Thread started 19 Nov 2013 (Tuesday) 08:19
5d iii vs 6d for automotive photography
cayenne_ksa
Nov 19, 2013 08:19 |  #1
I understand this has been discussed many times but I want to be specific to my need. I'm looking to buy another camera for the following reasons
  1. i want to have FF body
  2. i need another body
current gears
  • canon 7d
  • canon 70-200 2.8 IS L
  • canon 24-70 2.8 L
I shoot cars 90% of the time utilising natural light. Most shots are with presence of tirpod in good lighting conditions ( indoor, shaded areas , or sunset/sunrise time ). No low light. most cars i shoot are still and maybe twice per year I attend a race where i do some panning shots.
my question, is there any good reason to go with 5d iii over 6d? what i care about the most is image quality.
paddler4
Nov 19, 2013 08:32 |  #2
The 6D is actually better in low light. AFAIK, the biggest consideration in your case might be the AF system. The 6D's AF is pretty low end, while the 5DMKIII has a superb AF system. This will be of no consequence at all for your still shots, but it could make a big difference for races.Never having done that kind of shooting, I don't know how much the AF will matter. Perhaps you could make do with center-point-only on the 6D.
Check out my photos at http://dkoretz.smugmug​.com (external link)
FarmerTed1971
fondling the 5D4
Gallery: 66 photos
Joined Sep 2013
Nov 19, 2013 08:53 |  #3
Go 6D and a new wide lens (and bring the 7D when you go to the races).
Getting better at this - Fuji X-t3 x2 - Fuji X-Pro2 - Laowa 9mm - 16 1.4 - 18-55 - 16-80 - 23/35/50/90 f2 - 50-140 - flickr (external link) - www.scottaticephoto.co​m (external link)
bobbyz
Nov 19, 2013 09:17 |  #4
6d is plenty IMHO. Even old 5dc would do.
Fuji XT-1, 18-55mm
Scott ­ M
Gallery: 83 photos
Nov 19, 2013 09:37 |  #5
FarmerTed1971 wrote in post #16463434 (external link)
^ This. The only advantage of the 5D3 over the 6D in your circumstance is the ergonomics of the 5D3 and 7D are very similar. They also use the same memory type.
Photo Gallery (external link)
milleniumking
Joined Jan 2013
Nov 19, 2013 12:13 |  #6
If you have the $$$ go with the mark iii. This way you could probably get rid of your 7d and hang on to your lenses.
VicSkimmr
Nov 19, 2013 12:16 |  #7
There's never a reason to go 6D over 5d3 if money isn't a concern unless you care about the increased weight of the 5d3.
That being said, the 6D should be an excellent automotive body. It's only potential hindrances would be the slow FPS for rolling shots and the 1/4000 shutter speed limit if you shoot into the sun at low apertures, which a lot of people do these days for automotive stuff.
-Jason
[URL="http://www.flick​r.com/photos/jasonwith​ers/"]flickr (external link)
bobbyz
Nov 19, 2013 13:42 |  #8
VicSkimmr wrote in post #16463921 (external link)
f1.4/f2 for cars and needing 1/4000 for rolling shots?
Fuji XT-1, 18-55mm
VicSkimmr
Nov 19, 2013 15:56 |  #9
FPS on a 6D is 4.5, which is on the slow side for rolling shots. I should know, I've done it. Rolling shots are nearly always a spray and pray deal unless you're doing them on the highway. More FPS = more keepers.
and yeah, I've been in situations where I hit the shutter limit. f/2.8 with mid morning light.
IMAGE: http://farm9.staticflickr.com/8395/8669687706_705d436910_c.jpg
IMAGE LINK: http://www.flickr.com …/jasonwithers/8​669687706/  (external link)
Drew's NB Miata (external link) by jasonwithers (external link), on Flickr
-Jason
bobbyz
Nov 19, 2013 15:58 |  #10
I don't shoot cars but one can easily stick a ND filter if 1/4000 is an issue.
Fuji XT-1, 18-55mm
EverydayGetaway
Gallery: 11 photos
Joined Oct 2012
Nov 19, 2013 20:30 |  #11
bobbyz wrote in post #16464506 (external link)
This.
I shot a car cruise with the 6D and used fast glass for a good portion of it. The lighting conditions were about as awful as you could ever see (Mid-day bright sun, no clouds, 95+ degree heat) which is why I haven't shared bunches of those pics... but the light was intense to the point that even with my lens at f/2 I would've been over 2 stops over-exposed with 1/4000/sec, so the 5D wouldn't have made a difference. Thanks to ND filters it was a non issue.
You'll usually want to use a CPL for shooting cars anyway, in which case you likely won't even need an ND filter.
Fuji X-T3 // Fuji X-Pro2 (Full Spectrum) // Fuji X-H1 // Fuji X-T1
flickr (external link) // Instagram (external link)www.LucasGPhoto.com (external link)
cayenne_ksa
Nov 19, 2013 21:50 as a reply to  @ EverydayGetaway's post |  #12
milleniumking wrote in post #16463915 (external link)
if there is no difference in image quality at good lighting condition i would rather go with 6d and invest more in gears. so my main concern is image quality
VicSkimmr wrote in post #16464499 (external link)
I still have my 7d for higher FBS.
cayenne_ksa
Nov 19, 2013 21:53 |  #13
correct me if i'm wrong but the main advantage in my case to go with 5d iii is AF system and the ability to use it more for motorsport than 6d. The 7d can make up that.
in terms of image quality at conditions for still cars, it will be the same.
i can sell the 7d and get 5d iii instead of 7d+6d, but as mentioned i prefer to have 2 bodies
stang67
Joined Mar 2013
Nov 19, 2013 23:30 |  #14
I'd definitely go for the 6D in your position. It should be decent at the track and if you want something with better AF and higher burst rate, you have the 7D. The 5D III would be to replace your 7D, but since you want 2 bodies; 6D+7D no question.
Canon 6D - Canon 1D Mk III - 70-200mm f/2.8L IS II | Σ 105mm f/2.8 | Canon 400mm f/5.6L | Σ 35mm f/1.4 | 17-40mm f/4L
OneJZsupra
Nov 20, 2013 00:55 |  #15
I would go 5d3, your love of cars could take you to the track and having the af system of the 5d could help out a lot.
Gear List | Feed Back | My Site (external link)
YN RF-603 O-ring solution
5,286 views & 0 likes for this thread
Latest registered member is May*Gem5
795 guests, 280 members online
