Thread started 12 Nov 2013 (Tuesday) 07:43
T4i taking longer to write file?
DavidSR
Nov 12, 2013 07:43 |  #1
Hello,
I have limited internet access so sorry if this has already been answered. I was taking pictures and I noticed that after I removed my eye from the viewfinder there was a black screen longer than normal and the picture didn't show until I slightly pressed the shutter. Any ideas?
Thank you!!
T4i, 18-55mm IS, 55-250mm IS, 50mm 1.8, 3 Vivitar 285HV's and a set of Cactus V5 Triggers!!
Keyan
Joined Mar 2011
Nov 12, 2013 08:49 |  #2
Did you change any settings?
Try a low level format of the card using the camera menu, not a PC.
Cameras: 7D2, S100
Lenses: 17-55 f/2.8 IS USM, 18-135 STM, 24-70 f/4L IS USM, 50 f/1.4 USM,70-300L IS USM
Other Stuff: 430 EX II, Luma Labs Loop 3, CamRanger
John ­ from ­ PA
Joined May 2003
Nov 12, 2013 09:07 |  #3
I see you had a very similar chain of events back in August and you got some suggestions back then at https://photography-on-the.net …/showthread.php​?t=1323531.
What did you ever learn back in August? Was the issue resolved? Is the problem now again with your 32GB card but not the 8 GB you had before? If it is with that 32GB card where did you acquire the card (eBay, Amazon, Fry's, etc.)? I'm making the assumption this is with the same T4i as back in August as well.
655 views & 0 likes for this thread, 3 members have posted to it.
1600 guests, 140 members online
