Looking to invest in a new camera and want to know how does 1Ds MK III compared to 5D MKIII and which would you buy if they are equally priced. Want to know soon so I can make decision.
Which camera is better and why?
Photoman65 Senior Member 303 posts Joined Nov 2006 Location: Dallas, TX More info | Nov 17, 2013 14:42 | #1 Looking to invest in a new camera and want to know how does 1Ds MK III compared to 5D MKIII and which would you buy if they are equally priced. Want to know soon so I can make decision. Canon USA Gear! Cameras: 5D MKIII & 7D L Lenses: 24mm-70mm f/2.8, 85mm f/1.2 II, 70mm-200mm f/2.8 IS, 1.4II Ext, 580 EXII Speedlite
Kanye Senior Member 670 posts Likes: 2 Joined Oct 2013 Location: Seattle, WA More info | Nov 17, 2013 14:59 | #2 1Ds.
Nov 17, 2013 15:20 | #3 As a lover of 1 series bodies, I'd have to say 5D3. I asked the same a while back and the consensus was the 5. 5D3, 7D2, 1D3, 40D, 14 f2.8 Samyang, 17-40 L, 28-80 L, 70-200 2.8ii L, 200 2.8ii L, 200-400 L, 1.4 ii,
bobbyz Cream of the Crop 20,506 posts Likes: 3479 Joined Nov 2007 Location: Bay Area, CA More info | Nov 17, 2013 21:14 | #4 I like 1 series also but 5dmk3 would be my choice. Fuji XT-1, 18-55mm
auto-clicker Senior Member 819 posts Likes: 37 Joined Dec 2009 More info | Even though mine failed very early in my possession for unknown reason(s), i always recommend buying into the latest technology that you can afford. So i say 5D3 from your choices.
timbop Goldmember More info | Nov 17, 2013 22:52 | #6 5d3, but you don't mention any particular needs or anything else that might influence my suggestion FOR YOU Current: 5DM3, 6D, 8mm fish, 24-105/4IS, 35/2IS, 70-200/2.8IS, 85/1.8, 100-400/IS v1, lensbaby composer with edge 80, 580's and AB800's
umphotography grabbing their Johnson More info | The 5D3 outperforms the 1Ds at every place you can test it against except build. 5D3 blows the 1Ds away in noise performance above 2000 ISO. AF system on 5D3 is noticeably better, Servo works, with only a few advantages of customizing to the 1Ds AF system some particular needs Mike
NYC2BGI Senior Member 846 posts Joined Feb 2005 Location: Brooklyn, NY USA More info | Nov 18, 2013 08:38 | #8 5D3 all the way. Canon 5D3, 5D2, 40D
Dec 12, 2013 10:26 | #9 nellyle wrote in post #16458817 All depends what you want to shoot obviously, but high iso, fps, screen, resolution, AF all go to the 5. Low iso I'm sure there wouldn't be much if anything in it. +1 on 5D3 -Jay
Tareq "I am very lazy, a normal consumer" More info | Dec 12, 2013 13:36 | #10 Between the two definitely i will choose 5D3, but i have 1Ds3 and 1DX, i go with 1Ds3 only for higher mp for landscapes and nightshots or everything except sports and situations where i must use high ISO, so 5D3 has high mp and better high ISO so i can use it for everything, only sports i prefer 1DX over 5D3, if you said 5D2 then i will say 1Ds3 all the way for me. Galleries:
Dec 12, 2013 14:56 | #12 |
theflyingmoose Goldmember 1,640 posts Likes: 78 Joined Dec 2006 More info | Dec 12, 2013 15:07 | #13 d800.
Tareq "I am very lazy, a normal consumer" More info | Dec 12, 2013 15:29 | #14 H5D or Phase One IQ series Galleries:
| Latest registered member is josetide 1046 guests, 171 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
