Thread started 14 Nov 2013 (Thursday) 17:19
1Dx will not turn on... unless...
Candersson
Nov 14, 2013 17:19 |  #1
My 1Dx will not power up, sometimes. :confused:
Let's say it works like normal 7 out of 10 times.
When it won't start the only thing to fix it is to eject the battery and insert again. Tried several different batteries (originals) with the same result.
It looks like it want to do some kind of "reset".
When it starts it works just fine...
Of course it's going in for repair - just curious if anyone else have had the same experience.
...and if so, what was the problem ???
- Thomas -
1DX/1DIV/7D/5DmkII and Lenses | WWW (external link)
So much to learn, so little time...
Frodge
Joined Nov 2012
Nov 14, 2013 18:55 |  #2
Is the battery door closing all the way?
“It's kind of fun to do the impossible.” - Walt Disney.
Equipment: Tokina 12-24mm, Canon 40mm 2.8, Tamron 17-50 2.8 XR Di, Canon 18-55mm, Canon 50mm 1.8, Tamron 70-300VC / T3I and 60D
Echo63
Nov 14, 2013 19:44 |  #3
Frodge wrote in post #16452381 (external link)
1DX doesn't have a battery door, the battery is one unit with a locking lever on the end.
My Best Imageswww.echo63.deviantart.​com (external link)
Gear listhttps://photography-on-the.net …p?p=2463426&pos​tcount=385
N2bnfunn
Nov 14, 2013 23:17 |  #4
I could be a few things, sounds like the contacts in the body of the camera is dirty, or it could be the battery it self contact sdirty, or worst thing it could be a cold solder connection in the body of the camera.
Do this check and see if your camera 1dx falls under the recall.... if so that is your problem/
Canon EOS R EF 70-200 L 2.8 L 24-70 2.8L II Canon Pixma PRO-1 3 Canon 600EX-RT Speedlites
joeseph
"smells like turd"
Gallery: 264 photos
Joined Jan 2004
Nov 15, 2013 02:16 |  #5
Echo63 wrote in post #16452490 (external link)
true, but this locking lever activates a power-switch so it's worth checking that it's fully in the locked position...
TF posting: here :-)
sdipirro
Nov 15, 2013 12:49 |  #6
Well, parts of this sounds similar to a problem I was having (that I'm hoping is fixed now). My 1dx was working perfectly when I sent it to Canon for the mirror lubrication recall back in July. When I got it back, it worked fine for a couple of weeks, and then it died about 10 shots into a paid shoot. I didn't have time to mess with it and finished the shoot with a backup camera. When I removed and replaced the battery, it came back to life. It behaved this way for a couple of weeks until removing and replacing the battery no longer brought the camera back to life. It was completely dead and went back to Canon. They replaced some part and sent it back. I had the same experience as above. It worked fine for a little while, then started with the intermittent failures, and then died completely. I even bought a second battery to be sure that wasn't the problem. Back to Canon again, and to their credit, they wanted to keep it a little longer this time so it wouldn't come back again once they fixed it. I've had it back now for a few weeks, and so far, so good...but I still bring a backup camera with me everywhere because I don't trust it yet. They replaced two different parts the last time, but the part name and numbers meant nothing to me.
Cameras: 1DX, 1D4, 20D, 10D, S90, G2
Lenses: Canon 10-22mm, 16-35mm f2.8L II, 24-70mm f2.8L, 70-200mm f2.8L IS, 300mm f2.8L IS, 200mm f2L IS, 50mm f1.4, 50mm f1.2L, 85mm f1.2L, 1.4x TC, 2x TC, 500D macro, Zeiss 21mm
Lighting: 580EX, Elinchrom 600 RX's, D-Lite 4's, ABR800, 74" Eli Octa, 100cm/70cm DOs, Photoflex Medium Octa and reflectors, PW's, Lastolite Hilite, Newton Di400CR bracket
Candersson
Nov 15, 2013 13:38 as a reply to  @ sdipirro's post |  #7
^^ Well that sounds just like my scenario!!!
I had it in for the fix and it was fine for a while then this behavior started to appear... sounds very similar.
Could you please let me know name/numbers of the two parts you had repaired?
Regarding the other comments. I have switched to other batteries (and new ones as well) without any difference.
I ALWAYS bring a backup, but nothing is more irritating than when things fails during a gig.
