need another one. Basically, you have that extra "space" (in the form of resolution) so you will use it.
Having said that: I would most definitely recommend two identical monitors when using a dual setup if you can afford to do it. (I severely dislike the discrepancy between the screens at university - but hey, at least I have two - not a lot of other people have two on our floor - though my computer at university is ancient... from May 2007... yes, my laptop beats that - June 2008...)
Edit: One more comment - go digital at that resolution, either DVI or HDMI or Display Port. (DVI at uni, Display Port at home)
My experience with VGA at these resolutions is that it is too susceptible to interference and a flickering screen. Maybe better shielding would work, but digital signals are simpler and better.
5D MK II AF Satisfaction Poll | Reduced Kit List
A Basic Guide to Photographyexternal link | Websiteexternal link
Flickrexternal link | Artflakesexternal link | Blurbexternal link
m3thods
Joined Sep 2013
Nov 09, 2013 10:59 |  #15
Just to be complete and save you from using your imagination with my setup:
IMAGE: http://farm3.staticflickr.com/2875/10761080605_5c63a9aa94_c.jpg
IMAGE LINK: http://www.flickr.com/​photos/vangeles/107610​80605/  (external link)
On the right you'll see what I mean with the sliders. I hate scrolling, so I can get most tools in view just by having portrait. With regular browsing, I keep long articles on the right and other windows in my main landscape monitor.
like Detlev said, you'll always benefit from having 2 monitors. Even if your secondary isn't IPS (like mine), it'll likely be easier to multitask on the computer.
Like I said earlier, if you're saving money from not buying a second monitor, do invest in a calibration tool. You'll be able to tell people that your pictures are colour-correct, even if it isn't on their screens :)
Happy editing!
10,392 views & 0 likes for this thread, 9 members have posted to it.
916 guests, 162 members online
