Thread started 09 Nov 2013 (Saturday) 12:16
Luminance slidder Lightroom 4
DigitalDon
Joined Aug 2012
Nov 09, 2013 12:16 |  #1
Luminance slidder in lightroom 4 who uses it, I started adding luminance and my pictures look better, well to me they look better.
(EOS RebelT3i EF-S 18 - 55 IS II Kit) (EFS 55 - 250 mm lense f/4-5.6 IS II) (YONGNUO YN 565EX flash)
jefzor
Joined Jul 2013
Nov 09, 2013 15:13 |  #2
Do you mean clarity?
www.jefpauwels.be (external link)
DigitalDon
Joined Aug 2012
Nov 09, 2013 17:43 |  #3
jefzor wrote in post #16437766 (external link)
No it's Luminance under Noise Reduction, but it seems to do about the same as Clarity.
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/11/2/LQ_667662.jpg
Image hosted by forum (667662) © DigitalDon [SHARE LINK]
Bob_A
Gallery: 48 photos
Joined Jan 2005
Nov 09, 2013 18:12 |  #4
I use Luminance NR and Color NR for every RAW image, varying the amounts by ISO (for jpegs I don't use any at all since it's already been applied by the camera). For ISO 200 with my D700 I might use Luminance = 8-10 and Color = 6. For a similar shot at ISO 3200 I might use Luminance = 28 and Color = 18.
With an image at 100% I start with Color and reduce chroma noise until any different colored speckles almost disappear. Don't overdo it. After that I increase Luminance NR until the image is reasonably noise free without losing important details.
Before doing NR I apply sharpening (for RAWs) and tend to use a bit of Masking, especially for images of people and landscapes with a lot of sky.
Bob
tzalman
Fatal attraction.
Nov 09, 2013 20:24 |  #5
DigitalDon wrote in post #16438061 (external link)
Are you kidding? They are almost complete opposites. NR blurs both noise and detail. Clarity, by increasing micro contrast, increases the definition of noise and detail.
Elie / אלי
tzalman
Fatal attraction.
Nov 09, 2013 20:59 |  #6
I do set a little Luma NR for every shot, but only 3 up to ISO 800, 7 for 1600 and 15 for 3200, but I also do some rough grain for every shot. So I take away the noise and replace it with simulated film grain. I like grain for two reasons; it gives the illusion of 3D volume and it creates an impression of sharpness.
Regarding Chroma NR, Adobe says that the default 25 should be right for most photos. They have also dropped hints that the 25 is not an absolute value and the actual NR varies according to camera model and ISO.
Elie / אלי
DigitalDon
Joined Aug 2012
Nov 09, 2013 21:56 |  #7
tzalman wrote in post #16438346 (external link)
Okay learn something new everyday, all i know is if i move the clarity slidder to the left it gets the (only word i can think of is) dreamy look like slidding the Lum slidder right makes it dreamy looking to.
DigitalDon
Joined Aug 2012
Nov 09, 2013 22:26 |  #8
Bob_A wrote in post #16438117 (external link)
Thanks for the info
I usually start with Basic panel first and almost always turn down the Highlights, almost all the way down, then I will adjust Shadows to the right until I say to myself, Ok, there has to be shadows so I back off until I think the shadows look right, White and Black I watch the under/overexposure indicators for them.
then I play around with the Exposure a little and Contrast at about 10.
I then go to the Details panel and set Sharpening about half way, then I back off (to the left) the Radius slidder until it blurs, then slowly move to the right until I see it clear up a bit, usually around 1.7, The Detail slidder I will add just enought until I see some detail, I hardly ever use the Masking slidder. I haven't really used the Luminance until a few days ago and I noticed I could use more of the Sharpening and Detail slidders (more to the right) when I used the Luminance slidder.
Forgot to mention, I usually zoom to 1.1 or more on some of them
jefzor
Joined Jul 2013
Nov 10, 2013 02:39 |  #9
Oh, OK. That's one I'd leave at 0, unless you have a noise problem. And even then, 25 is as high as I'd want to go with it.
tzalman
Fatal attraction.
Nov 10, 2013 04:09 |  #10
DigitalDon wrote in post #16438501 (external link)
That's because to the left is negative Clarity
Elie / אלי
Bob_A
Gallery: 48 photos
Joined Jan 2005
Nov 10, 2013 18:10 |  #11
tzalman wrote in post #16438407 (external link)
I usually add too much NR since an image is rarely viewed full size on a monitor and noise isn't as visible when printed. Adding grain is a nice trick though and certainly less NR is required when you use it. I had some horribly underexposed negatives that I scanned an was able to get a useable "memory" (not art, that's for sure) by using grain instead of increasing NR until the image was mush. :)
Adding too much chroma NR doesn't appear to wreck details as aggressively as too much luminance NR, so most of the time you could probably get away with 25. For my D700 I don't typically need that much though, so I dial it down.
Bob
BigAl007
Gallery: 556 photos
Nov 11, 2013 04:39 |  #12
I have yet been unable to SEE any difference between working very carefully to find the setting that will just remove the chroma noise and the LR default of 25, so it just stays on the default. Well actually I usually do my basic pannel adjustments with all NR and sharpening zeroed out, but a quick double click of the slider soon sets it back to default.
Alan
tonylong
...winded
Gallery: 60 photos
Nov 11, 2013 19:40 |  #13
I typically leave the color/chrome LR at the default, because that setting doesn't seem to "harm" the images, and it does seem to do good with color noise!
Tony
1,618 views & 0 likes for this thread, 6 members have posted to it.
1047 guests, 105 members online
