Thread started 12 Nov 2013 (Tuesday) 14:11
Wedding Flash Modifier On Camera If Any
picworx
Joined Jun 2005
Nov 12, 2013 14:11 |  #1
I would like to know what you folks are using if any for wedding shots, i.e the dress, inside the church, outside etc.
I have tried 2 types as shown below but one does not work any better than the other hence I was just thinking of getting a regular stofen, small and light on the flash bracket?
Any thoughts?
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/11/2/LQ_667975.jpg
Image hosted by forum (667975) © picworx [SHARE LINK]
IMAGE: https://photography-on-the.net/forum/images/hostedphotos_lq/2013/11/2/LQ_667976.jpg
Image hosted by forum (667976) © picworx [SHARE LINK]
The Print is What Really Matters
jcolman
Gallery: 17 photos
Nov 12, 2013 14:14 |  #2
I haven't used an on-camera flash modifier in a couple years. I just bounce the light behind me or use off-camera flash.
www.jimcolmanphotograp​hy.com (external link)
gonzogolf
dumb remark memorialized
Gallery: 561 photos
Nov 12, 2013 14:16 |  #3
The flashbender works well and can be used in a variety of ways, as a simple bounce card, or tilted more forward when the ceilings wont provide for a full bounce. Stofens are a waste of battery and flash power. Outside neither are much help, although the flashbender can make for a better catch light.
HiepBuiPhotography
Joined Mar 2012
Nov 12, 2013 14:20 |  #4
That second one that you posted looks similar to a Stofen. If you didn't like it, why go with the Stofen? I personally don't use any modifiers. Bounce it or direct flash when needed.
Hiep Bui Photography | Harrisburg Wedding Photographer (external link)
Trent ­ Gillespie
Joined Jan 2013
Nov 12, 2013 21:24 as a reply to  @ HiepBuiPhotography's post |  #5
I have no clue why people buy stofens? If you believe it makes a difference, you might as well just glue a thick piece of tupperware to the top of your flash. All a stofen does it cut power, causing your flash to work harder. In order to get more elegant light, you need to make your light source larger... not more powerful. Bouncing is the best method at achieving this...
I use flashbender for flagging, but rarely as a flash modifier. If there is absolutely nothing to bounce off, I will put the flash head at a 45 degree angle and bounce it off the flashbender, but it really is about the same as directional flash.
Do your wallet and your photos a favor, and experiment with bounce flash.
Trent Gillespie
Denver Wedding Photographer (external link)
Gear in the Bag (external link)
Sibil
Nov 13, 2013 07:02 |  #6
picworx wrote in post #16445937 (external link)
What brand is the 2nd one on the right that looks like a stofen?
Christopher ­ Steven ­ b
Nov 13, 2013 13:13 |  #7
I totally agree with the 'spirit' of the responses given above--stofens et al don't generally produce the kind of light you're looking for. Learning to bounce is generally the best approach.
That said, I think that any light modifier can be treated as a tool that has uses in certain situations. If I place my subject in front of a low stone archway, lighting them with a brolly from the front, an omni-directional light bulb effect is precisely what I would like to place behind them to not only back light the subject a little, but also light up the 'sides' and top of the doorway. Popping a stofen on that backlighting flash really is the most efficient and easy way to go about this.
christopher steven b. - Ottawa Wedding Photographer
www.christopherstevenb​.com (external link)| Blog (external link)
tim
Light Bringer
Nov 13, 2013 13:39 |  #8
Covered pretty extensively in the past week.
https://photography-on-the.net …/showthread.php​?t=1340296
https://photography-on-the.net …/showthread.php​?t=1340636
umphotography
grabbing their Johnson
Gallery: 21 photos
Nov 13, 2013 15:42 as a reply to  @ tim's post |  #9
I have an use the Rogue flash bender with the diffusion panel.....Outstanding product. But I also bounce and go bare OCF a ton. The Rogue bender does well when you want to really soften up the light.....Works great in the right light and takes about 2 seconds to slip it on so thats why I use it.
Mike
www.umphotography.com (external link)
Facebook (external link)
Trent ­ Gillespie
Joined Jan 2013
Nov 13, 2013 16:34 |  #10
umphotography wrote in post #16449131 (external link)
Has anyone tested the diffusion panel's effectiveness at certain distances. I would think past 10 feet, it would have minimal effect on softening the light.
Trent Gillespie
gonzogolf
Gallery: 561 photos
Nov 13, 2013 16:35 |  #11
Trent Gillespie wrote in post #16449310 (external link)
I keep meaning to do that. But I suspect you are right. The only value I can really tell is that it evens the spread of light out a bit more.
frugivore
Gallery: 11 photos
Nov 13, 2013 16:54 |  #12
Most often, my goal with regard to lighting is to have the light 'wrap around' my subject. Bouncing does this to some degree because the larger surface diffuses the light and his the subject from different angles.
When there is no surface to bounce from, the only solution that I found was to light the subject with multiple light sources. I typically use two speedlights - one on camera and one as the key light off camera. This creates a pattern of light that emulates the 'wrap' effect. So I use two Flip-It reflectors on the flashes to direct the light forward with the had zoomed to 105/200mm. The Demb reflector let me move the light source higher and the design was more efficient than the Flashbender and other products.
With this setup, your lights can be very far away and still get that soft light look. The "large light source" rule doesn't apply in this case.
Red ­ Tie ­ Photography
Nov 13, 2013 18:27 |  #13
I use the Demb Flip it - similar to the flashbender to fill in the eyes a little bit when I bounce.
Bryan
Gear List (external link)
San Diego Wedding Photography - Red Tie Photography (external link)
Red Tie Photography Blog (external link)
umphotography
Gallery: 21 photos
Nov 13, 2013 21:17 |  #14
gonzogolf wrote in post #16449317 (external link)
10 ft would be my max distance, 6-8 ft is ideal for 4 or less people. Its very soft nice light and a heck of a lot quicker than setting up a softbox
Mike
gonzogolf
Gallery: 561 photos
Nov 14, 2013 09:20 |  #15
umphotography wrote in post #16450061 (external link)
Thats pretty much what I feel, but havent done any evaluation to confirm it.
19,457 views & 0 likes for this thread, 20 members have posted to it and it is followed by 2 members.
1510 guests, 132 members online
