Hi, I have an older Gitzo explorer. This has locks on-top of the legs to (independently) arrest the splay. Even while new, as far as I remember, you *could* still change the angle of leg while locked, though it took quite a bit of strength. Maybe this was a "feature" rather than a "bug", to allow fine adjustments without unlocking the leg. Either way, it did not bother me. Now, though, one of the legs splays out with hardly any pressure at all even when locked. For example, when on uneven ground, the weight of the camera and tripod pushing on the leg causes it to spread out. Needless to say, this is annoying. I notice these allen wrench / hex bolts at the top of each leg, and tried to tighten these by hand. No luck -- they were already pretty tight and I don't think I changed much. In any case, the leg remains prone to spreading with the slightest pressure.
Has anyone else faced this? How did you fix it? Should I employ more torque on the hex bolts (e.g., with a power drill)?
Thanks for any advice or information!
