Thread started 09 Nov 2013 (Saturday) 07:09
T-3 Troubles
Rickfly
Joined Nov 2013
Nov 09, 2013 07:09 |  #1
List,
I have had my T-3 for several months and everything has worked fine until now. For some reason it will no longer take pictures. The lens cap is off, the battery has a full charge. I think I may have inavertently pushed a wrong button somewhere. When you push the shutter button half way, on full auto, the little red lights to focus no longer appear. When you push the shutter button all the way, the screen on the back of the camera momentarily goes dark. What am I doing wrong? Also, is there away to to re-set the camera to factory settings? Thanks. RFly
dpds68
Nov 09, 2013 07:39 |  #2
Take out both Batteries main and small coin Batteries ( If there is one in that Model ) Press shutter button with no power to drain residual charge leave out for at least 15 min then replace that should reset to factory settings .
David
Gripped Canon 7D,20D,XT / Tamron 17-50mm 2.8, Canon 85mm f1.8 , 70-200 2.8L,EF50mm1.8 II,Sigma 150-500mm OS, Sigma 105mm 2.8 Macro, Sigma 10-20mm 4-5.6
Vivitar285Hv x2,Canon430EX,Nissin Di866,CTR-301P Triggers,
http://www.flickr.com/​photos/dpds68/ (external link)
SimmonsCreek
Joined Feb 2013
Nov 09, 2013 08:12 |  #3
Great to know, thanks
Lora
http://lora-hall.fineartamerica.co​m (external link)
Canon Rebel T3
Disposibleteen
Joined May 2012
Nov 09, 2013 08:33 |  #4
If i remember correctly on that model there should be a function in the menus to reset to factory defaults. I would try that before pulling the coin battery just to see if it solves the issue.
John ­ from ­ PA
Joined May 2003
Nov 09, 2013 08:49 |  #5
How old is the main battery? Do you have a spare that you can try? I think that the T3 has a small microswitch in the memory card compartment (like most Canon's). Remove the memory card, reseat it and make sure the compartment door closes properly.
Rickfly
Joined Nov 2013
Nov 10, 2013 18:03 as a reply to  @ John from PA's post |  #6
The battery is OK. On further investigation, the problem is not the camera. It's the 18 -55mm lens. The lens will not work in automatic mode, BUT it will work in manual mode. Auto does work with the 75 - 300 mm lens, so the problem is with the lens and not the camera. Any advice? Thanks! Rick
RHChan84
Joined Apr 2011
Nov 10, 2013 18:43 |  #7
Try cleaning out all the contacts on the lens and the body.
Canon (60D Gripped | 18-135mm f3.5-5.6 IS | 40mm f2.8 | 50mm f1.8 | 70-200 F4L IS| 430 EXII)
Tamron (17-50 f2.8 VC)
Feedback
Facebook (external link)
Rickfly
Joined Nov 2013
Nov 11, 2013 06:14 as a reply to  @ RHChan84's post |  #8
I cleaned the contacts. Now the flash will work, but that's about all that works. I'm wonder if the lens is defective and needs to be replaced. Thanks.
Jim_T
Joined Nov 2003
Nov 11, 2013 09:03 |  #9
I doubt it's the lens.. You can check it by taking the lens off and pressing the shutter button.. The camera should take a shot.
tagnal
Nov 11, 2013 13:40 |  #10
Jim_T wrote in post #16441984 (external link)
Except he said it works fine with the "75 - 300 mm lens".
5D3 / M3 / S100 / Σ 35 Art / 50 1.8 / 135 L / 17-40 L / 24-70 L / 70-200 f/4 IS L / m 22 2.0 / 580ex II
Toy List | flickr (external link) | FAA (external link)
Rickfly
Joined Nov 2013
Nov 13, 2013 06:46 as a reply to  @ tagnal's post |  #11
I'm finding that the shutter works without a lens.
watt100
Nov 13, 2013 09:04 |  #12
Rickfly wrote in post #16440541 (external link)
when you say "manual mode" do you mean the AF/MF switch on the lens?
Rickfly
Joined Nov 2013
Nov 13, 2013 13:47 as a reply to  @ watt100's post |  #13
Yes, along with the manual setting on the body.
Wilt
Nov 13, 2013 13:52 |  #14
Manual setting on the body has nothing directly to do with the lens not functioning.
Have you verified that the AF/MF switch on the lens is set to the AF position?!
Rickfly
Joined Nov 2013
Nov 15, 2013 08:11 as a reply to  @ Wilt's post |  #15
You may want to keep this e-mail for future reference for your T-3 camera. I called Canon today about my camera. Here's what the problem was - the lens was out of synch with the auto-focus motor.
Here's how to fix the problem - Take the lens off the camera, set the lens to manual operation, turn the focus ring on the lens all the way to the left-then all the way to the right, put lens back on camera and turn the lens switch to auto, and it should work. This puts the lens back in synch with the focus motor.
The tech said that this problem could have been caused by putting too much downward pressure on the lens when it's in the case. I stored my camera with the lens on it in my camera bag with the lens facing down and the camera body on top of it. The tech said it would be better to either put it in the bag with the body down instead of the lens, or take the lens off all together.
1,546 views & 0 likes for this thread
T-3 Troubles
Latest registered member is LaurensW
2246 guests, 312 members online