Every day without a problem, is one day closer to the disaster ;)
- Thomas -
puntti
Joined Dec 2013
Dec 07, 2013 20:42 as a reply to  @ Candersson's post |  #8
Same thing happened to me. The last few weeks my camera turns off during use (dead as a door nail). I put the battery in and out a few times and it works again. Until yesterday! Now it won't turn on at all. Exactly the same as this video, except now it won't turn on at all. http://vimeo.com/76656​998 (external link)
Did you find out the name/numbers of the two parts sdipirro had repaired to fix the problem?
Regards.
Tanya.
Candersson
Dec 08, 2013 13:25 as a reply to  @ puntti's post |  #9
Nop, I didn't get any info back from sdipirro.
Mine has been at the repair shop for 2 weeks now (I have been travelling so haven't missed it).
I told them to keep it until they find what's wrong and then fix it.
I talked to the tech the other week and he couldn't find anything in any logs - so it seems to be something early in the power circuits (or software).
I'm about to give him a call tomorrow again and check the status.
I'd like my camera back :confused: ...sure, I can get a loaner until it is sorted but I would rather have my own!
- Thomas -
Nick_Reading.UK
Joined Nov 2011
Dec 08, 2013 16:44 |  #10
Such an expensive camera and so many issues!!!!
EOS 5Dmk3 X2, 60D, EF24-70mm f2.8L mk2, EF70-200mm f2.8L IS mk2, EF85mm f1.8, EF50mm f1.4, EF50mm f1.8 mk1(350D with 18-55mm Sh"kit" lens).
Speedlite 600EX-RT, 430EX II Flash. manfrotto 190XDB tripod, Giottos GTMML 3290B Monopod, B+W 77mm 110 Single Coated filter, Hama 77mm Variable Neutral Density Filter.
puntti
Joined Dec 2013
Dec 08, 2013 17:06 |  #11
That's the strange part. Mine didn't give any errors to log either. It just went dead while I was using it. Mid shot actually! Pulling the battery in and out a few times did work for a while, but not any more :/
Canon 1DX is a beautiful camera ... when it's working!
Anyway, thanks for answering back Candersson. Keep me informed in what your repair shop finds out, it will be interesting.
Candersson
Dec 09, 2013 17:57 as a reply to  @ puntti's post |  #12
Talked to the service tech today and found out what has been done.
He told me that he had been in contact with Canon and got the suggestion to reload the camera settings.
I'm not talking about the software (that we users upgrade manually) but the internal settings of the 1DX.
These are stored in a separate memory which holds camera basic settings like factory adjustments and adjustments to lenses (made by the Canon service) etc. etc.
These settings are only accessed/managed through a special software that is being used by the Canon service.
So basically he did a backup of the settings in my body, erased the memory and reloaded the settings.
This was done beginning of last week and he has been testing the camera several times each day since then without being able to recreate the problem.
If this is the final solution I don't know. It sure is an improvement though :)
I am going to collect the body tomorrow and then continue to shot and be very observant for any strange behavior...
- Thomas -
puntti
Joined Dec 2013
Dec 09, 2013 18:08 |  #13
If you find your camera still has the problem in future, the next step may be to have them check the 'PF' board. This was the solution for David Ferrone on this Vimeo video https://vimeo.com/7665​6998 (external link)
Thanks for your information as well. I'll make sure I print it out and send it in when I get mine fixed. Let me know how it goes. It will be interesting to see if that fixes your problem in the long term.
Have a great day!
Candersson
Dec 09, 2013 18:49 as a reply to  @ puntti's post |  #14
Thanks puntti
I'll keep that in mind and cross my fingers... :cool:
- Thomas -
joe9047
Dec 12, 2013 18:03 as a reply to  @ Candersson's post |  #15
Count me in too. First happened in July during my daughters grad party. I guess high temps/humidity and going into and out of the air conditioned house did it in. Soon figured out I needed to take the battery out and reinsert it back in the camera to get going again. Had to do that every half hour or so.
Luckily, I sent it in for repair one week before my warranty was up. Not so lucky for me was that it took four trips to Canon Factory Service before they finally fixed it (I hope).
The last service was a circuit board replacement- PCB ASS'Y, FP
Part # CG2-3143-000
Joe
Gear
23,722 views & 1 like for this thread, 23 members have posted to it and it is followed by 3 members.
1462 guests, 129 members online
