I volunteer at my local animal shelter, and do the kittens and cats. Last week was my first go at it, and overall, I was pretty pleased with my results. However, they request that the kittens stay inside their kennels, which are brushed aluminum (aluminium for you Brits), with a wire door. I can open the door, but they don't want the kittens to be removed from kennel.
I ended up using my pop-up flash for the kittens, rather then my YN568II, because of all the reflections. When I tried with the YN in the hot shoe, it was too tall to get the light inside the kennel. I do have triggers (622's and 602's), but didn't bring them, as I was trying to travel light.
Here is an example of how they turned out:
![]() | HTTP response: 404 | MIME changed to 'image/gif' | Byte size: ZERO | PHOTOBUCKET ERROR IMAGE |
There were hot spots on the walls, etc., but I was able to crop most of the problem areas out. I was relatively careful with my angles, in an attempt to keep the hotspots from being right behind the kittens.
While they are decent, I still think I could have done better. Unfortunately, I don't have any small (portable) diffusers. Would one have helped? Any suggestions on how I could have improved these?
Catch a great expression and it will look great.
