Thread started 31 Jan 2006 (Tuesday) 21:17
Adobe website Photoshop tutorials
keenasmustard
Joined Nov 2005
Jan 31, 2006 21:17 |  #1
OK, maybe it's me, but....
I just ran through a couple of tutorials on the Adobe website and kept running into deadends with them. Either they don't explain a step thoroughly enough, or they simply don't make any sense. I'm a fairly experienced user, not a beginner, so even reading between the lines on a few of them still left me lost.
The one that really made me feel stupid was this tip:
To fix an overexposed photo using Adobe® Photoshop® CS2 (external link), lower the Opacity of your top layer to around 50%. Once the photo looks properly exposed, choose the Flatten Image from the Layers palette's flyout menu.
I tried this and it does nothing at all. Have they missed out a step? If anyone's got a minute to give that a go and see what result you get, I'd be most appreciative.
chrisb99
Feb 01, 2006 06:08 |  #2
I might be mistaken (I am fairly new to the post processing world) but I believe the mode of the top layer needs to be changed. I am not positive but I think it should be overlay.
I guess the article is assuming that this will darken the image too much and therefore suggests reducing the opacity to decrease the darkening effect. If the image is severely overexposed, more layers can be added.
Jedi ­ Lights
1 post
Joined Nov 2005
Feb 01, 2006 08:03 as a reply to  @ chrisb99's post |  #3
My guess will be the top layer is a duplicate of the photo, then change the blend mode to multiply, then lower the Opacity of your top layer to around 50%.
Thats how i do it anyways!!
Be one with the Force! - Oh-be-One CANON-Bee
EOS_JD
Feb 03, 2006 07:18 |  #4
open your image and Press Ctrl J to copy the background layer so you have 2 layers showing the same image. Change the blending mode to MULTIPLY if the image is OVEREXPOSED and reduce opacity to suit. If it is still over exposed, create a copy of the 2nd layer and increae/decrease opacity to suit.
SCREEN mode will help with Underexposed shots.
Overlay and soft light add saturation and contrast. best used in small doses (20% or less although some images may like more.
All My Gear
5D MkIII & 5D MKII + Grips | 24-70 f2.8L IS | 24-105 f4L IS | 70-200 f2.8L IS MkII | 50 f/1.4 | 85 f1.8 | 100 f2.8 | 1.4x MkII | Tamron 17-35 f2.8-4
1,103 views & 0 likes for this thread, 4 members have posted to it.
2083 guests, 101 members online
